603,349 active members*
2,969 visitors online*
Results 1 to 4 of 4
    Hello
    I have the following problem: With my DMC635Veco machine, the blow air is switched on via M25. It would be helpful if it could go off pulsed rather than constantly. Can you reprogram it? If yes how do you do that?
    Gruß,<br><br>HS-Cutter
    Jan 2009
    376
    You could write your own M-function (there is also a thread in the forum for that topic) and switch the air on and off with retention time.
    Hello
    I guess you want the blow air during the editing process.
    In order to place the switching on and off into the background, you have to dig deep into the PLC and also that wouldn’t no be plain text anymore.
    Simply building in a timing element into the Pneumatic pipes might be the best solution.
    Greetings
    cgTNC
    Hello wolf310 und cgTNC
    Thanks for your hints
    @wolf310: where can I find the thread? Cant find it using the search function,
    @cGTNC: also a possibility. However I only know timing elements that delay only once. I would need one that works intermittently. Where can I find something like that?
