586,058 active members*
4,449 visitors online*
    Sep 2013
    14
    TNC 426PB Change encoder input
    Hi guys!
    Bridgeport VMC 800 with Heidenhain TNC 426PB.
    Get alarms concerning spindle motor encoder amplitude.
    I usually try change interface port on the TNC first. Normally the spindle motor encoder is connected to X19 and usually the X20 is free.
    At least on TNC 530 You just change values in MP 113, but in this version of the controller MP113 is not present and so isn´t MP112 for the corresponding axes control.
    According to the regional Heidenhain office, this feature isn´t available on this version of the controller. The port addressed (or numbers) are somewhat hardwired in the system, so we don´t have the liberty to change inputs as we see fit. Well, this i could accept if it wasn´t for one thing. The spindle motor encoder cable that is supposed to sit at X19 was already put on X20 when I was enrolled to repair the machine, and it has been that way for years - working. I´m pretty sure the normal position is X19 for this machine as that correspond to the schematics and the marking on the cable itself. Now there is a crude piece of tape with marker saying X20 on the cable.
    If I knew who made the modification of course I´d ask him HOW? But now... Do anybody have a clue how this was done without changing the nonexisting MP113?
    Jun 2015
    3
    Re: TNC 426PB Change encoder input
    Hello Thamaz,
    I am facing same problem with our old Bridgeport VMC 800 on Z Axis. Our Z Axis encoder is fitted on X 18 in place of X 17. Did you find some solution to your question? If you could advise on how the swap was done, we could use X19 port for Z axis.
    Regards
    Sep 2013
    14
    Quote Originally Posted by pawansharmahelp View Post
    Hello Thamaz,
    Regards
    Hello pawansharmahelp. This was some time ago and I certainly don't remember that particular task and it's outcome. But here goes: MP 112.0 designates the port of the X-axis default is 15, MP 112.1 the Y-axis as 16 and 112.2 the Z-axis as 17 This is deafault. You want to connect the Z-axis to port 19, this might not be possible as port 19 and 20 are default designated for the spindle encoder. I'm in the dark here but You might try on your own risk setting MP112.2 to 19. Beware - I DO NOT KNOW IF THIS WILL WORK!
  1. Deciphering Leadshines encoder input pins.
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 09-21-2015, 06:38 PM
  2. Encoder input to Smooth Stepper
    By Georgie in forum SmoothStepper Motion Control
    Last Post: 05-08-2015, 12:53 PM
  3. Heidenhain linear encoder as input
    By markder13 in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-30-2014, 12:35 AM
  4. HOW TO CHANGE ACTIVE ENCODER FROM LINEAR SCALE TO MOTOR ENCODER IN SIEMENS 840D.
    By sandeepmb123 in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 01-02-2014, 08:05 PM
  5. Need some input on fitting encoder to old motor
    By Greenbuggy in forum Servo Motors / Drives
    Last Post: 05-21-2012, 09:05 PM
