Have a look at this thread: http://www.cnczone.com/forums/haas_m...rformance.html
All the TM machines have the same spindle and servos only the axis lengths are different.
I think they are good value for money. Certainly they are not a VF2 sporting a 10,000rpm spindle and if someone buys one expecting that type of machine they are being silly.
The precision/accuracy is just the same as all the other Haas mills. They will machine steel perfectly well provided you recognise that a 3" face mill is not possible. However, 1-1/2" is fine and will handle a reasonable rate of material removal. Larger end mills, 5/8" and up, can be problematic in steel because the spindle does not have a lot of torque.
