587,167 active members*
3,498 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Tool Offsets - What's wrong with this Gear?
Results 1 to 14 of 14
    Oct 2006
    106
    I took a gear drawing from AutoCAD and used KCAM to convert to G-Code. The first cut looked good, but the teeth were pretty small - I forgot to account for the tool offset. I added G41 D1 and set up Tool 1 in Mach3 as the 1/8" bit that I'm using.
    The tops of the teeth came out correctly, but there's a strange undercut in the corners at the bottom of the teeth and there's a peak where it should be flat between these corners. In the picture, the gear in the back is the first one I cut with no offset and the one in the front was what I got when used G41. You can see the space at the base of the teeth and the little spline in the middle.
    Mar 2003
    4826
    What is wrong? It's undercut
    I suspect it is a case of tool interference due to inproper offset of the path within the controller's rad comp routine.
    The best way I've found to fix a troublesome path for radius comp is to fillet the internal corners of the 2d curve to match the tool radius. If the controller could execute the original path correctly, this is exactly what you will get anyways.
    So where the tooth meets the root circle, fillet the geometry to your 1/16" radius. You might discover that you will have to do some manual trimming to get a good continuous curve.
    Then, redo the toolpath on this new geometry.
    First you get good, then you get fast. Then grouchiness sets in.
    Oct 2006
    106
    Thanks, Hu. I'll play with it some more and see what I can do with it. I'm new to all this and was foolish to think it would be as simple as putting a G41 in the code.
    Dec 2010
    313
    Quote Originally Posted by edo View Post
    Just wondering if you could help me, how did you get the offset on the second gear? How did you set it up, in Mach3 or Lazycam?
    Thanks,
    Rob
    Oct 2006
    106
    Rob - you got me scratchin' my head - that was almost 6 years ago. I believe I took Hu's advice and used a fillet in the drawing before converting to G-code. I guess it didn't even occur to me that space between the teeth couldn't be smaller the cutting tool. I may have went to a 1/16" bit too.
    Good luck.
    Dec 2010
    313
    Good luck.
    I tried a smaller bit but still no luck, but thanks for the suggestion and thanks for thinking about the question.
    How do I use Hu`s advice and add a fillet? I am using Solidworks dwg editor and Mach3 with Lazycam, I don't have a good CAM program and don't have the money at the moment.
    Do you think ReplicatorG or Pronterface would work in place?
    Oct 2006
    106
    I use TurboCad and DesignCad 3D, both relatively simple & inexpensive and they work for everything I've needed. Solidworks dwg editor has the fillet function. Fillet turns a point where two lines meet into a curved line. Since we can't cut a sharp inside angle with a round bit, we fillet the intersection to match the radius of the bit. In DesignCad, I just hit F and a pop-up lets me enter the radius; then I click on one of the lines, move the cursor to the other line, click again and it turns the intersection into a curve.
    Hope this helps.
    Feb 2006
    1792
    Possibly the problem is with too large tool dia for the gear being cut.
    Dec 2010
    313
    Quote Originally Posted by sinha_nsit View Post
    Hi, Actually that's what I want the offset for, I need the software to produce G-code with that consideration.
    Feb 2006
    1792
    If a software being used, a larger step length might help.
    Dec 2010
    313
    How?
    i am using Mach3 as machine software
    Dec 2008
    3122
    Offset the teeth profile by 1/2 of the tool diameter you want to use, this offset contour is what you want to put thru KCAM to get G code. Your offset setting (D1) in Mach3 is set to zero.
    To get deeper into the root radius of the tooth, you would need to use a smaller tool, so offset the tooth profle for the area you want this smaller tool to go, by the (small) tool radius, & output that new contour thru KCAM
    You can add the G41 D1 to the start of each cut...and G40 at the end, you shouldn't need it if your tool is cutting correct size, ---- a minus tool offset in D1 ( in the control ) makes the tool cut closer to your part.
    place a circle ( T1 diameter ) on the V (1st toolpath ) to represent where the first tool can get to, showing you where to start the 2nd toolpath from.
    Dec 2010
    313
    Quote Originally Posted by Superman View Post
    How do you use the G41 command?
    I have tried a few different kinds of CAM software and because I am new to each one I am struggling. How do i change the G-code if I want to use a 1/8"bit?
    here is the G-code, how should it look with the G41 command added to it?
    N5 (File Name = large gear on Monday, September 24, 2012)
    N10 (Default Mill Post)
    N15 G91.1
    N20 G0 Z1.0000
    N25 M3
    N30 X17.3749 Y36.7433
    N35 G1 Z0.0000 F60.00
    N40 G42
    N45 X16.8051 Y36.2685
    N50 X16.2354 Y35.6988
    N55 X15.9507 Y35.4141
    N60 X15.7608 Y35.0342
    N65 X15.4759 Y34.6544
    N70 X15.2860 Y34.2746
    N75 G40
    N80 X14.9063 Y33.4203
    N85 G0 Z1.0000
    N90 X41.2058 Y16.5202
    N95 G1 Z0.0000
    N100 G42
    N105 X40.3512 Y15.0011
    N110 G0 Z1.0000
    N115 X41.2058 Y16.5202
    N120 Z0.0000
    N125 G1 X41.3008 Y16.6152
    N130 Y16.7100
    N135 X41.2058 Y16.8051
    N140 X40.8260 Y17.0898
    N145 X40.3512 Y17.2797
    N150 X39.9714 Y17.5646
    N155 X39.5917 Y17.8493
    N160 X39.2119 Y18.0392
    N165 X38.8322 Y18.3241
    N170 X38.4524 Y18.6090
    N175 X38.0726 Y18.8938
    N180 G0 Z1.0000
    N185 X37.6929 Y18.7989
    N190 Z0.0000
    N195 G1 X37.8828 Y18.8938
    N200 X37.9776
    N205 X38.0726
    N210 G0 Z1.0000
    N215 X37.6929 Y18.7989
    N220 Z0.0000
    N225 G1 X36.6484 Y17.3747
    N230 X36.4586 Y17.0898
    N235 X35.6990 Y16.2354
    N240 X35.3193 Y16.0454
    N245 X35.0344 Y15.7606
    N250 X34.6546 Y15.5708
    N255 X34.2748 Y15.2858
    N260 X33.8951 Y15.0960
    N265 X33.4203 Y15.0011
    N270 X33.3254 Y15.0960
    N275 X33.2304 Y15.1910
    N280 X33.1356
    N285 X32.9457 Y15.2858
    N290 X32.8506 Y15.3809
    N295 X32.7558 Y15.4757
    N300 X32.6608 Y15.5708
    N305 X32.4709 Y15.6656
    N310 G0 Z1.0000
    N315 X33.8000 Y19.4634
    N320 Z0.0000
    N325 G1 X33.6102 Y19.1787
    N330 X33.4203 Y18.8938
    N335 X33.2304 Y18.5140
    N340 X33.0405 Y18.1342
    N345 X32.8506 Y17.7545
    N350 Y17.4696
    N355 X32.6608 Y16.9950
    N360 X32.5659 Y16.5202
    N365 Y16.1404
