![Quote](images/misc/quote_icon.png)
Originally Posted by
Shrimp
I'm not a non-technical person. I have a self designed and built 3-axis pipe profiler using the ESS. Regardless of the demo mode debacle I was still informed that I would need to put the spindle into manual mode, manually set the RPM's of the lathe spindle, and then try to run the threading cycle to get it to work. Maybe they suggest that because the PC supplied with the machine can't keep up with with cycle. My new setup runs it just fine allowing mach3 to control the spindle. I'd rather not try to convert this machine to an ESS as it's not that important.
