603,923 active members*
3,063 visitors online*
    Jun 2010
    Tool Geometry / Offset
    I'm new to running a 240MS and am not understanding how the geometry offset library works. It has a 12 station turret with an offset registry of 32. If I MDI a T0808 and use the Q setter, all the information will go into the 08 offset. If I MDI a T0816 and use the Q setter, all the information goes into the 08 offset. (I've tried MDI T1608 and get an error message!) (The old cnc lathe had a 32 tool tool library with a 12 position turret that I could use tool 24 in position 6.) Can I run the 240 like this or not? Thanks!
    Mar 2003
    2932
    By default, the offset is selected according to the tool number when you lower the Q-setter. This is to avoid the possibility of setting the wrong offset when you touch off. I believe that parameter 5005 bit 5 selects whether or not this happens. Your machine is probably set to 1. If you set this bit to 0, it won't automatically select the offset when you lower the Q-setter.
    Oct 2009
    30
    If I'm understanding u correctly, u may call for ex t01 then any offset u like 0-12 so t0101 or t0106 or t0111. Not the offset then tool. As far as usingthe qsetter goes I believe u can manually change offset number with the arrow keys after registry appears . So when u pull qsetter down with tool 5 in position t5 registry will be highlighted on t5 x just scroll down with arrow keys to pick alternate offset number then touch off qsetter.
    Good luck
  1. Tool geometry offset Y-axis
    By Dlo in forum Mori Seiki lathes
    Last Post: 05-13-2010, 07:26 AM
  2. Okuma howa tool geometry protect
    By chrisclegg in forum Okuma
    Last Post: 10-10-2008, 02:36 PM
  3. Loading tool geometry with G10 ???
    By theemudracer in forum Fanuc
    Last Post: 12-11-2007, 02:06 AM
  4. Lathe geometry offset
    By cncdigger in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-29-2007, 11:52 PM
  5. Help needed on tool path geometry
    By 2_jammer in forum G-Code Programing
    Last Post: 03-13-2006, 06:03 AM
