587,833 active members*
3,820 visitors online*
Results 1 to 5 of 5
    May 2006
    4
    Tool Changer Stuck
    the machine was running and was in the middle of changing tool when the air pressure got low,now the carosell it is stuck next to the spindle and wont return. any ideas how to make it return? thanks 1991 40/20
    Jul 2003
    1220
    Suggest you turn machine off.
    Disconnect the air line to machine and pull carousel back.
    This is what I've done but it isn't a Fadal.
    Feb 2007
    464
    Maybe you have M codes that will turn it manually.
    Jun 2007
    31
    You can push the Carousel back with your hands,no problem.
    Oct 2003
    530
    My fadal vmc15 has had this problem before. The carousel should move back by hand. If it doesn't want to move you might have to move the bar that actually moves the carousel by hand a little bit.
  1. Tool changer stuck, help
    By ShortRunCNC in forum Daewoo/Doosan
    Last Post: 05-19-2007, 01:23 AM
  2. Big problem. Tool stuck
    By Tien_Luu in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-04-2006, 09:46 PM
  3. Pallet changer stuck
    By Jedi in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2006, 09:43 AM
