Timing Belt Vendor
I'm hoping someone out there may know of a timing belt vendor that stocks belts longer than normal. I'm looking for a belt that is 192" long by at around 1" wide and hopefully with a Kevlar filament. I would like to stay near an XL size pitch (.2") but would consider using an X or even an MXL. Metric belts are not out of the question either. My reasoning for this is to keep the pulley size to a minimum while keeping as many teeth in contact as possible with the belt.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
