587,997 active members*
2,970 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > TM1 or MiniMill, how many differences?
Results 1 to 6 of 6
    Oct 2015
    24
    I was looking at some 10-15 yr old mills. I noticed the TM1 and MiniMill can both run on single phase. What are all the differences between the two? (TM1 with toolchanger and programmable coolant nozzle)
    Thanks in advance!
    Feb 2009
    311
    Re: TM1 or MiniMill, how many differences?
    The TM1 has a longer (in X) and slightly narrower (in Y) table, and also more X and Z travel. The mini mill has a full enclosure and the TM1 may or may not. The TM1 without the full enclosure has a maximum spindle speed of 4000RPM and maximum axis travel speeds of 200IPM. These can be increased to 6000RPM and 400IPM by changing parameters (the TM1 with full enclosure has these faster spindle and axis speeds already set).
    The current mini mill (not sure about the older ones) has a max rapid speed of 600IPM. I'm also pretty sure the TM1 and mini mill use the same spindle.
    The maximum table weight capacity of the TM1 is 1000lbs, which is twice that of the mini mill.
    There may be other differences but this is what I know. This also assumes the standard mini mill and not the mini mill 2 or super mini mill.
    C|
    Dec 2004
    126
    10 to15 year old HAAS ,,, RUN AWAY FAST
    they no longer supporting the control ,,, ZERO control boards available for pre 2002 year machines ... to fix a bad board you could be looking at 10K or more ,,, most machines that old would need a new CRT and spindle drive to work with the newer controller cards. and what day is Haas going to stop making boards for the newer machines ...
    Mar 2010
    1852
    Quote Originally Posted by D.D.Machine View Post
    Yeah, now if they would just fail I could ***** like you. I run a 96 and a 97 that just keep pumping out parts without any board failures.
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
    Oct 2015
    24
    Thanks for to info!
    Mar 2009
    88
    TM1 if you can find one. Much more versatile machine, especially the open machine(definitely need the chip cover though). X and Z on mini are really limiting on the mini. Even though the TM has a much bigger table, the footprint of the machine is the same.
  1. NM-135 X and Y differences
    By tas99 in forum Novakon
    Last Post: 02-12-2021, 10:17 PM
  2. G98 and G99 differences?
    By cossiegaz in forum G-Code Programing
    Last Post: 05-21-2016, 05:00 PM
  3. Differences from V23 to V24
    By hkenuam in forum BobCad-Cam
    Last Post: 11-18-2011, 05:56 PM
  4. g-rex 100 101 differences?
    By h_2_o in forum Gecko Drives
    Last Post: 02-28-2006, 07:03 AM
  5. Can someone explain the differences?
    By turmite in forum Servo Motors / Drives
    Last Post: 02-08-2006, 03:20 AM