    N370 X32.4709 Y15.6656
    N375 G0 Z1.0000
    N380 X34.8445 Y20.8876
    N385 Z0.0000
    N390 G1 X33.8000 Y19.4634
    N395 G0 Z1.0000
    N400 X34.8445 Y20.8876
    N405 Z0.0000
    N410 G1 Y20.9826
    N415 Y21.1725
    N420 X34.7496 Y21.2674
    N425 X34.3699 Y21.5523
    N430 X34.0850 Y21.8370
    N435 X33.3254 Y22.4066
    N440 X32.9457 Y22.6916
    N445 X32.5659 Y22.9763
    N450 X32.2810 Y23.2612
    N455 X31.9012 Y23.5461
    N460 G0 Z1.0000
    N465 X31.6165
    N470 Z0.0000
    N475 G1 Y23.6410
    N480 X31.8064
    N485 X31.9012 Y23.5461
    N490 G0 Z1.0000
    N495 X31.6165
    N500 Z0.0000
    N505 G1 X30.4770 Y22.2168
    N510 X30.0973 Y21.9320
    N515 X29.5276 Y21.4572
    N520 X29.2429 Y21.2674
    N525 X28.9580 Y20.9826
    N530 X28.1985 Y20.6027
    N535 X27.7237 Y20.5078
    N540 X27.3439 Y20.3180
    N545 X26.8693 Y20.2229
    N550 X26.7743 Y20.3180
    N555 X26.6792 Y20.4128
    N560 X26.3945 Y20.6977
    N565 X26.2046 Y20.7926
    N570 X26.0148 Y20.9826
    N575 G0 Z1.0000
    N580 X27.7237 Y24.6854
    N585 Z0.0000
    N590 G1 X27.4390 Y24.4005
    N595 X27.2491 Y24.0207
    N600 X27.0592 Y23.7360
    N605 X26.8693 Y23.3562
    N610 X26.6792 Y23.0713
    N615 X26.4894 Y22.6916
    N620 X26.2995 Y22.3118
    N625 X26.2046 Y21.8370
    N630 X26.1096 Y21.4572
    N635 X26.0148 Y20.9826
    N640 G0 Z1.0000
    N645 X28.8630 Y25.9197
    N650 Z0.0000
    N655 G1 X27.7237 Y24.6854
    N660 G0 Z1.0000
    N665 X28.8630 Y25.9197
    N670 Z0.0000
    N675 G1 X28.9580 Y26.0146
    N680 Y26.1096
    N685 Y26.2044
    N690 X28.8630 Y26.2995
    N695 X27.9136 Y27.2489
    N700 X27.5338 Y27.5336
    N705 X26.8693 Y28.1983
    N710 X26.5844 Y28.5780
    N715 X26.2046 Y28.9578
    N720 G0 Z1.0000
    N725 X26.0148
    N730 Z0.0000
    N735 G1 X26.1096
    N740 X26.2046
    N745 G0 Z1.0000
    N750 X26.0148
    N755 Z0.0000
    N760 G1 X24.5906 Y27.7235
    N765 X24.0209 Y27.2489
    N770 X23.7360 Y27.0590
    N775 X23.3562 Y26.8691
    N780 X23.0715 Y26.6792
    N785 X22.6918 Y26.4894
    N790 X21.8372 Y26.2044
    N795 X21.3624 Y26.1096
    N800 X20.9826
    N805 X20.6029 Y26.3943
    N810 X20.5080 Y26.4894
    N815 X20.2231 Y26.7741
    N820 X20.1283 Y26.9640
    N825 G0 Z1.0000
    N830 X22.2170 Y30.3820
    N835 Z0.0000
    N840 G1 X21.6473 Y29.9072
    N845 X21.4574 Y29.6225
    N850 X21.2676 Y29.2427
    N855 X20.7928 Y28.5780
    N860 X20.6029 Y28.1983
    N865 X20.1283 Y26.9640
    N870 G0 Z1.0000
    N875 X23.5461 Y31.6163
    N880 Z0.0000
    N885 G1 X22.2170 Y30.3820
    N890 G0 Z1.0000
    N895 X23.5461 Y31.6163
    N900 Z0.0000
    N905 G1 X23.6412
    N910 Y31.7112
    N915 Y31.8062
    N920 Y31.9010
    N925 X22.9765 Y32.6606
    N930 X21.2676 Y34.7494
    N935 Y34.8443
    N940 G0 Z1.0000
    N945 X20.9826
    N950 Z0.0000
    N955 G1 Y34.9393
    N960 X21.0777
    N965 Y34.8443
    N970 X21.2676
    N975 G0 Z1.0000
    N980 X20.9826
    N985 Z0.0000
    N990 G1 X19.4636 Y33.8000
    N995 X19.1787 Y33.6102
    N1000 X18.8940 Y33.4203
    N1005 X18.5142 Y33.2304
    N1010 X18.1344 Y33.0405
    N1015 X17.7547 Y32.9455
    N1020 X17.3749 Y32.8506
    N1025 X16.9950 Y32.6606
    N1030 X16.5204
    N1035 X16.0456 Y32.5657
    N1040 X15.5710
    N1045 X15.0013 Y33.3252
    N1050 G40
    N1055 X14.9063 Y33.5151
    N1060 G0 Z1.0000
    N1065 X18.7989 Y37.7877
    N1070 G1 Z0.0000
    N1075 G42
    N1080 X17.3749 Y36.7433
    N1085 G0 Z1.0000
    N1090 X18.7989 Y37.7877
    N1095 Z0.0000
    N1100 G1 X18.8940
    N1105 Y37.8826
    N1110 Y38.0724
    N1115 X17.7547 Y39.5915
    N1120 X17.2799 Y40.3512
    N1125 X16.8051 Y41.1107
    N1130 Y41.2056
    N1135 G0 Z1.0000
    N1140 X16.5204 Y41.3006
    N1145 Z0.0000
    N1150 G1 X16.6152
    N1155 X16.7102
    N1160 X16.8051 Y41.2056
    N1165 G0 Z1.0000
    N1170 X16.5204 Y41.3006
    N1175 Z0.0000
    N1180 G1 X15.0013 Y40.3512
    N1185 X14.6214 Y40.2562
    N1190 X14.3366 Y40.0663
    N1195 X13.9569 Y39.8764
    N1200 X12.8176 Y39.5915
    N1205 X11.9630 Y39.4966
    N1210 X11.0136
    N1215 X10.4440 Y40.3512
    N1220 G40
    N1225 X10.3490 Y40.5411
    N1230 G0 Z1.0000
    N1235 X13.1974 Y43.4843
    N1240 G1 Z0.0000
    N1245 G42
    N1250 X12.8176 Y43.2944
    N1255 X12.5327 Y43.1046
    N1260 X12.2478 Y42.8196
    N1265 X11.9630 Y42.6298
    N1270 X11.6781 Y42.3450
    N1275 X11.4882 Y42.0601
    N1280 X11.1085 Y41.6804
    N1285 X10.6339 Y40.9208
    N1290 G40
    N1295 X10.4440 Y40.5411
    N1300 G0 Z1.0000
    N1305 X62.7580 Y7.6902
    N1310 G1 Z0.0000
    N1315 G42
    N1320 X62.3783 Y5.8865
    N1325 G0 Z1.0000
    N1330 X62.7580 Y7.6902
    N1335 Z0.0000
    N1340 G1 Y7.7853
    N1345 X62.6630 Y7.9754
    N1350 X60.7642 Y8.4498
    N1355 X59.9096 Y8.6398
    N1360 X59.0553 Y8.9246
    N1365 X58.9602
    N1370 G0 Z1.0000
    N1375 X58.6755 Y8.7349
    N1380 Z0.0000
    N1385 G1 X58.7704 Y8.8295
    N1390 X58.8654 Y8.9246
    N1395 X58.9602
    N1400 G0 Z1.0000
    N1405 X58.6755 Y8.7349
    N1410 Z0.0000
    N1415 G1 X58.2007 Y7.1208
    N1420 X58.0108 Y6.7410
    N1425 X57.9158 Y6.3613
    N1430 X57.7261 Y5.9815
    N1435 X57.3464 Y5.3166
    N1440 X57.0614 Y5.0319
    N1445 X56.8716 Y4.6522
    N1450 X56.4918 Y4.3674
    N1455 X56.2069 Y4.0823
    N1460 X55.8271 Y3.7976
    N1465 X55.2575 Y3.9877
    N1470 X55.1624
    N1475 X54.6878 Y4.1774
    N1480 G0 Z1.0000
    N1485 X54.7827 Y8.1650
    N1490 Z0.0000
    N1495 G1 X54.4980 Y7.0258
    N1500 Y6.6460
    N1505 Y5.4117
    N1510 X54.6878 Y4.1774
    N1515 G0 Z1.0000
    N1520 X55.2575 Y9.8742
    N1525 Z0.0000
    N1530 G1 X54.7827 Y8.1650
    N1535 G0 Z1.0000
    N1540 X55.2575 Y9.8742
    N1545 Z0.0000
    N1550 G1 X55.3525 Y9.9692
    N1555 X55.2575
    N1560 Y10.0638
    N1565 X55.1624 Y10.1589
    N1570 X54.2130 Y10.4436
    N1575 X53.4535 Y10.8234
    N1580 X51.7446 Y11.4882
    N1585 X51.6496
    N1590 G0 Z1.0000
    N1595 X51.4597 Y11.3932
    N1600 Z0.0000
    N1605 G1 Y11.4882
    N1610 X51.5547
    N1615 X51.6496
    N1620 G0 Z1.0000
    N1625 X51.4597 Y11.3932
    N1630 Z0.0000
    N1635 G1 X50.7002 Y9.7791
    N1640 X50.1305 Y8.7349
    N1645 X49.8456 Y8.4498
    N1650 X49.3710 Y7.8803
    N1655 X49.0861 Y7.5006
    N1660 X48.7063 Y7.2158
    N1665 X48.4214 Y6.9307
    N1670 X47.9468 Y6.7410
    N1675 X47.8520
    N1680 X47.6619 Y6.8361
    N1685 X47.5670 Y6.9307
    N1690 X47.1873 Y7.0258
    N1695 X47.0922 Y7.1208
    N1700 X46.9024 Y7.2158
    N1705 G0 Z1.0000
    N1710 X47.3772 Y11.2031
    N1715 Z0.0000
    N1720 G1 X47.1873 Y10.8234
    N1725 X47.0922 Y10.5386
    N1730 X46.9024 Y9.7791
    N1735 X46.8075 Y9.0196
    N1740 Y8.5448
    N1745 Y8.0700
    N1750 Y7.5956
    N1755 X46.9024 Y7.2158
    N1760 G0 Z1.0000
