Re: Threading full depth i one cut OSP5020L
hello vesene, just like broby said, pls check attached about g33 + more goodies
if you are going to use g33 after another threading code, be sure to use same rpm ( just like rcs60 said ); this involves both codes to use the same start spindle phase
you may achieve custom infeed paterns by changing start_Z or Q
it may be possible to use also G71 with custom parameters, just like rcs60 said, but so far i have not tried this ...
if you are going to use a custom G71, you may simply copy-paste the threading operation inside igf, and edit the copy; for g33 you will need to insert a g-code sequence, and write the code inside it
remove burrs after a finish cut or add some extra threading passes because of deflection whitout having to go thru the intire cutting cycle
if you wish, pls specify what kind of burrs you wish to remove :
... near end or start of thread
... after last pass
... ocasional burrs, among intermediate passes ?
sometimes, a bigger insert may behave better then a smaller insert ... just saying, i don't know your setup
if you wish, i may give you a code sample / kindly
