586,036 active members*
4,343 visitors online*
Results 1 to 8 of 8
    May 2004
    18
    Too many digits
    I am programming a B axis which is capable of feeding at 5,400 degrees per minute. But I can only program F999. I cannot find a parameter that controls the number of F digits. Can any one help?
    Jun 2010
    161
    What model of FANUC CNC is used?
    May 2004
    18
    16-M
    Jun 2010
    161
    Try setting parameter 1404.2 (3rd bit from the right) = 1 to extend the commanded feedrate.
    May 2004
    18
    Thanks. I will try
    May 2004
    18
    I tried that and still got the 003 Too Many Digits.
    So I tried programming the F word without a decimal and it worked.
    I set 1404.2 back to 0 and it still works now.
    Thank you for your assistance
    Apr 2009
    22
    I had a similar problem on an 18i-MB. It was fitted with one of the new Direct Drive Rotary 4th axis capable of 250 RPM. I ended up programming in metric to get past the 4 didn't issue. Fanuc said they would look into it, but nothing every came of it.
    Hope you find a solution.
    OU812
    Feb 2008
    586
    I once had to use inverse time to feed fast with a rotary. G94? I forget... but figure out how long, say, 5 seconds, program F(1/5) or F.2 It will take 5 secs to get there.
  1. Alarm 003 to many digits on Hardinge with 18-T
    By HBFixedGear in forum Fanuc
    Last Post: 08-10-2022, 01:45 AM
  2. G-Code output precision always 3 digits?
    By cwm9 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 04-24-2016, 03:33 PM
  3. Replies: 5
    Last Post: 03-22-2010, 03:13 PM
  4. Dialog Digits
    By MikeT in forum BobCad-Cam
    Last Post: 03-02-2004, 03:07 PM
