587,177 active members*
3,281 visitors online*
    Apr 2006
    125
    Talking Time for an Update???
    Hi Scott,
    Hope all is well.
    Following-on from Keith's post - when's the next update out?
    We all appreciate you're busy, but surely we're due one
    If you want to know what to add, you only have to ask
    :cheers:
    Mar 2003
    765
    Believe it or not I've actually been working on NCPlot and should have an update ready soon!
    Here's what I've been up to:
    Added feed rate and rapid override controls to the run time estimation page.
    Fixed a backplot bug that shows up when both scaling and rotation are active at the same time.
    Fixed a display bug that appears when multiple files are open and maximized and then one is closed.
    Added a new option for handling different types of rotary 4th axis.
    The DXF importing for lathe was essentialy broken, made several fixes for this.
    Added the modal values display to the marker.
    Added checkboxes to the tool list which allow the individual tool paths to be turned off or on.
    Plus a few other things....
    Hang in there, it should be ready soon.
    Scott
    Apr 2006
    125
    Good man Scott
    Have you got anywhere with plotting a tool at a time (ie backplot automatically stops at M01 or Tcall I suppose)?
    Also as we're on a roll, any news on the solids verify?
    :cheers:
  1. long time reader first time poster
    By blu333 in forum MetalWork Discussion
    Last Post: 02-21-2010, 12:30 PM
  2. USB Update
    By Mark A Johnson in forum Tormach Personal CNC Mill
    Last Post: 04-13-2009, 02:11 PM
  3. 10.7 Update
    By Dolphin USA in forum Dolphin CAD/CAM
    Last Post: 03-17-2008, 09:12 PM
  4. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
  5. X2 Conversion Time (shopping time)
    By Micro Rotors in forum Benchtop Machines
    Last Post: 03-04-2007, 06:11 PM