    N1765 X48.1367 Y12.8174
    N1770 Z0.0000
    N1775 G1 X47.3772 Y11.2031
    N1780 G0 Z1.0000
    N1785 X48.1367 Y12.8174
    N1790 Z0.0000
    N1795 G1 Y13.0073
    N1800 X47.9468 Y13.1021
    N1805 X47.5670 Y13.2920
    N1810 X47.1873 Y13.4819
    N1815 X46.7125 Y13.7668
    N1820 X46.3327 Y13.9567
    N1825 X45.8581 Y14.1466
    N1830 X45.4784 Y14.3364
    N1835 X44.6238 Y14.8112
    N1840 G0 Z1.0000
    N1845 X44.3389 Y14.7162
    N1850 Z0.0000
    N1855 G1 X44.4339 Y14.8112
    N1860 X44.6238
    N1865 G0 Z1.0000
    N1870 X44.3389 Y14.7162
    N1875 Z0.0000
    N1880 G1 X43.4845 Y13.1972
    N1885 X43.1046 Y12.5325
    N1890 X42.8198 Y12.2478
    N1895 X41.9653 Y11.3932
    N1900 X41.6806 Y11.2031
    N1905 X41.3008 Y10.9184
    N1910 X40.9208 Y10.6337
    N1915 X40.4462 Y10.4436
    N1920 X39.5917 Y11.0134
    N1925 G40
    N1930 X39.4968 Y11.1085
    N1935 G0 Z1.0000
    N1940 Y11.0134
    N1945 G1 Z0.0000
    N1950 G42
    N1955 Y11.9628
    N1960 Y12.4376
    N1965 X39.5917 Y12.8174
    N1970 X39.7816 Y13.5769
    N1975 X39.9714 Y13.9567
    N1980 X40.2564 Y14.6214
    N1985 G40
    N1990 X40.3512 Y15.0011
    N1995 G0 Z1.0000
    N2000 X5.7916 Y77.9490
    N2005 G1 Z0.0000
    N2010 G42
    N2015 X5.9815 Y75.1957
    N2020 X6.0766 Y74.2461
    N2025 Y74.1512
    N2030 X5.9815 Y74.0562
    N2035 X5.8867
    N2040 G0 Z1.0000
    N2045 X4.0827 Y73.8663
    N2050 Z0.0000
    N2055 G1 X5.8867 Y74.0562
    N2060 G0 Z1.0000
    N2065 X0.3798 Y72.2522
    N2070 Z0.0000
    N2075 G1 X0.7597 Y72.5372
    N2080 X1.5192 Y73.0118
    N2085 X2.2788 Y73.3915
    N2090 X2.5635 Y73.4866
    N2095 X3.7030 Y73.7715
    N2100 X4.0827 Y73.8663
    N2105 G0 Z1.0000
    N2110 X0.3798 Y72.2522
    N2115 Z0.0000
    N2120 G1 Y71.9675
    N2125 X0.4748 Y71.7776
    N2130 Y71.4927
    N2135 Y71.3979
    N2140 Y71.1130
    N2145 X0.9496 Y70.8282
    N2150 X1.3294 Y70.7332
    N2155 X1.7091 Y70.5433
    N2160 X2.2788 Y70.4485
    N2165 X2.5635 Y70.3534
    N2170 X3.3232 Y70.2584
    N2175 X4.0827
    N2180 X4.4625
    N2185 X6.2664 Y70.4485
    N2190 G0 Z1.0000
    N2195 X6.4563 Y70.2584
    N2200 Z0.0000
    N2205 G1 Y70.3534
    N2210 X6.3613 Y70.4485
    N2215 X6.2664
    N2220 G0 Z1.0000
    N2225 X6.4563 Y70.2584
    N2230 Z0.0000
    N2235 G1 Y70.1636
    N2240 X6.8361 Y67.5050
    N2245 X7.0260 Y66.5556
    N2250 Y66.4608
    N2255 X6.9309 Y66.2707
    N2260 G0 Z1.0000
    N2265 X5.1270 Y65.8910
    N2270 Z0.0000
    N2275 G1 X6.9309 Y66.2707
    N2280 G0 Z1.0000
    N2285 X1.6141 Y63.8971
    N2290 Z0.0000
    N2295 G1 X1.9938 Y64.2771
    N2300 X2.6585 Y64.8467
    N2305 X3.0383 Y65.0366
    N2310 X3.3232 Y65.2265
    N2315 X3.7030 Y65.4164
    N2320 X4.0827 Y65.6062
    N2325 X4.4625 Y65.7013
    N2330 X4.7472 Y65.7961
    N2335 X5.1270 Y65.8910
    N2340 G0 Z1.0000
    N2345 X1.6141 Y63.8971
    N2350 Z0.0000
    N2355 G1 X1.7091 Y63.8023
    N2360 Y63.6124
    N2365 Y63.5174
    N2370 Y63.4225
    N2375 X1.8040 Y63.1376
    N2380 Y62.9477
    N2385 X1.8990 Y62.8529
    N2390 X2.2788 Y62.6630
    N2395 X2.7534 Y62.4731
    N2400 X3.1333 Y62.3781
    N2405 X3.6079
    N2410 X4.3674 Y62.2832
    N2415 X4.7472
    N2420 X5.1270
    N2425 X5.8867 Y62.3781
    N2430 X7.5956 Y62.7578
    N2435 G0 Z1.0000
    N2440 X7.8805 Y62.6630
    N2445 Z0.0000
    N2450 G1 Y62.7578
    N2455 X7.7855
    N2460 X7.5956
    N2465 G0 Z1.0000
    N2470 X7.8805 Y62.6630
    N2475 Z0.0000
    N2480 G1 Y62.5680
    N2485 X8.0704 Y61.7136
    N2490 X8.3551 Y60.7640
    N2495 X8.5450 Y59.9096
    N2500 X8.8299 Y59.0551
    N2505 X8.9248 Y58.9602
    N2510 X8.8299 Y58.8652
    N2515 Y58.7702
    N2520 X8.7349
    N2525 G0 Z1.0000
    N2530 X7.0260 Y58.2005
    N2535 Z0.0000
    N2540 G1 X8.7349 Y58.7702
    N2545 G0 Z1.0000
    N2550 X3.7030 Y55.8269
    N2555 Z0.0000
    N2560 G1 X3.9877 Y56.2069
    N2565 X4.6524 Y56.8714
    N2570 X5.0321 Y57.1563
    N2575 X5.3168 Y57.3462
    N2580 X5.6968 Y57.5360
    N2585 X5.9815 Y57.7259
    N2590 X6.3613 Y57.9158
    N2595 X6.7410 Y58.1057
    N2600 X7.0260 Y58.2005
    N2605 G0 Z1.0000
    N2610 X3.7030 Y55.8269
    N2615 Z0.0000
    N2620 G1 X3.9877 Y55.1624
    N2625 Y55.0674
    N2630 X4.0827 Y54.7827
    N2635 X4.5573 Y54.5928
    N2640 X5.0321 Y54.4978
    N2645 X5.4119
    N2650 X6.7410
    N2655 X7.4057 Y54.5928
    N2660 X7.7855 Y54.6876
    N2665 X8.1652 Y54.7827
    N2670 X9.8742 Y55.3523
    N2675 G0 Z1.0000
    N2680 X10.1591 Y55.1624
    N2685 Z0.0000
    N2690 G1 X9.9692 Y55.3523
    N2695 X9.8742
    N2700 G0 Z1.0000
    N2705 X10.0640 Y55.1624
    N2710 Z0.0000
    N2715 G1 X10.1591
    N2720 X10.4440 Y54.3079
    N2725 X10.7287 Y53.4533
    N2730 X11.1085 Y52.5990
    N2735 X11.4882 Y51.7444
    N2740 Y51.5545
    N2745 Y51.4597
    N2750 X11.2984 Y51.3646
    N2755 G0 Z1.0000
    N2760 X9.6843 Y50.7000
    N2765 Z0.0000
    N2770 G1 X11.2984 Y51.3646
    N2775 G0 Z1.0000
    N2780 X6.7410 Y48.0416
    N2785 Z0.0000
    N2790 G1 X7.0260 Y48.4214
    N2795 X7.2158 Y48.7061
    N2800 X7.5006 Y49.0861
    N2805 X7.7855 Y49.3708
    N2810 X8.0704 Y49.6555
    N2815 X8.4502 Y49.9404
    N2820 X8.7349 Y50.1303
    N2825 X9.3996 Y50.5101
    N2830 X9.6843 Y50.7000
    N2835 G0 Z1.0000
    N2840 X6.7410 Y48.0416
    N2845 Z0.0000
    N2850 G1 Y47.8518
    N2855 X6.8361 Y47.5668
    N2860 X6.9309 Y47.4720
    N2865 X7.0260 Y47.3770
    N2870 Y47.1871
    N2875 X7.1208 Y47.0922
    N2880 Y46.9972
    N2885 X7.5956 Y46.9022
    N2890 X8.0704 Y46.8073
    N2895 X8.9248
    N2900 X9.3996 Y46.9022
    N2905 X9.6843 Y46.9972
    N2910 X10.0640
    N2915 X10.4440 Y47.1871
    N2920 X10.8238 Y47.2821
    N2925 X11.2035 Y47.3770
    N2930 X12.8176 Y48.1365
    N2935 G0 Z1.0000
    N2940 X13.1023 Y48.0416
    N2945 Z0.0000
    N2950 G1 X13.0075 Y48.1365
    N2955 X12.9124
    N2960 X12.8176
    N2965 G0 Z1.0000
    N2970 X13.1023 Y48.0416
    N2975 Z0.0000
    N2980 G1 X13.2922 Y47.5668
    N2985 X13.4821 Y47.1871
    N2990 X13.6720 Y46.8073
    N2995 X13.9569 Y46.3325
    N3000 X14.1468 Y45.9528
    N3005 X14.3366 Y45.4782
    N3010 X14.5265 Y45.0984
    N3015 X14.8112 Y44.7186
    N3020 Y44.6236
    N3025 Y44.5286
    N3030 X14.7164 Y44.4337
    N3035 G40
    N3040 G0 Z1.0000
    N3045 X13.1974 Y43.4843
    N3050 Z0.0000
    N3055 G1 X14.7164 Y44.4337
    N3060 G0 Z1.0000
    N3065 X73.9616 Y5.8865
    N3070 G1 Z0.0000
    N3075 G42
    N3080 X73.7715 Y4.1774
    N3085 X73.6766 Y3.4178
    N3090 X73.5816 Y3.0381
    N3095 X73.4868 Y2.6583
    N3100 X73.2969 Y2.2786
    N3105 X73.2018 Y1.8988
    N3110 X72.9171 Y1.5190
    N3115 X72.8221 Y1.1393
    N3120 X72.2524 Y0.3798
    N3125 X71.2080 Y0.5694
    N3130 X71.0181
    N3135 G0 Z1.0000
