On my macturn 250w how can I differentiate two tools on the same turret station(bottom turret) one on either side for group numbers? It only gives you 12 possibilities for group number, yet under group table , there are 96 possibilities! Which leads me to believe I can do it. I am already running both tools without life or monitoring, under a group number you lose the identification of the sub side tool in relation to turret position. Example, t0404(main), t0424(sub) is what I have now. Assigning group numbers you would need 24 to be its own tool not a secondary offset to 04. But then it loses it's spot on the turret, only 12 identified stations! Hope I explained it okay! I understand if you need better clarification, any help I would really appreciate!
P.s. Monitoring won't be a problem as you identify by "parts" 64 spots on each turret or milling spindle. Thanks!!!!
