603,935 active members*
6,371 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > tool library...or is it?
    Jul 2007
    29
    Has any one been able to successfully add a variety of tools to various features of a single part.
    For instance I need to use two different center drills. The BCC center drill default is .25". I want three different holes in one part the smallest being #50 for a 2-56 tap hole. The material thickness is .125 so the .25" center drill is no good. If I change the center drill parameters for a #1 center drill I'm stuck
    with it for the larger holes.
    The tool change option is virtually impossible. I was instructed by tech support to "trick" the program using radius variations to use different endmills. ex. - .25" 3FL rougher is .0001 R, .25" 4 FL rougher .0002 R, etc.
    In addition if I want a profile cut using a chamfer mill I cannot even choose it
    as an option. Is there any option for a 45 degree chamfer other than a 3D tool path? In the year I've had the program, the more I advance even more hassles evolve. If it's a basic one drill, one end mill part, no problem. beyond that it's very frustrating.
    Oct 2007
    142
    I understand your frustration.
    It took a while for me to learn the tool change stuff. I dont know if this is specific to my machine, of if its a BCC thing, but this is how I have to do it
    First thing I do is set the XY edges
    Then retract the spindle to the tool change position I want. (Tool 0)
    Set the TLO from the tool 0 position (the last program had 8 tool changes).
    Then set the Z zero (touch the top of part)
    Then select the program you want to run. If the program I am going to run is already selected I have to select another program, then reselect the one I want.
    If I do it in any other order than that, it dosent work properly. But when I do it in the right order it works great.
    For the center drill operations I write the code by hand in the predator. I havent had time to play with the point pattern operation for drilling yet.
    Not sure if this related to your problem, but I hope it helps
    Oct 2007
    142
    How do you attach the thumb nails?
  1. Tool Library Questions
    By Mastercam User in forum Mastercam
    Last Post: 05-11-2008, 07:22 PM
  2. MCX Tool library question
    By MauserBob in forum Mastercam
    Last Post: 04-18-2008, 02:20 PM
  3. Tool Library Catagories
    By PinMan in forum BobCad-Cam
    Last Post: 04-18-2008, 01:21 PM
  4. How to get more tools in the tool library?
    By clint_so in forum Mastercam
    Last Post: 07-24-2007, 04:55 PM
  5. Tool Library and Roundover Toolpaths
    By Natchamp in forum Visual Mill
    Last Post: 07-12-2004, 02:53 PM