    N3140 X70.2586 Y4.4625
    N3145 Z0.0000
    N3150 G1 X70.1638 Y4.0823
    N3155 Y3.3228
    N3160 X70.2586 Y2.5633
    N3165 X70.4485 Y2.1835
    N3170 X70.6384 Y1.3290
    N3175 X70.8282 Y0.9492
    N3180 X71.0181 Y0.5694
    N3185 G0 Z1.0000
    N3190 X70.4485 Y6.2662
    N3195 Z0.0000
    N3200 G1 X70.2586 Y4.4625
    N3205 G0 Z1.0000
    N3210 X70.4485 Y6.2662
    N3215 Z0.0000
    N3220 G1 Y6.3613
    N3225 Y6.4559
    N3230 X70.3536
    N3235 X70.2586
    N3240 Y6.5510
    N3245 X66.6507 Y7.1208
    N3250 X66.5558
    N3255 G0 Z1.0000
    N3260 X66.3660 Y6.9307
    N3265 Z0.0000
    N3270 G1 Y7.0258
    N3275 X66.4608 Y7.1208
    N3280 X66.5558
    N3285 G0 Z1.0000
    N3290 X66.3660 Y6.9307
    N3295 Z0.0000
    N3300 G1 X65.8912 Y5.2220
    N3305 X65.7963 Y4.8422
    N3310 X65.7013 Y4.4625
    N3315 X65.4166 Y3.7026
    N3320 X65.1316 Y3.0381
    N3325 X64.7519 Y2.6583
    N3330 X64.5620 Y2.3736
    N3335 X64.1822 Y1.9938
    N3340 X63.9924 Y1.7087
    N3345 X62.9479 Y1.8988
    N3350 G40
    N3355 X62.7580 Y1.9938
    N3360 G0 Z1.0000
    N3365 Y1.8988
    N3370 G1 Z0.0000
    N3375 G42
    N3380 X62.4733 Y2.7534
    N3385 X62.2832 Y3.6079
    N3390 Y3.9877
    N3395 Y5.2220
    N3400 Y5.6018
    N3405 G40
    N3410 X62.3783 Y5.8865
    N3415 G0 Z1.0000
    N3420 X62.7580 Y17.2797
    N3425 G1 Z0.0000
    N3430 G42
    N3435 X61.9035 Y17.5646
    N3440 X58.8654 Y18.5140
    N3445 X58.1059 Y18.7989
    N3450 X57.4412 Y19.0836
    N3455 X56.6817 Y19.2735
    N3460 X55.9222 Y19.6533
    N3465 X55.1624 Y19.9382
    N3470 X54.4980 Y20.2229
    N3475 X53.7384 Y20.5078
    N3480 X52.9789 Y20.8876
    N3485 X51.5547 Y21.5523
    N3490 X50.8900 Y21.9320
    N3495 X50.1305 Y22.2168
    N3500 X47.9468 Y23.3562
    N3505 X47.3772 Y23.8308
    N3510 X46.6176 Y24.2106
    N3515 X44.6238 Y25.4449
    N3520 X43.8643 Y25.9197
    N3525 X43.2944 Y26.2995
    N3530 X42.6300 Y26.7741
    N3535 X41.3008 Y27.7235
    N3540 X40.0665 Y28.6731
    N3545 X39.4018 Y29.1477
    N3550 X38.1675 Y30.1921
    N3555 X37.5978 Y30.7618
    N3560 X36.3637 Y31.8062
    N3565 X35.7939 Y32.2808
    N3570 X35.2242 Y32.8506
    N3575 X34.6546 Y33.4203
    N3580 X32.3760 Y35.6988
    N3585 X31.8064 Y36.2685
    N3590 X31.3316 Y36.8381
    N3595 X30.2872 Y38.0724
    N3600 X29.7175 Y38.6421
    N3605 X29.2429 Y39.3068
    N3610 X27.8187 Y41.2056
    N3615 X26.8693 Y42.5349
    N3620 X26.3945 Y43.1046
    N3625 X25.5400 Y44.4337
    N3630 X25.0654 Y45.0984
    N3635 X24.5906 Y45.8579
    N3640 X24.2108 Y46.5224
    N3645 X23.8310 Y47.1871
    N3650 X23.4513 Y47.8518
    N3655 X23.0715 Y48.6113
    N3660 X22.5967 Y49.2758
    N3665 X22.3120 Y49.9404
    N3670 X21.5523 Y51.3646
    N3675 X21.2676 Y52.1242
    N3680 X20.2231 Y54.3079
    N3685 X19.9384 Y55.0674
    N3690 X19.5584 Y55.8269
    N3695 X19.2737 Y56.4916
    N3700 X18.7041 Y58.0106
    N3705 X18.5142 Y58.7702
    N3710 X18.2293 Y59.5299
    N3715 X17.7547 Y61.0489
    N3720 X17.4698 Y61.8084
    N3725 X17.2799 Y62.5680
    N3730 G40
    N3735 Y62.7578
    N3740 G0 Z1.0000
    N3745 X63.0430 Y18.4190
    N3750 G1 Z0.0000
    N3755 G42
    N3760 X62.8531
    N3765 X62.0936 Y18.7039
    N3770 X61.3338 Y18.8938
    N3775 X59.8148 Y19.3686
    N3780 X59.0553 Y19.6533
    N3785 X58.3906 Y19.8432
    N3790 X57.6311 Y20.1281
    N3795 X56.8716 Y20.4128
    N3800 X56.2069 Y20.6977
    N3805 X54.6878 Y21.2674
    N3810 X51.1750 Y22.9763
    N3815 X50.4152 Y23.3562
    N3820 X49.7508 Y23.7360
    N3825 X49.0861 Y24.0207
    N3830 X48.4214 Y24.4955
    N3835 X47.7569 Y24.8753
    N3840 X46.9974 Y25.2550
    N3845 X45.6680 Y26.1096
    N3850 X45.0036 Y26.4894
    N3855 X44.3389 Y26.9640
    N3860 X43.7692 Y27.3437
    N3865 X43.1046 Y27.8185
    N3870 X42.4401 Y28.2933
    N3875 X41.7754 Y28.7679
    N3880 X39.3070 Y30.6669
    N3885 X38.7373 Y31.1415
    N3890 X38.1675 Y31.7112
    N3895 X37.5978 Y32.1860
    N3900 X36.9334 Y32.7556
    N3905 X35.7939 Y33.8000
    N3910 X34.1800 Y35.4141
    N3915 X33.6102 Y35.9838
    N3920 X33.1356 Y36.5534
    N3925 X31.9963 Y37.6927
    N3930 X31.5215 Y38.3574
    N3935 X30.9518 Y38.9270
    N3940 X30.0024 Y40.1613
    N3945 X29.5276 Y40.7310
    N3950 X28.5782 Y41.9651
    N3955 X28.1034 Y42.6298
    N3960 X27.6288 Y43.2944
    N3965 X27.2491 Y43.9589
    N3970 X26.7743 Y44.5286
    N3975 X25.9197 Y45.8579
    N3980 X25.5400 Y46.5224
    N3985 X25.0654 Y47.1871
    N3990 X24.6856 Y47.9466
    N3995 X24.3056 Y48.6113
    N4000 X23.9259 Y49.2758
    N4005 X23.5461 Y49.9404
    N4010 X23.1664 Y50.6051
    N4015 X22.7866 Y51.3646
    N4020 X21.1725 Y54.8775
    N4025 X20.8878 Y55.6370
    N4030 X20.6029 Y56.3966
    N4035 X20.0332 Y57.8208
    N4040 X19.7485 Y58.5805
    N4045 X19.4636 Y59.3400
    N4050 X19.2737 Y60.0045
    N4055 X18.6090 Y62.2832
    N4060 G40
    N4065 X18.3243 Y63.0428
    N4070 G0 Z1.0000
    N4075 X74.2463 Y6.0762
    N4080 G1 Z0.0000
    N4085 G42
    N4090 X74.1512
    N4095 X74.0564 Y5.9815
    N4100 X73.9616
    N4105 G40
    N4110 Y5.8865
    N4115 G0 Z1.0000
    N4120 X85.9242
    N4125 G1 Z0.0000
    N4130 G42
    N4135 X86.1143 Y4.0823
    N4140 G0 Z1.0000
    N4145 X85.9242 Y5.8865
    N4150 Z0.0000
    N4155 G1 Y5.9815
    N4160 X85.8296 Y6.0762
    N4165 X85.7345
    N4170 X84.7849
    N4175 X82.0316 Y5.8865
    N4180 X81.9369
    N4185 G0 Z1.0000
    N4190 X81.7468 Y5.6964
    N4195 Z0.0000
    N4200 G1 Y5.7914
    N4205 X81.8419 Y5.8865
    N4210 X81.9369
    N4215 G0 Z1.0000
    N4220 X81.7468 Y5.6964
    N4225 Z0.0000
    N4230 G1 Y4.3674
    N4235 Y3.8926
    N4240 Y3.5129
    N4245 Y2.7534
    N4250 X81.3671 Y1.6141
    N4255 X81.1770 Y1.2343
    N4260 X80.9873 Y0.8546
    N4265 X80.7972 Y0.3798
    N4270 X80.5125 Y0.0000
    N4275 X79.3732
    N4280 G0 Z1.0000
    N4285 X78.1389 Y3.8926
    N4290 Z0.0000
    N4295 G1 X78.2340 Y3.5129
    N4300 Y3.1331
    N4305 Y2.7534
    N4310 X78.4236 Y1.9938
    N4315 X78.6137 Y1.6141
    N4320 X78.7088 Y1.2343
    N4325 X78.8984 Y0.8546
    N4330 X79.1836 Y0.3798
    N4335 X79.3732 Y0.0000
    N4340 G0 Z1.0000
    N4345 X78.1389 Y5.6964
    N4350 Z0.0000
    N4355 G1 Y4.2724
    N4360 Y3.8926
    N4365 G0 Z1.0000
    N4370 Y5.6964
    N4375 Z0.0000
    N4380 G1 Y5.7914
    N4385 X78.0439 Y5.8865
    N4390 X77.9492
    N4395 X76.9996 Y5.9815
    N4400 X74.3413 Y6.0762
    N4405 G40
    N4410 X74.2463 Y6.1712
    N4415 G0 Z1.0000
    N4420 X5.8867 Y77.9490
    N4425 G1 Z0.0000
    N4430 G42
    N4435 Y78.0439
    N4440 X5.7916 Y78.1387
    N4445 X5.6968 Y78.2338
    N4450 G40
    N4455 X5.6018
    N4460 G0 Z1.0000
    N4465 X14.7164 Y115.3568
    N4470 G1 Z0.0000
    N4475 G42
    N4480 Y115.2620
    N4485 X13.8618 Y113.6479
    N4490 X13.4821 Y112.7933
