588,380 active members*
5,165 visitors online*
Results 1 to 18 of 18
    Jul 2003
    71
    TL-2 Simple Questions
    Well we just signed over a check to purchase a TL-2 and there were a couple basic questions I forgot to ask and I really don't want to deal with the sales guy again and was hoping if anyone can help out with these couple questions.
    We purchased a TL-2 with:
    Coolant Pump Kit
    Manual Tailstock
    12" Chuck
    4 Station Turret
    and Quick Change tool post.
    First question is on installation, does the TL-2 need compressed air and if so what is it used for on the TL-2? Reason asking would a basing 5hp 50 gallon compressor work or should we plumb it to our be air dried compressor.
    For those who have purchased the tailstock does it come with a dead center or live center?
    This is the first time we have bought a lathe and a little anxios and want to make sure we have everything before the machien arrives.
    Oct 2006
    125
    no dead or live center,if you have an air dryer every machine should get air from there i dont think your machine will need it but you will need an air gun,why you need a 12" chuck a 10" should be more then enuff. and call the sales man bug the hell out of him thats what he is paid for. earplugs saftey glasses and a rain jacket are also needed.
    Jul 2005
    12177
    Tailstock option does not include any centers alive or dead.
    Clean, dry air is needed for the tool turret.
    12" chuck is overkill and is going to slow down the spindle acceleration.
    Jul 2003
    71
    Thanks for the quick reply guys. We needed the 12" for one of the discs/parts we will be running!!
    By any chance do you guys know what morse taper the tailstock uses???
    Jul 2005
    12177
    Quote Originally Posted by Tazzer View Post
    I think tailstock taper is #4.
    Regarding needing a 12" chuck for a big disc if you get something like a Bison with removable top jaws you can make custom jaws to hold discs much larger than the chuck body. Adapting a smaller chuck with funky custom jaws means you do not have the frustration of long start and stop times with a machine running small parts at higher speeds with a big chuck.
    Nov 2007
    1702
    I'm pretty sure that the tailstock is MT-5, not MT-4. Geof probably just mistyped because he is not known to make such basic mistakes.
    The machine itself doesn't use any air (unless its different than the TL-1). I also agree: the 12" chuck is totally overkill.
    Greg
    Jul 2005
    12177
    Quote Originally Posted by Donkey Hotey View Post
    He's probably correct, but I do know it is big, ridiculously so because the machine would never drive the largest size of drill that could be fitted in the taper.
    Jul 2005
    12177
    I'm pretty sure that the tailstock is MT-5, not MT-4......
    Oh ye of little faith; I decided to look it up. See below copied right from the Haas specs:
    "Manual tailstock for TL-2 includes platform with 48" travel (1219mm) & quill section with MT4 & locking handle for manual thrust."
    Dec 2008
    319
    We also got the upgraded pump with our tm-2.
    If I were to buy another one like it I would just upgrade the pump myself and put the $$ into tooling.
    I would have also made them throw in some class time.
    Tim
    Upgraded Pump
    Hi Tim,
    Does the TM-2 have an enclosure? I don't think so??? That upgraded pump really puts out a good coolant spray and will give you a bath of coolant if you don't have some type of enclosure. The standard 5 gallon pump system is a JOKE.
    John
    Nov 2007
    1702
    Quote Originally Posted by Geof View Post
    You win, Geof. :cheers: I was thinking of the TL-1 spindle (A5). I made that mistake once before, when I ordered a rotating tailstock chuck.
    Greg
    Jul 2005
    12177
    I am not much better...I ordered a chuck and got the spindle specification wrong; needless to say it did not fit.
    Dec 2008
    717
    Man, even I knew not to second guess Geof..
    Quote Originally Posted by axis View Post
    ......and a rain jacket are also needed.
    HA! I totally agree. - I miss being showered with coolant and fire hot Chromoly chips!
    Have fun! Those are cool machines.
    Tim
    Aug 2005
    235
    Call the sales man and GET THE ENCLOSURE!!!!! I have one on a TL-2 and use it to avoid burns from hot chips, keep my shop clean and run coolant without getting a bath. It is worth the exorborant price that they charge for it but it is better than being miserable.
    Jun 2006
    47
    Get the 10" chuck and make jaws to hold your parts. Here is my TL-1 with an 8" chuck turning 12.25" diameter castings,
    Mark Hockett
    cmacclel Guest
    Quote Originally Posted by Mark Hockett View Post
    Mark Hockett
    Wow you have some nutz I guess I really need to know the boundary's of material holding. Your only holding that piece by around a 1/2"? How heavy is the part?? 30+ lbs??
    Mac
  17. #17
    Jun 2006
    47
    Quote Originally Posted by cmacclel View Post
    Mac
    Its being held by almost 1" of the small diameter when facing and turning the OD. I have done about 50 of those parts like that. Once I have the OD and one face done I can turn the part around and grip it by the OD to face the other side. The castings weigh about 42 lbs when I start. Here is a finished part,
  18. #18
    Jul 2005
    12177
    I like the way you don't change jaws to go between the OD, the boss and back to the OD. (At least that's what it looks like is possible)
    What is the material? It seems to give a nice finish both turning and milling.
  1. A couple more simple questions for a CNC builder
    By Danno in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-11-2008, 06:27 PM
  2. Please Help!! Simple 3-D part not so simple for me
    By eaglegage in forum Mastercam
    Last Post: 05-15-2008, 04:00 PM
  3. Simple Questions
    By pzzamakr1980 in forum Mastercam
    Last Post: 03-12-2008, 02:54 PM
  4. Simple questions.
    By Dr Honda in forum Gecko Drives
    Last Post: 09-11-2007, 04:51 AM
  5. Simple Question Simple Answer ?
    By p3t3rv in forum Stepper Motors / Drives
    Last Post: 02-16-2006, 04:00 PM
