Originally Posted by
timmyb199
hi i run mach 3 and am trying the demo and when i export it says tool change not supported, is it really not supported or do i need a different post procesor file or how should i get around this
If you would like to have support for it you can use the mach 3 atc pp. If you don't want it just use the regular mach 3 inch or the basic g-code..
I use it so i can combine multible toolpaths into one file...mach 3 will run all toolpaths that use the same tool.
Chuck
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
