Hello!
I've been trying out a new way (new for me) to cut timing pulleys.
I was unable to find a form for any pulley, so I had a go at creating one. This was done on my manual lathe, and then milled the "teeth" on my 4th axis:
I then hardened it, by heating to a nice cheery cherry red, and quenching in fresh oil:
It came out ok, but not perfect. Anyway, I tried cutting with it and had good results, but they quality of cuts declined very fast. After about 9 teeth, the blank was getting hot, and the cut was not clean at all!
Here is a video of some cuts.
Turn volume down a bit!
[ame="http://www.youtube.com/watch?v=dr_HE1LS8K4"]http://www.youtube.com/watch?v=dr_HE1LS8K4[/ame]
The machine is a Sieg X1 (150W), with home-made 4th axis from a 7x10 lathe head.
My settings:
- 9 tooth cutter, 25mm radius
- 1000rpm
- 100mm/min feed
- 0.6mm doc
- Mist coolant
So can anyone help me achieve better cuts without having to babysit the machine?
I realise this is probably not too easy, given that the tool is home-made, but please try!
Thanks!
