603,894 active members*
2,695 visitors online*
    Dec 2006
    42
    Timeout for code to be executed
    hi everyone
    What im trying to do is set a timeout in my M6 script so that if i certain command is not executed within a certain time, the program is halted and ideally bring up an alarm.
    an example scenario would be during a tool change. Say the carousel gets jammed and doesnt reach the spindle within 10 seconds (which would be detected by a limit switch on the carousel slide), then the toolchange procedure would be halted and
    the machine stopped, an alarm condition activated for an operator to attend to the jam.
    The timer/timeout is what im struggling with
    thanks in advance
    Aug 2023
    6
    Hi impi,
    Just have a look at this users M6 script https://github.com/Klaus-Michael/PlanetCNC_KMS_Stuff/tree/main/KMS-DIY-CNC/Scripts
    I think you will find a lot about what you need. M2 aborting several checks. And gcode like G9 or pause...
    Dec 2006
    42
    Re: Timeout for code to be executed
    Thank you, will take a look
  1. IF function executed thru O6001
    By JBMachad in forum Fanuc
    Last Post: 06-13-2023, 02:46 PM
  2. Edgecam PDI Problem (plugin is executed twice)
    By yangkaidi in forum EdgeCam
    Last Post: 09-13-2022, 02:01 AM
  3. TNGv2 Comments being executed
    By theRat in forum PlanetCNC
    Last Post: 02-26-2020, 10:31 AM
  4. Replies: 6
    Last Post: 03-15-2015, 03:11 AM
  5. Realtime timeout!
    By matthew6060 in forum Cincinnati CNC
    Last Post: 02-22-2009, 06:33 PM
