603,864 active members*
3,980 visitors online*
    Feb 2008
    12
    tool change stalls in high speed range
    My tree 1050 will stall in high speed range during a tool change with tools in the pockets but will run all day long with no tools in it.any ideas where to look would be apprecited.
    Bob
    Jan 2008
    136
    check spindle orientation position is correct, ie that the motor is not fighting against the driving dogs.
    Feb 2008
    12
    thanks for the post,the orient position is right,works all day long in low speed but not in high gear with a tool in it.
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-07-2014, 01:33 AM
  3. Spindle speed range or lack of it!
    By creep_pea in forum Bridgeport / Hardinge Mills
    Last Post: 10-04-2006, 10:42 PM
  4. Replies: 15
    Last Post: 08-10-2006, 03:13 AM
  5. Speed range for VFD and three phase motor
    By RotarySMP in forum CNC Machine Related Electronics
    Last Post: 04-20-2005, 08:05 PM
