Hi
I have recently got a CNC for making one piece MDF doors. On the shaker (flat panel) door the are a lot of tool marks left on the flat panel. The larger bit that does the first pass (1 1/2" diameter) leaves lines as it makes it passes. The smaller diameter (1/8") bit that goes around after leaves lines and it is very clear where it cut (often slightly lower of a cut)
I've tired making more passes (which has helped) but still leaves lines. I've made sure all my material is secure, the table has been surfaced as well as varying the speeds and feed rates.
I've also used a small magnetic level to make sure the spindle head is mounter level.
Does anyone have any suggestions? Either machine setup or programming?
