587,869 active members*
3,147 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Tool Nose Radius Fault with Program
Results 1 to 5 of 5
    Sep 2006
    17
    Hey guys,
    I am having a little problem with a tool nose radius program on my lathe. The tools radius is .031" Here is the part of the program that is giving me problems. Thanks for any help.......
    N1
    M98P1
    T0101(80 DIAMOND)
    G97S800M13
    G00X1.55Z.1
    G50S2500
    G96S600
    G42X1.45Z.05
    G99
    G71U.05R.015
    G71P100Q200U.03W.01F.005
    N100G0X0.
    G01G99Z0.F.005
    X1.191,R.03
    X1.375Z-.875
    Z-1.0
    X1.4
    N200G0X1.45
    G70P100Q200
    M98P1
    Thanks for any help........
    Mar 2003
    4826
    missing an arc command gcode here, after the G01:
    G01G99Z0.F.005
    X1.191,R.03
    First you get good, then you get fast. Then grouchiness sets in.
    Mar 2003
    2932
    Josh,
    You don't say what problem you're having. Getting an alarm? Which one?
    Try the following:
    N1
    M98P1
    T0101(80 DIAMOND)
    G97S800M13
    G00X1.55Z.1
    G50S2500
    G96S600
    X1.45Z.05( <----------- REMOVE G42)
    G99
    G71U.05R.015
    N100G0G42X0.( <------------ ADD G42 HERE)
    G01G99Z0.F.005
    X1.191,R.03( <------------- MANUAL DOESN'T SHOW , IN EXAMPLES)
    X1.375Z-.875
    Z-1.0
    X1.4
    N200G0G40X1.45( <--------- ADD G40 HERE)
    G70P100Q200
    M98P1
    Jul 2005
    12177
    This question is also posted here:
    http://www.cnczone.com/forums/showthread.php?t=39809
    With this title:
    G-Code Problem on my Fanuc Oi Hardinge Lathe
    Any answers based on experience with Haas are maybe not going to be entirely useful.
    Mar 2003
    2932
    Silly me. Saw it posted in Haas Mills, thought it might be for a Haas. Now that I see the double G71's, I'm totally ashamed of answering the question at all. The answer should still work, however. I'll try to be more careful next time.
  1. tool nose radius comp
    By joe1970 in forum G-Code Programing
    Last Post: 02-25-2010, 04:43 AM
  2. Lathe Tool Tip Radius
    By clarkea1 in forum Mastercam
    Last Post: 05-21-2007, 06:10 PM
  3. Tool: Ball Nose definition in BobCad
    By rherman in forum BobCad-Cam
    Last Post: 09-20-2006, 09:48 PM
  4. tool nose comp.?
    By pp-TG in forum MetalWork Discussion
    Last Post: 09-19-2006, 09:36 PM
  5. Setting or Program fault?
    By Kiwi in forum BobCad-Cam
    Last Post: 04-28-2006, 12:42 PM
