Hello;
I'm using Mach 2 but keep having tool offset problems when I have a program that uses multiple tools.
After I make the tool change (manually), then hit "start", the tool length offset is not added !!
Am totally confused
Just before the program request for a tool change, the g-code looks like this example;
G49 z2.0
m05
Goo x0.0 y0.0
m06 T02
M03
s3000
etc.......
I thought my problem was because my post processor was installing G49 before the tool change, but I think it has something to do with the way I have setup Mach.
I've been editing my g-code files manually by removing the "G49" command, before machining, but I don't think this is the proper fix.
Any help would be greatly appreciated.
Dan
