588,076 active members*
4,911 visitors online*
Results 1 to 6 of 6
    Mar 2010
    59
    timing belt walking off pulley??
    I just replaced my gantry on my 4x6 router, and now the timing belt is walking towards the motor. It is the exact same setup as before, just on a different gantry. It worked perfect before. Pulley has perfect alignment with idlers. Cant seem to figure this out, knowing (I thought) that a walking belt is caused by incorrect alignment.
    any thoughts?
    Stepper belt walking - YouTube
    Aug 2008
    409
    Either some sort of misalignment or your tension isnt set correctly is my guess.
    Mar 2010
    59
    Would too tight or too loose cause this?
    Sep 2005
    540
    My guess is that the shaft of your motor is not parallel with the shaft of what is being driven. The belt then walks to a position which it thinks is the largest diameter of the pulley. Not sure how else to explain it with out making a sketch. If you draw the shafts and pulley greatly misaligned you should be able to see what I am babbling about.
    Robert
    Mar 2010
    59
    The only pulley is on the shaft.
    Feb 2012
    From what I can see from the begining of the vid before the motor kicks in,your belt is at a slight angle and this will give rise to belt shift on the pully.
  1. HTD timing belt pulley
    By R.thayer in forum Uncategorised CAM Discussion
    Last Post: 11-14-2013, 10:08 PM
  2. What is a timing belt and pulley ?
    By ynneb in forum FAQ of DIY CNC Machine Building
    Last Post: 02-18-2011, 01:38 PM
  3. Timing belt & pulley supplier in UK
    By lsteele in forum Want To Buy...Need help!
    Last Post: 03-31-2009, 11:01 AM
  4. Reinstalling timing belt pulley
    By snapman in forum Linear and Rotary Motion
    Last Post: 01-04-2007, 05:46 AM
  5. Any recommended Timing belt and pulley?
    By starCNC in forum Uncategorised MetalWorking Machines
    Last Post: 08-01-2004, 05:29 AM