    N4495 X13.1023 Y111.9390
    N4500 X13.0075
    N4505 X12.9124 Y111.8439
    N4510 X12.8176
    N4515 G0 Z1.0000
    N4520 X11.2035 Y112.6034
    N4525 Z0.0000
    N4530 G1 X12.8176 Y111.8439
    N4535 G0 Z1.0000
    N4540 X7.1208 Y113.0782
    N4545 Z0.0000
    N4550 G1 X7.5956
    N4555 X8.0704 Y113.1733
    N4560 X8.9248
    N4565 X9.6843 Y113.0782
    N4570 X10.4440 Y112.8884
    N4575 X10.8238 Y112.6985
    N4580 X11.2035 Y112.6034
    N4585 G0 Z1.0000
    N4590 X7.1208 Y113.0782
    N4595 Z0.0000
    N4600 G1 X7.0260 Y112.7933
    N4605 Y112.6985
    N4610 X6.9309 Y112.5086
    N4615 X6.8361 Y112.2237
    N4620 X6.7410 Y112.1288
    N4625 Y112.0338
    N4630 X7.2158 Y111.2743
    N4635 X7.5006 Y110.8945
    N4640 X7.7855 Y110.6096
    N4645 X8.0704 Y110.3249
    N4650 X8.4502 Y110.0400
    N4655 X8.7349 Y109.8501
    N4660 X9.1146 Y109.6602
    N4665 X9.3996 Y109.4703
    N4670 X9.6843 Y109.2804
    N4675 X11.2984 Y108.6158
    N4680 G0 Z1.0000
    N4685 X11.4882 Y108.3310
    N4690 Z0.0000
    N4695 G1 Y108.5209
    N4700 X11.2984 Y108.6158
    N4705 G0 Z1.0000
    N4710 X11.4882 Y108.3310
    N4715 Z0.0000
    N4720 G1 Y108.2360
    N4725 X10.7287 Y106.5271
    N4730 X10.4440 Y105.6725
    N4735 X10.1591 Y104.8182
    N4740 X10.0640
    N4745 Y104.7231
    N4750 X9.9692
    N4755 X9.8742 Y104.6283
    N4760 G0 Z1.0000
    N4765 X8.1652 Y105.1979
    N4770 Z0.0000
    N4775 G1 X9.8742 Y104.6283
    N4780 G0 Z1.0000
    N4785 X4.0827 Y105.2928
    N4790 Z0.0000
    N4795 G1 X4.5573 Y105.3878
    N4800 X5.0321 Y105.4826
    N4805 X5.8867 Y105.5777
    N4810 X6.2664
    N4815 X6.7410 Y105.4826
    N4820 X7.4057 Y105.3878
    N4825 X7.7855 Y105.2928
    N4830 X8.1652 Y105.1979
    N4835 G0 Z1.0000
    N4840 X4.0827 Y105.2928
    N4845 Z0.0000
    N4850 G1 X3.8928 Y104.5332
    N4855 X3.7978 Y104.4384
    N4860 X3.7030 Y104.1535
    N4865 X4.0827 Y103.7737
    N4870 X4.3674 Y103.4888
    N4875 X5.0321 Y102.9192
    N4880 X5.6968 Y102.4446
    N4885 X5.9815 Y102.2547
    N4890 X6.7410 Y101.9698
    N4895 X7.0260 Y101.7799
    N4900 X8.7349 Y101.3053
    N4905 G0 Z1.0000
    N4910 X8.8299 Y101.0204
    N4915 Z0.0000
    N4920 G1 X8.9248
    N4925 X8.8299 Y101.1152
    N4930 Y101.2102
    N4935 X8.7349 Y101.3053
    N4940 G0 Z1.0000
    N4945 X8.8299 Y101.0204
    N4950 Z0.0000
    N4955 G1 Y100.9253
    N4960 X8.5450 Y100.0710
    N4965 X8.3551 Y99.2164
    N4970 X8.0704 Y98.2670
    N4975 X7.8805 Y97.4124
    N4980 Y97.3176
    N4985 X7.7855 Y97.2226
    N4990 X7.6904
    N4995 X7.5956
    N5000 G0 Z1.0000
    N5005 X5.8867 Y97.6023
    N5010 Z0.0000
    N5015 G1 X7.5956 Y97.2226
    N5020 G0 Z1.0000
    N5025 X1.8990
    N5030 Z0.0000
    N5035 G1 X2.7534 Y97.5075
    N5040 X3.1333 Y97.6023
    N5045 X3.6079 Y97.6974
    N5050 X3.9877
    N5055 X4.7472
    N5060 X5.8867 Y97.6023
    N5065 G0 Z1.0000
    N5070 X1.8990 Y97.2226
    N5075 Z0.0000
    N5080 G1 X1.8040 Y97.0327
    N5085 Y96.9378
    N5090 Y96.7478
    N5095 Y96.6529
    N5100 X1.7091 Y96.3680
    N5105 Y96.1781
    N5110 X1.6141 Y96.0833
    N5115 X1.9938 Y95.7035
    N5120 X2.2788 Y95.4186
    N5125 X2.6585 Y95.1339
    N5130 X3.0383 Y94.9440
    N5135 X3.4180 Y94.7539
    N5140 X3.7030 Y94.5642
    N5145 X4.0827 Y94.3742
    N5150 X4.4625 Y94.2793
    N5155 X4.8422 Y94.1845
    N5160 X5.1270 Y94.0894
    N5165 X6.9309 Y93.7097
    N5170 G0 Z1.0000
    N5175 X7.0260 Y93.4248
    N5180 Z0.0000
    N5185 G1 Y93.5198
    N5190 Y93.6146
    N5195 Y93.7097
    N5200 X6.9309
    N5205 G0 Z1.0000
    N5210 X7.0260 Y93.4248
    N5215 Z0.0000
    N5220 G1 Y93.3299
    N5225 X6.5512 Y90.6714
    N5230 X6.4563 Y89.7220
    N5235 X6.3613 Y89.6270
    N5240 X6.2664 Y89.5321
    N5245 G0 Z1.0000
    N5250 X4.4625 Y89.7220
    N5255 Z0.0000
    N5260 G1 X6.2664 Y89.5321
    N5265 G0 Z1.0000
    N5270 X0.4748 Y88.9625
    N5275 Z0.0000
    N5280 G1 X1.3294 Y89.3422
    N5285 X1.7091 Y89.4373
    N5290 X2.1837 Y89.6270
    N5295 X2.5635
    N5300 X2.9432 Y89.7220
    N5305 X3.3232
    N5310 X3.7030 Y89.8170
    N5315 X4.0827 Y89.7220
    N5320 X4.4625
    N5325 G0 Z1.0000
    N5330 X0.4748 Y88.9625
    N5335 Z0.0000
    N5340 G1 Y88.6776
    N5345 Y88.4877
    N5350 Y88.2030
    N5355 X0.3798 Y88.1079
    N5360 Y87.8232
    N5365 X0.7597 Y87.5383
    N5370 X1.1395 Y87.2534
    N5375 X1.5192 Y86.9686
    N5380 X1.8990 Y86.7788
    N5385 X2.6585 Y86.4938
    N5390 X2.9432 Y86.3990
    N5395 X3.3232 Y86.3040
    N5400 X4.0827 Y86.2091
    N5405 X5.8867 Y86.0192
    N5410 G0 Z1.0000
    N5415 X6.0766 Y85.7343
    N5420 Z0.0000
    N5425 G1 Y85.8294
    N5430 X5.9815 Y85.9242
    N5435 X5.8867 Y86.0192
    N5440 G0 Z1.0000
    N5445 X6.0766 Y85.7343
    N5450 Z0.0000
    N5455 G1 X5.9815 Y85.6395
    N5460 X5.8867 Y82.9810
    N5465 Y82.0316
    N5470 Y81.9365
    N5475 X5.6968 Y81.8417
    N5480 X5.6018 Y81.7466
    N5485 G0 Z1.0000
    N5490 X3.8928
    N5495 Z0.0000
    N5500 G1 X4.3674
    N5505 X5.6018
    N5510 G0 Z1.0000
    N5515 X0.0000 Y80.6074
    N5520 Z0.0000
    N5525 G1 X0.7597 Y81.0822
    N5530 X1.2343 Y81.2720
    N5535 X1.9938 Y81.5568
    N5540 X2.3736 Y81.6518
    N5545 X2.7534
    N5550 X3.1333 Y81.7466
    N5555 X3.8928
    N5560 G0 Z1.0000
    N5565 X0.0000 Y80.6074
    N5570 Z0.0000
    N5575 G1 Y79.4681
    N5580 X0.7597 Y78.9933
    N5585 X1.2343 Y78.8034
    N5590 X1.6141 Y78.6135
    N5595 X2.7534 Y78.3288
    N5600 X3.5131 Y78.2338
    N5605 X3.8928
    N5610 X4.3674
    N5615 G40
    N5620 X5.6018
    N5625 G0 Z1.0000
    N5630 X18.1344 Y77.5693
    N5635 G1 Z0.0000
    N5640 X17.9446 Y77.8540
    N5645 X17.7547 Y78.0439
    N5650 X17.6596 Y78.2338
    N5655 X17.4698 Y78.5187
    N5660 X17.3749 Y78.8034
    N5665 X17.2799 Y79.0883
    N5670 Y79.3730
    N5675 X17.1848 Y79.5629
    N5680 Y79.8478
    N5685 Y80.1326
    N5690 X17.2799 Y80.9871
    N5695 X17.3749 Y81.2720
    N5700 X17.8495 Y82.0316
    N5705 X18.0394 Y82.2214
    N5710 X18.2293 Y82.4113
    N5715 X18.4192 Y82.6012
    N5720 X18.6090 Y82.7911
    N5725 X18.8940 Y82.9810
    N5730 X19.1787 Y83.0760
    N5735 X19.3686 Y83.1708
    N5740 X19.6535 Y83.2659
    N5745 X19.9384 Y83.3607
    N5750 X20.2231
    N5755 X20.5080
    N5760 X20.7928
    N5765 X21.0777
    N5770 X21.3624 Y83.2659
    N5775 X21.6473 Y83.1708
    N5780 X21.9320 Y83.0760
    N5785 X22.1221 Y82.9810
    N5790 X22.4068 Y82.7911
    N5795 X22.8816 Y82.4113
    N5800 X23.0715 Y82.2214
    N5805 X23.2614 Y82.0316
    N5810 X23.6412 Y81.2720
    N5815 X23.7360 Y80.9871
    N5820 X23.9259 Y80.1326
    N5825 Y79.9429
    N5830 X23.7360 Y79.0883
    N5835 X23.6412 Y78.8034
    N5840 Y78.5187
    N5845 X23.4513 Y78.2338
    N5850 X23.3562 Y78.0439
