603,943 active members*
3,963 visitors online*
    May 2011
    108
    tool height setting question
    I need a way to set my tool heights when doing tool changes.
    Im new to milling a cnc and cant grasp this yet. i am using R8 collets (not end mill holders) so i dont have any repeatability with different size tools put in the collets at different heights everytime .
    Because of that i need to find a tool height everytime i put a new tool in. When running a program and it calls for a tool change how do i find the height of the tool in mid program? I surely cant set the height before running the program since the next time i put the tool in when running the program it would be a different height .
    I have a .060 touchplate i made and a Hoss tool probe screen to find tool heights but can i use this during a tool change in a program?
    Also i am trying to find out how to use the tool probe correctly . I set the plate thickness (.060) .When i press the z tool probe button the tool comes down and contacts the plate then retracts 1" back up. Does this automatically set the right height in work DRO's or Machine DRO's ? Im not sure since it retracts back up to 1" everytime. Also do i have to manually jog the height difference of the .060 or it removes it automatically, Lastly do i then set the height it says the tool is in the tool table or am i ready to go ?
    Thanks for the help.
    Grizzly G0602-AXA QCTP<<< Soon to be CNC and 3PHA-VFD !
    7x14Lathe, X2cncmillG540 Solidworks,HSMworks,VcarvePro
    Mar 2003
    35494
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2012
    1543
    Re: tool height setting question
    Simply zero your new tool each tool change, its not like your giving the tool an offset, ie. M6 T3 G43 H3, you would just have M6 T3, so no offset. I'm on Tapatalk and don't remember the other questions, because I can't see them while typing this, sorry.
  1. Replies: 10
    Last Post: 10-14-2011, 07:59 PM
  2. Replies: 3
    Last Post: 05-22-2010, 06:09 PM
  3. fanuc series oi-mb Setting tool height?
    By esadaddy in forum Fanuc
    Last Post: 01-08-2009, 08:15 AM
  4. Setting tool height
    By is300driver in forum MetalWork Discussion
    Last Post: 11-15-2006, 01:28 AM
  5. Setting Tool Height
    By JAGYZF in forum Commercial CNC Wood Routers
    Last Post: 03-22-2005, 02:22 PM
