Brain teaser question..... Can you use a standard 60 Deg Threading insert to cut metric pitch threads? I was told you could. So I tried it, (non critical part) and it seamed to work. However the part I threaded was a stop for the spindle bore that basically screwed into the back of the bore. Now best guess was that it was a M56x2.0 Thread. I say this because the thread was made in the bore and then bored flush with the ID of the bore so the crest were turned off.
Now having that in mind.... you lose a certain amount of engagement. After threading, testing and recutting several times it finally went in. These threads were cut with a standard 60 Deg insert with a 29.5 plunge angle and a .07874 pitch (had to convert everything from M to S).
Bottom line question... Do you need metric threading inserts to cut metric threads or just use standard inserts the whole way through? This is to settle a debate at work. I looked the thread profiles up in Machinery's Handbook and the angles were the same for both profiles, 60 Deg. Aside from that the thread profile was different. :stickpoke
So any help would be awesome!!
