So I'm trying to program a simple 2D contour toolpath and selecting the outline as a continuous chain isn't working properly. I've imported the outlines as a DXF from adobe illustrator, and extruded them to the give me a solid model. Now when I go into CAM and try to select the outline, Fusion only wants to select one line segment at a time, and there are probably hundreds of segments, so I don't want to pick them one by one. The last time I cut letters like this I had problems trying to work directly with the 2D outline, but making a 3D solid model solved that problem. Now I was able to select one complete outline by chance when I moused over one tiny spot and the whole chain selected, but the rest of the letters won't let me do this. I was hoping there would be an option to right click and select all tangent lines or a whole loop, but haven't found that option. Is there something I'm missing here?