    N5855 X23.0715 Y77.8540
    N5860 X22.8816 Y77.5693
    N5865 X22.6918 Y77.3792
    N5870 X22.5019 Y77.2844
    N5875 X22.2170 Y77.0945
    N5880 X21.9320 Y76.9994
    N5885 X21.7422 Y76.8096
    N5890 X21.4574 Y76.7147
    N5895 X21.1725
    N5900 X20.9826 Y76.6197
    N5905 X20.3182
    N5910 X19.4636 Y76.8096
    N5915 X19.1787 Y76.9046
    N5920 X18.7041 Y77.1893
    N5925 X18.4192 Y77.3792
    N5930 X18.1344 Y77.5693
    N5935 G0 Z1.0000
    N5940 X27.0592 Y75.4804
    N5945 G1 Z0.0000
    N5950 G42
    N5955 Y74.6258
    N5960 X26.9642
    N5965 G40
    N5970 Y74.4360
    N5975 G0 Z1.0000
    N5980 X70.5435 Y69.2142
    N5985 G1 Z0.0000
    N5990 G42
    N5995 X70.6384 Y69.3090
    N6000 X70.7334 Y69.4040
    N6005 X70.8282 Y69.4989
    N6010 Y69.5939
    N6015 X70.9233
    N6020 G0 Z1.0000
    N6025 X70.5435 Y69.2142
    N6030 Z0.0000
    N6035 G1 X70.7334 Y68.9292
    N6040 X71.0181 Y68.7394
    N6045 X71.3030 Y68.4546
    N6050 X71.4929 Y68.1697
    N6055 X71.7776 Y67.9798
    N6060 X71.9677 Y67.6001
    N6065 X72.2524 Y67.3152
    N6070 X72.6322 Y66.7455
    N6075 X72.8221 Y66.4608
    N6080 X73.1070 Y65.9860
    N6085 X73.2969 Y65.5112
    N6090 X73.5816 Y64.9416
    N6095 X73.7715 Y64.4670
    N6100 X73.9616 Y63.8971
    N6105 X74.0564 Y63.2326
    N6110 X74.2463 Y62.5680
    N6115 X74.3413 Y61.9983
    N6120 Y61.3338
    N6125 Y60.7640
    N6130 G0 Z1.0000
    N6135 X73.7715 Y67.0304
    N6140 Z0.0000
    N6145 G1 X73.2018 Y67.6001
    N6150 X72.6322 Y68.1697
    N6155 X71.7776 Y68.9292
    N6160 X71.3030 Y69.2142
    N6165 X70.9233 Y69.5939
    N6170 G0 Z1.0000
    N6175 X74.3413 Y60.7640
    N6180 Z0.0000
    N6185 G1 Y43.8641
    N6190 Y27.0590
    N6195 G0 Z1.0000
    N6200 X62.7580 Y17.2797
    N6205 Z0.0000
    N6210 G1 Y17.4696
    N6215 X62.8531 Y17.6594
    N6220 Y17.7545
    N6225 Y17.8493
    N6230 Y17.9444
    N6235 X62.9479 Y18.0392
    N6240 Y18.1342
    N6245 Y18.2291
    N6250 X63.0430 Y18.3241
    N6255 G0 Z1.0000
    N6260 X75.4806 Y27.0590
    N6265 Z0.0000
    N6270 G1 X74.3413
    N6275 Y26.5842
    N6280 Y26.1096
    N6285 X74.2463 Y25.6348
    N6290 X74.1512 Y25.0652
    N6295 X73.9616 Y24.4955
    N6300 X73.7715 Y23.9259
    N6305 X73.5816 Y23.3562
    N6310 X73.2969 Y22.7864
    N6315 X72.6322 Y21.7422
    N6320 X71.8727 Y20.7926
    N6325 X71.4929 Y20.4128
    N6330 X70.5435 Y19.6533
    N6335 X69.9739 Y19.3686
    N6340 X69.4991 Y18.9888
    N6345 X68.9294 Y18.7989
    N6350 X68.3598 Y18.5140
    N6355 X67.7902 Y18.3241
    N6360 X67.2205 Y18.2291
    N6365 X66.6507 Y18.1342
    N6370 X65.9862 Y18.0392
    N6375 X64.7519
    N6380 X64.1822 Y18.1342
    N6385 X63.6126 Y18.2291
    N6390 X63.0430 Y18.3241
    N6395 G0 Z1.0000
    N6400 X75.4806 Y60.7640
    N6405 Z0.0000
    N6410 G1 Y61.2388
    N6415 Y61.8084
    N6420 X75.3856 Y62.2832
    N6425 X75.2907 Y62.9477
    N6430 X75.1957 Y63.7074
    N6435 X75.0058 Y64.2771
    N6440 X74.8159 Y64.8467
    N6445 X74.6260 Y65.4164
    N6450 X74.3413 Y65.9860
    N6455 X74.0564 Y66.5556
    N6460 X73.7715 Y67.0304
    N6465 G0 Z1.0000
    N6470 X75.4806 Y27.0590
    N6475 Z0.0000
    N6480 G1 Y49.5607
    N6485 Y58.5805
    N6490 Y60.7640
    N6495 G0 Z1.0000
    N6500 X62.7580 Y17.2797
    N6505 Z0.0000
    N6510 G1 X63.2328 Y17.1848
    N6515 X63.7074 Y17.0898
    N6520 X64.1822 Y16.9950
    N6525 X64.7519
    N6530 X65.3215
    N6535 X65.8912
    N6540 X66.4608
    N6545 X67.0304 Y17.0898
    N6550 X67.6003 Y17.1848
    N6555 X68.1699 Y17.3747
    N6560 X68.7396 Y17.4696
    N6565 X69.2144 Y17.7545
    N6570 X69.7838 Y17.9444
    N6575 X70.2586 Y18.2291
    N6580 X70.7334 Y18.5140
    N6585 X71.2080 Y18.7989
    N6590 X72.1574 Y19.4634
    N6595 X72.9171 Y20.3180
    N6600 X73.2969 Y20.6977
    N6605 X73.9616 Y21.6471
    N6610 X74.2463 Y22.1219
    N6615 X74.9110 Y23.7360
    N6620 X75.1008 Y24.2106
    N6625 X75.3856 Y25.3499
    N6630 X75.4806 Y26.4894
    N6635 G40
    N6640 Y27.0590
    N6645 G0 Z1.0000
    N6650 X87.7284 Y0.3798
    N6655 G1 Z0.0000
    N6660 G42
    N6665 X87.4436 Y0.7595
    N6670 X86.7788 Y1.8988
    N6675 X86.5891 Y2.2786
    N6680 X86.4940 Y2.6583
    N6685 X86.2093 Y3.7976
    N6690 G40
    N6695 X86.1143 Y4.0823
    N6700 G0 Z1.0000
    N6705 X118.6802 Y16.5202
    N6710 G1 Z0.0000
    N6715 G42
    N6720 X119.6294 Y15.0011
    N6725 X119.7244 Y14.6214
    N6730 X120.0092 Y13.9567
    N6735 X120.1992 Y13.5769
    N6740 X120.3889 Y12.8174
    N6745 Y12.4376
    N6750 X120.4840 Y11.9628
    N6755 Y11.0134
    N6760 X120.2943 Y10.9184
    N6765 X120.1992
    N6770 X120.1042 Y10.8234
    N6775 X119.9145 Y10.7287
    N6780 X119.8195 Y10.6337
    N6785 X119.7244
    N6790 X119.6294 Y10.5386
    N6795 X119.4397 Y10.4436
    N6800 G0 Z1.0000
    N6805 X116.4963 Y13.1972
    N6810 Z0.0000
    N6815 G1 X116.6864 Y12.9122
    N6820 X116.8760 Y12.5325
    N6825 X117.3508 Y11.9628
    N6830 X117.9207 Y11.3932
    N6835 X118.3004 Y11.1085
    N6840 X119.0600 Y10.6337
    N6845 X119.4397 Y10.4436
    N6850 G0 Z1.0000
    N6855 X115.5471 Y14.7162
    N6860 Z0.0000
    N6865 G1 X116.4963 Y13.1972
    N6870 G0 Z1.0000
    N6875 X115.5471 Y14.7162
    N6880 Z0.0000
    N6885 G1 Y14.8112
    N6890 X115.2620
    N6895 X114.8822 Y14.6214
    N6900 X114.5024 Y14.3364
    N6905 X114.0276 Y14.1466
    N6910 X113.6479 Y13.9567
    N6915 X113.1735 Y13.7668
    N6920 X112.7937 Y13.4819
    N6925 X112.4140 Y13.2920
    N6930 X111.9392 Y13.1021
    N6935 G0 Z1.0000
    N6940 X111.8441 Y12.8174
    N6945 Z0.0000
    N6950 G1 Y13.0073
    N6955 X111.9392 Y13.1021
    N6960 G0 Z1.0000
    N6965 X111.8441 Y12.8174
    N6970 Z0.0000
    N6975 G1 X112.6036 Y11.2031
    N6980 X112.6987 Y10.8234
    N6985 X112.7937 Y10.5386
    N6990 X113.1735 Y9.3994
    N6995 Y9.0196
    N7000 Y8.5448
    N7005 Y8.0700
    N7010 Y7.5956
    N7015 X112.9834 Y7.2158
    N7020 X112.8884 Y7.1208
    N7025 X112.7937 Y7.0258
    N7030 X112.3189 Y6.9307
    N7035 X112.2239 Y6.8361
    N7040 X111.9392 Y6.7410
    N7045 G0 Z1.0000
    N7050 X109.2804 Y9.7791
    N7055 Z0.0000
    N7060 G1 X109.4705 Y9.3994
    N7065 X109.8503 Y8.7349
    N7070 X110.1350 Y8.4498
    N7075 X110.3251 Y8.1650
    N7080 X110.6098 Y7.8803
    N7085 X110.8945 Y7.5006
    N7090 X111.1796 Y7.2158
    N7095 X111.5594 Y6.9307
    N7100 X111.9392 Y6.7410
    N7105 G0 Z1.0000
    N7110 X108.5209 Y11.3932
    N7115 Z0.0000
    N7120 G1 X109.2804 Y9.7791
    N7125 G0 Z1.0000
    N7130 X108.5209 Y11.3932
    N7135 Z0.0000
    N7140 G1 X108.4263 Y11.4882
    N7145 X108.3312
    N7150 X108.2362
    N7155 X106.5271 Y10.8234
    N7160 X105.6729 Y10.5386
    N7165 X104.8184 Y10.1589
    N7170 G0 Z1.0000
    N7175 X104.6283 Y9.8742
    N7180 Z0.0000
