Does anyone know of a supplier for timing belts and gears in Ontario. I am trying to work out the drive system for my machine, the steppers i have may be a little light so I was figuring to gear them up about 4-5 / 1.
http://motiontek.ca/pulley.html haven't got anything from them..
i got mine from
http://www.bbman.com/products/timing...t-pulleys.html
one was defective and i had to send a few emails to convince them to replace it, other than that they were pretty good
motiontek is quite expensive, although it does look high quality.
Not in canada, but just throwing them out there:
www.smallparts.com has many items, pulleys are various plastic types
https://sdp-si.com/eStore/ has tons, including metal
or hubbard cnc on ebay has some well priced XL belts + metal pulleys
The first two ship UPS (which can be scary for fees). I had good luck with smallparts for a $25 order, but haven't tried sdp. USPS would be slower but at most you pay taxes + $5.
in the UK but ..
http://technobots.co.uk/
Hi, for your pulleys and belts you can order by phone at sdp-si.com and they will send your order using USPS and it will cost you an additionnal 10.00 but at least you know the ending price and this is not so if you use UPS:devious: from what I can read you are looking for a 4.5:1 ratio, while going at spd-si web site take a look at their center distance designer http://www.sdp-si.com/Cd/default.htmto make sure that you have the proper number of teeth in tha swall pulley
Check with Toronto Gear, http://www.torontogear.com/ , they deal through distributors, probably most power tramsmission companies like Toronto Bearing, Canadian Bearing, etc. I've had reasonable success with their products and they can supply a fairly wide range of belts and pulleys. Custom parts are pricey but stock stuff is priced OK
check with Martin Gear www.martinsprocket.com they have a full line of timing gears
there is also Mcmaster Carr www.mcmastercarr.com
Thank you all for the info i should be able to get something with all that you gave:cheers:
You can email me at [email protected] for belts and pulleys
Bearing and Transmission and Kinecore both carry belts and pulleys. They will give you a catalog if you ask.
Paul
