588,216 active members*
4,031 visitors online*
Thread: TNG Progress
Page 2 of 6 1234
Results 21 to 40 of 104
  1. #21
    Feb 2019
    76
    Re: TNG Progress
    SkiPatrol
  2. #22
    May 2019
    28
    Re: TNG Progress
    @ Anriro I saw your video from another thread and I now understand ... hopefully v2 will solve that for you. PlanetCNC is fully committed on delivering TNGv2 and I trust that as soon as they can provide us with a delivery date they will. I am really happy with the current version of TNG and I have been able to do some amazing things with it. To think that TNGv2 is going to be even better and run natively on my Mac is just phenomenal. Wish I could download it today.
  3. #23
    Aug 2018
    4
    Re: TNG Progress
    Hi, Is there any news about the TNG progress? Its already October 2019 ...
  4. #24
    Mar 2017
    1340
    Re: TNG Progress
    PlanetCNC TNG V2 beta version will be released at the end of this month.
  5. #25
    Aug 2018
    4
    Re: TNG Progress
    That's great news! Thanks for information.
  6. #26
    Aug 2011
    999
    Re: TNG Progress
    Quote Originally Posted by PlanetCNC View Post
    Got a sneak preview of the changes? Especially the support of rotary machining (incl. graphical preview) and making the transformation matrix "stick" when the program is closed like the old software?
    Box Joint and Dovetail CAM software here: WWW.TAILMAKER.NET
  7. #27
    Mar 2017
    1340
    Re: TNG Progress
    Graphical preview of rotary axes is implemented.
    Transformation stay active when g-code program is reloaded. It can also be persistent between software restarts.
  8. #28
    Aug 2011
    999
    Re: TNG Progress
    Great. I can't wait to try it out....
  9. #29
    Mar 2017
    1340
    Re: TNG Progress
    Screenshot
  10. #30
    Re: TNG Progress
    Couple of questions...
    Are the change notes posted somewhere? I didn't see them on this forum or the Planet-CNC.com website.
    Also, if V2 is still in beta, why isn't V1 still available for download? I would think that users like myself could potentially need to revert to V1 if issues are found in V2.
  11. #31
    Mar 2017
    1340
    Everything is changed so change log isn't really applicable.
    Status is beta until cycles are completed.
    Untill then you can get link to previous TNG version from our support.
  12. #32
    May 2008
    266
    Re: TNG Progress
    Is G76 implemented, because TNG v2 is throwing this error - "Word 'I' without command that uses it"
    EXAMPLE CODE:
    (PLANETCNC-TNG LINUX-CNC)
    (ECAM V4 ***LATHE*** )
    (CREATED ON 28/10/2019 AT 23:28)
    (PART DESCRIPTION: BRASS PILLAR)
    (PROG NUMBER: 1)
    (STOCK O/D: 7.000)
    (STOCK I/D: 0.000)
    (STOCK LENGTH: 15.000)
    (------------------ TOOL LIST ------------------)
    (TOOL:EXTERN THREAD TOOL )
    (SETUP 1)
    G08 G18 G21 G54 G61 G80 G90
    (M7 X 1)
    (EXTERN THREAD TOOL )
    (MAX Z TRAVEL: 1.000)
    (MIN Z TRAVEL: -10.000)
    (MAX X TRAVEL: 4.000)
    (MIN X TRAVEL: 2.887)
    G94 T15 G43 H15 M6
    G97 S600 M3 G04 P1 M8
    G0 X4.000 Z1.000
    G76 P1.000 Z-10.000 I-0.500 J0.168 K0.613 E0.613 H2 L2 Q29.4 R1.7
    G0 X4.000 Z1.000
    G53 X23.000 Z112.000
    M5
    M9
    M2
  13. #33
    Aug 2011
    999
    Re: TNG Progress
    Thanks, just downloaded and tried in simulation mode. Looking good so far. Will try tomorrow on the machine.
    Questions and some beta findings:
    - Same license info as for the V1 version, I guess?
    - The whole speed calculation and lookahead thing seems to have changed. Should I just use the defaults that came with the download?
    - I am missing the button from the old CNC-USB software to set all positions to zero. Can I get that somehow back?
    - Whe I click "Check for updates" it tells me that I still have the 2018 version and should update to the 2019 version, although I definitely have the 2019 version. So, the update check does not work properly.
    - The helpfile/user manual and g-code manual menu items do not work.
    - It shows "Revert to V1" in the machine menu. Does that mean "Revert to TNG V1" or is it "Revert to CNC-USB" ? I would hate to update if I don't have the option to go back to CNC-USB if something does not work for me.
  14. #34
    Mar 2017
    1340
    Re: TNG Progress
    G76 is a cycle. There are some issues with cycles and we need a week or so to finish them.
  15. #35
    Mar 2017
    1340
    Re: TNG Progress
    - Same license as TNGv1. If you have old CNCUSB license then write to support to get TNGv2 license.
    - Defaults lookahead/blend settings should be fine for most users.
    - There is a button to set XY work position to zero and Z work position to zero because usually work position is set separately for Z. However in TNGv2 you can create custom buttons and/or change behavior of most machine related commands.
    - Check for updates needs to be updated. I simply forgot.
    - I will check why manuals don't work. There should be 3 manuals in setup file.
    - Revert to V1 means go back to Mk1 CNCUSB. Make sure you follow instructions how to properly use this.
    https://planet-cnc.com/updating-plan...-tng-software/
  16. #36
    Apr 2013
    110
    Re: TNG Progress
    Hello,
    I downloaded TNG V2 beta but the software installation is not clear to me; I noticed that the executable contained in the download is executed directly without installation ... maybe because I have already installed the V.1? Perhaps the contents of the zip should be copied to the V1 folder replacing the original files? in this case, is the software localization still possible with the txt files contained in the lang folder?
  17. #37
    Mar 2017
    1340
    Re: TNG Progress
    You are right. There was a problem in publish script and I accidentally uploaded update files and not whole installation. This should be fixed now. Thank you for letting me know.
    @JerryBurks - this should also fix "user manual" issue and "check for updates"
  18. #38
    Apr 2013
    110
    Re: TNG Progress
    Excellent, downloaded and installed ... thanks
  19. #39
    Apr 2013
    110
    Re: TNG Progress
    Hello,
    TNG V.2: error detected with the M3 and M5 spindle commands. Is there something wrong with my configuration?
    Attachment 430270
    Attachment 430272
    Attachment 430274
  20. #40
    Mar 2017
    1340
    You should delete your old scripts. TNGv2 has much more powerful scripting options but unfortunately syntax is different from old TNG.
Page 2 of 6 1234
  1. progress
    By 1hander in forum Benchtop Machines
    Last Post: 02-24-2016, 04:00 AM
  2. more progress..
    By adam_m in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 03:56 AM
  3. Progress at last
    By RustedOut in forum Charter Oak Automation Support Forum
    Last Post: 10-16-2010, 05:13 PM
  4. My first CNC... in progress!
    By hi-tech in forum CNC Wood Router Project Log
    Last Post: 06-02-2009, 10:45 PM
  5. progress! (pix)
    By anthony in forum Waterjet General Topics
    Last Post: 06-03-2005, 10:56 PM