    N7185 G1 Y9.9692
    N7190 X104.7233 Y10.0638
    N7195 Y10.1589
    N7200 X104.8184
    N7205 G0 Z1.0000
    N7210 X104.6283 Y9.8742
    N7215 Z0.0000
    N7220 G1 X105.1981 Y8.1650
    N7225 X105.3878 Y7.7853
    N7230 Y7.4055
    N7235 X105.4828 Y7.1208
    N7240 Y6.6460
    N7245 Y5.5067
    N7250 Y5.0319
    N7255 X105.3878 Y4.5571
    N7260 X105.1981 Y4.0823
    N7265 X104.2485 Y3.7976
    N7270 X104.1535
    N7275 G0 Z1.0000
    N7280 X101.7799 Y7.0258
    N7285 Z0.0000
    N7290 G1 X101.8749 Y6.7410
    N7295 X102.0650 Y6.3613
    N7300 X102.6344 Y5.3166
    N7305 X102.8245 Y5.0319
    N7310 X103.1092 Y4.6522
    N7315 X103.4890 Y4.3674
    N7320 X103.7737 Y4.0823
    N7325 X104.1535 Y3.7976
    N7330 G0 Z1.0000
    N7335 X101.3055 Y8.7349
    N7340 Z0.0000
    N7345 G1 X101.7799 Y7.0258
    N7350 G0 Z1.0000
    N7355 X101.3055 Y8.7349
    N7360 Z0.0000
    N7365 G1 X101.1154 Y8.9246
    N7370 X100.9257
    N7375 X100.0712 Y8.6398
    N7380 X99.2166 Y8.4498
    N7385 X98.3620 Y8.1650
    N7390 X97.4124 Y7.9754
    N7395 X97.3178
    N7400 G0 Z1.0000
    N7405 X97.2228 Y7.6902
    N7410 Z0.0000
    N7415 G1 Y7.7853
    N7420 X97.3178 Y7.9754
    N7425 G0 Z1.0000
    N7430 X97.2228 Y7.6902
    N7435 Z0.0000
    N7440 G1 X97.5075 Y5.9815
    N7445 X97.6025 Y5.6018
    N7450 X97.6976 Y5.2220
    N7455 Y3.9877
    N7460 X97.6025 Y3.6079
    N7465 X97.4124 Y2.7534
    N7470 X97.1277 Y1.8988
    N7475 X96.8430 Y1.8038
    N7480 X96.7480
    N7485 X96.4632 Y1.7087
    N7490 X96.2732
    N7495 X96.1785
    N7500 X95.9884
    N7505 G0 Z1.0000
    N7510 X93.9946 Y5.2220
    N7515 Z0.0000
    N7520 G1 X94.1847 Y4.8422
    N7525 X94.2793 Y4.4625
    N7530 X94.3744 Y4.0823
    N7535 X94.5644 Y3.7026
    N7540 X94.6591 Y3.4178
    N7545 X94.8492 Y3.0381
    N7550 X95.1339 Y2.6583
    N7555 X95.4186 Y2.3736
    N7560 X95.7037 Y1.9938
    N7565 X95.9884 Y1.7087
    N7570 G0 Z1.0000
    N7575 X93.7099 Y6.9307
    N7580 Z0.0000
    N7585 G1 X93.9946 Y5.2220
    N7590 G0 Z1.0000
    N7595 X93.7099 Y6.9307
    N7600 Z0.0000
    N7605 G1 X93.6148 Y7.0258
    N7610 Y7.1208
    N7615 X93.4252
    N7620 X89.8172 Y6.5510
    N7625 X89.7222
    N7630 G0 Z1.0000
    N7635 X89.5321 Y6.2662
    N7640 Z0.0000
    N7645 G1 Y6.3613
    N7650 Y6.4559
    N7655 X89.6272
    N7660 X89.7222
    N7665 Y6.5510
    N7670 G0 Z1.0000
    N7675 X89.5321 Y6.2662
    N7680 Z0.0000
    N7685 G1 X89.7222 Y4.4625
    N7690 Y4.1774
    N7695 Y3.4178
    N7700 Y2.9430
    N7705 X89.6272 Y2.5633
    N7710 X89.5321 Y2.1835
    N7715 X89.2474 Y1.3290
    N7720 X89.0577 Y0.9492
    N7725 X88.8676 Y0.5694
    N7730 X87.9180 Y0.4748
    N7735 G40
    N7740 X87.7284
    N7745 G0 Z1.0000
    N7750 X70.9233 Y90.3867
    N7755 G1 Z0.0000
    N7760 G42
    N7765 X71.4929 Y90.8613
    N7770 X72.1574 Y91.4309
    N7775 X73.0120 Y92.1906
    N7780 X73.7715 Y92.9502
    N7785 G0 Z1.0000
    N7790 X69.5941 Y89.0573
    N7795 Z0.0000
    N7800 G1 X69.7838 Y89.2472
    N7805 X69.8788 Y89.4373
    N7810 X70.0687 Y89.5321
    N7815 X70.2586 Y89.7220
    N7820 X70.5435 Y90.1018
    N7825 X70.7334 Y90.1968
    N7830 X70.9233 Y90.3867
    N7835 G0 Z1.0000
    N7840 X67.0304 Y86.2091
    N7845 Z0.0000
    N7850 G1 X67.6003 Y86.7788
    N7855 X68.1699 Y87.3484
    N7860 X68.8344 Y88.2030
    N7865 X69.5941 Y89.0573
    N7870 G0 Z1.0000
    N7875 X17.2799 Y97.2226
    N7880 Z0.0000
    N7885 G1 X17.3749
    N7890 X17.4698
    N7895 X17.6596 Y97.1275
    N7900 X17.7547
    N7905 X17.9446 Y97.0327
    N7910 X18.0394
    N7915 X18.2293
    N7920 Y96.9378
    N7925 X18.3243
    N7930 G0 Z1.0000
    N7935 X27.0592 Y84.5000
    N7940 Z0.0000
    N7945 G1 Y85.3546
    N7950 X26.9642 Y85.4496
    N7955 Y85.6395
    N7960 X26.4894
    N7965 X26.1096
    N7970 X25.6350 Y85.7343
    N7975 X25.0654 Y85.8294
    N7980 X24.4007 Y86.0192
    N7985 X23.3562 Y86.3990
    N7990 X22.2170 Y86.9686
    N7995 X21.7422 Y87.3484
    N8000 X21.2676 Y87.6331
    N8005 X20.4130 Y88.4877
    N8010 X19.6535 Y89.4373
    N8015 X19.2737 Y90.0067
    N8020 X18.7041 Y91.0512
    N8025 X18.3243 Y92.1906
    N8030 X18.2293 Y92.7603
    N8035 X18.1344 Y93.3299
    N8040 X18.0394 Y93.9944
    N8045 Y95.1339
    N8050 X18.2293 Y96.3680
    N8055 X18.3243 Y96.9378
    N8060 G0 Z1.0000
    N8065 X60.7642 Y84.5000
    N8070 Z0.0000
    N8075 G1 X61.2390
    N8080 X62.1884 Y84.5950
    N8085 X62.9479 Y84.6901
    N8090 X63.6126 Y84.7849
    N8095 X64.2771 Y84.9748
    N8100 X64.8469 Y85.1647
    N8105 X65.9862 Y85.6395
    N8110 X67.0304 Y86.2091
    N8115 G0 Z1.0000
    N8120 X27.0592 Y84.5000
    N8125 Z0.0000
    N8130 G1 X49.5609
    N8135 X58.5805
    N8140 X60.7642
    N8145 G0 Z1.0000
    N8150 X17.2799 Y97.2226
    N8155 Z0.0000
    N8160 G1 X17.1848 Y96.7478
    N8165 X17.0900 Y96.2732
    N8170 X16.9950 Y95.7984
    N8175 X16.9001 Y94.6591
    N8180 X16.9950 Y94.0894
    N8185 Y93.5198
    N8190 X17.1848 Y92.3803
    N8195 X17.2799 Y91.8109
    N8200 X17.4698 Y91.2410
    N8205 X17.6596 Y90.7664
    N8210 X17.9446 Y90.1968
    N8215 X18.1344 Y89.7220
    N8220 X18.4192 Y89.2472
    N8225 X18.7989 Y88.7726
    N8230 X19.0838 Y88.2978
    N8235 X19.8434 Y87.4434
    N8240 X20.6979 Y86.6837
    N8245 X21.1725 Y86.3990
    N8250 X21.6473 Y86.0192
    N8255 X22.1221 Y85.7343
    N8260 X22.5967 Y85.4496
    N8265 X23.1664 Y85.2595
    N8270 X23.6412 Y85.0698
    N8275 X24.2108 Y84.8798
    N8280 X24.7804 Y84.7849
    N8285 X25.3501 Y84.5950
    N8290 X25.9197 Y84.5000
    N8295 X26.4894
    N8300 G40
    N8305 X27.0592
    N8310 G0 Z1.0000
    N8315 X85.5444 Y27.0590
    N8320 G1 Z0.0000
    N8325 G42
    N8330 X84.5002
    N8335 G0 Z1.0000
    N8340 X66.3660 Y87.1585
    N8345 G1 Z0.0000
    N8350 G42
    N8355 X66.4608
    N8360 Y87.0637
    N8365 X66.5558 Y86.9686
    N8370 Y86.8736
    N8375 X66.6507 Y86.7788
    N8380 Y86.6837
    N8385 X66.7457
    N8390 Y86.5889
    N8395 X66.8408 Y86.4938
    N8400 X67.0304 Y86.2091
    N8405 G0 Z1.0000
    N8410 X66.3660 Y87.1585
    N8415 Z0.0000
    N8420 G1 X65.4166 Y86.6837
    N8425 X64.9418 Y86.3990
    N8430 X64.4672 Y86.2091
    N8435 X63.8025 Y86.0192
    N8440 X62.6630 Y85.7343
    N8445 X61.9985 Y85.6395
    N8450 X61.3338
    N8455 X60.7642
    N8460 G0 Z1.0000
    N8465 Y84.5000
    N8470 Z0.0000
    N8475 G1 Y85.6395
    N8480 X43.8643
    N8485 G40
    N8490 X26.9642
    N8495 G0 Z1.0000
    N8500 X75.4806 Y60.7640
    N8505 G1 Z0.0000
    N8510 G42
    N8515 X74.5310
    N8520 G40
    N8525 X74.3413
    N8530 G0 Z1.0000
    N8535 X60.7642 Y74.4360
    N8540 G1 Z0.0000
    N8545 G42
    N8550 X61.2390 Y74.3411
    N8555 X61.8086
    N8560 X62.3783 Y74.2461
    N8565 X62.8531 Y74.1512
    N8570 X63.5176 Y74.0562
    N8575 X64.7519 Y73.6764
    N8580 X65.3215 Y73.3915
    N8585 X65.8912 Y73.1068
    N8590 X66.3660 Y72.8221
    N8595 X66.4608
    N8600 Y72.9169
    N8605 X66.5558 Y73.0118
    N8610 Y73.1068
    N8615 X66.6507 Y73.2018
    N8620 X66.7457 Y73.4866
    N8625 X66.8408 Y73.5816
    N8630 X67.0304 Y73.8663
    N8635 G0 Z1.0000
    N8640 X60.7642 Y74.4360
    N8645 Z0.0000
    N8650 G1 Y75.4804
    N8655 G0 Z1.0000
    N8660 X26.9642 Y74.4360
    N8665 Z0.0000
    N8670 G1 X43.8643
    N8675 X60.7642
    N8680 G0 Z1.0000
    N8685 X17.2799 Y62.7578
    N8690 Z0.0000
    N8695 G1 X17.4698 Y62.8529
    N8700 X17.6596
    N8705 X17.7547
    N8710 X17.8495
    N8715 X17.9446 Y62.9477
    N8720 X18.0394
    N8725 X18.1344
    N8730 X18.2293 Y63.0428
    N8735 X18.3243
    N8740 X18.2293 Y63.5174
    N8745 X18.1344 Y63.8971
    N8750 X18.0394 Y64.3719
    N8755 Y64.9416
    N8760 Y65.6062
    N8765 Y66.1759
    N8770 X18.1344 Y66.7455
    N8775 X18.2293 Y67.4102
    N8780 X18.4192 Y67.9798
    N8785 X18.6090 Y68.5495
    N8790 X19.0838 Y69.6888
    N8795 X19.3686 Y70.1636
    N8800 X19.7485 Y70.6382
    N8805 X20.5080 Y71.5878
    N8810 X20.9826 Y72.0624
    N8815 X21.8372 Y72.8221
    N8820 X22.4068 Y73.1068
    N8825 X22.8816 Y73.3915
    N8830 X23.4513 Y73.6764
    N8835 X24.0209 Y73.8663
    N8840 X24.5906 Y74.0562
    N8845 X25.1602 Y74.2461
    N8850 X25.8249 Y74.3411
    N8855 X26.3945
    N8860 X26.9642 Y74.4360
    N8865 G0 Z1.0000
    N8870 X27.0592 Y75.4804
    N8875 Z0.0000
    N8880 G1 X26.4894
    N8885 X25.4451 Y75.3854
    N8890 X24.9703 Y75.2905
    N8895 X24.4007 Y75.1957
    N8900 X23.8310 Y75.0056
    N8905 X23.3562 Y74.8157
    N8910 X22.7866 Y74.5310
    N8915 X22.3120 Y74.3411
    N8920 X21.7422 Y74.0562
    N8925 X21.2676 Y73.7715
    N8930 X20.8878 Y73.3915
    N8935 X20.4130 Y73.0118
    N8940 X19.5584 Y72.2522
    N8945 X19.1787 Y71.7776
    N8950 X18.8940 Y71.3979
    N8955 X18.6090 Y70.9231
    N8960 X18.2293 Y70.4485
    N8965 X17.9446 Y69.8786
    N8970 X17.7547 Y69.4040
    N8975 X17.5648 Y68.9292
    N8980 X17.3749 Y68.3596
    N8985 X17.1848 Y67.7900
    N8990 X16.9950 Y66.6507
    N8995 X16.9001 Y65.5112
    N9000 Y64.9416
    N9005 X16.9950 Y64.4670
    N9010 X17.1848 Y63.3277
    N9015 X17.2799 Y62.7578
    N9020 G0 Z1.0000
    N9025 X60.7642 Y75.4804
    N9030 Z0.0000
    N9035 G1 X38.2625
    N9040 X29.2429
    N9045 X27.0592
    N9050 G0 Z1.0000
    N9055 X67.0304 Y73.8663
    N9060 Z0.0000
    N9065 G1 X66.4608 Y74.1512
    N9070 X65.9862 Y74.3411
    N9075 X65.4166 Y74.6258
    N9080 X64.8469 Y74.8157
    N9085 X64.1822 Y75.0056
    N9090 X63.5176 Y75.1957
    N9095 X62.7580 Y75.3854
    N9100 X62.0936 Y75.4804
    N9105 X61.4289
    N9110 G40
    N9115 X60.7642
    N9120 G0 Z1.0000
    N9125 X63.0430 Y141.6565
    N9130 G1 Z0.0000
    N9135 G42
    N9140 X62.2832 Y141.4664
    N9145 X60.0047 Y140.7069
    N9150 X59.2452 Y140.5170
    N9155 X58.5805 Y140.2323
    N9160 X57.7261 Y139.9474
    N9165 X56.3019 Y139.3777
    N9170 X55.6372 Y139.0928
    N9175 X54.8777 Y138.8081
    N9180 X51.2698 Y137.1940
    N9185 X50.6053 Y136.8142
    N9190 X49.9406 Y136.4345
    N9195 X49.1811 Y136.0547
    N9200 X48.5164 Y135.6750
    N9205 X47.8520 Y135.2952
    N9210 X47.1873 Y134.9154
    N9215 X46.5226 Y134.5357
    N9220 X44.5288 Y133.2063
    N9225 X43.8643 Y132.8266
    N9230 X43.1996 Y132.3518
    N9235 X42.6300 Y131.8772
    N9240 X41.9653 Y131.4024
    N9245 X40.0665 Y129.9782
    N9250 X39.4968 Y129.5036
    N9255 X38.8322 Y129.0288
    N9260 X38.2625 Y128.4591
    N9265 X37.6929 Y127.9843
    N9270 X35.9838 Y126.3704
    N9275 X35.4141 Y125.8008
    N9280 X34.8445 Y125.3260
    N9285 X34.2748 Y124.7564
    N9290 X33.2304 Y123.6171
    N9295 X32.6608 Y123.0474
    N9300 X32.0911 Y122.4776
    N9305 X31.6165 Y121.8131
    N9310 X31.1417 Y121.2435
    N9315 X30.5721 Y120.6738
    N9320 X29.6227 Y119.4395
    N9325 X29.1479 Y118.7748
    N9330 X28.6731 Y118.2052
    N9335 X28.1985 Y117.5405
    N9340 X27.7237 Y116.8760
    N9345 X27.3439 Y116.3064
    N9350 X26.8693 Y115.6417
    N9355 X26.3945 Y114.9770
    N9360 X26.0148 Y114.3126
    N9365 X25.6350 Y113.6479
    N9370 X25.1602 Y112.9832
    N9375 X24.7804 Y112.3187
    N9380 X24.4007 Y111.6540
    N9385 X24.0209 Y110.8945
    N9390 X23.6412 Y110.2298
    N9395 X23.3562 Y109.5654
    N9400 X22.8816 Y108.9007
    N9405 X22.5967 Y108.1412
    N9410 X22.2170 Y107.4765
    N9415 X21.8372 Y106.7170
    N9420 X21.5523 Y106.0525
    N9425 X21.2676 Y105.2928
    N9430 X20.9826 Y104.6283
    N9435 X20.6029 Y103.8686
    N9440 X20.0332 Y102.4446
    N9445 X19.8434 Y101.6850
    N9450 X19.5584 Y100.9253
    N9455 X19.2737 Y100.1658
    N9460 X18.6090 Y97.8872
    N9465 X18.4192 Y97.2226
    N9470 G40
    N9475 X18.3243 Y96.9378
    N9480 G0 Z1.0000
    N9485 X62.7580 Y142.7007
    N9490 G1 Z0.0000
    N9495 G42
    N9500 X62.4733 Y142.6059
    N9505 X61.7136 Y142.4160
    N9510 X59.4350 Y141.7513
    N9515 X58.6755 Y141.4664
    N9520 X58.0108 Y141.1817
    N9525 X57.1563 Y140.8968
    N9530 X56.4918 Y140.6120
    N9535 X55.7323 Y140.3271
    N9540 X54.9728 Y140.0424
    N9545 X54.2130 Y139.7575
    N9550 X53.5486 Y139.3777
    N9555 X52.7888 Y139.0928
    N9560 X51.3648 Y138.4283
    N9565 X50.6053 Y138.0486
    N9570 X49.9406 Y137.6688
    N9575 X48.5164 Y136.9093
    N9580 X47.8520 Y136.5293
    N9585 X47.0922 Y136.1496
    N9590 X46.4278 Y135.7698
    N9595 X45.7631 Y135.2952
    N9600 X43.7692 Y134.0609
    N9605 X43.1046 Y133.5861
    N9610 X42.4401 Y133.1115
    N9615 X41.7754 Y132.6367
    N9620 X41.1109 Y132.1621
    N9625 X40.5411 Y131.6873
    N9630 X39.9714 Y131.2125
    N9635 X39.2119 Y130.7379
    N9640 X38.6423 Y130.1682
    N9645 X37.9776 Y129.6934
    N9650 X37.4080 Y129.2186
    N9655 X36.8383 Y128.6490
    N9660 X36.1736 Y128.0794
    N9665 X35.6040 Y127.6046
    N9670 X35.0344 Y127.0349
    N9675 X34.4647 Y126.4653
    N9680 X32.8506 Y124.7564
    N9685 X32.2810 Y124.1867
    N9690 X31.7114 Y123.6171
    N9695 X31.1417 Y123.0474
    N9700 X30.6669 Y122.3828
    N9705 X30.1923 Y121.8131
    N9710 X29.1479 Y120.5788
    N9715 X28.1985 Y119.3445
    N9720 X27.7237 Y118.6800
    N9725 X27.2491 Y118.0153
    N9730 X26.7743 Y117.3506
    N9735 X26.2995 Y116.6862
    N9740 X24.5906 Y114.0276
    N9745 X24.1158 Y113.3630
    N9750 X23.7360 Y112.6985
    N9755 X23.3562 Y111.9390
    N9760 X22.9765 Y111.2743
    N9765 X22.2170 Y109.8501
    N9770 X21.8372 Y109.1856
    N9775 X21.4574 Y108.4261
    N9780 X20.7928 Y107.0019
    N9785 X20.5080 Y106.2422
    N9790 X20.1283 Y105.5777
    N9795 X19.8434 Y104.8182
    N9800 X19.5584 Y104.0586
    N9805 X19.2737 Y103.2989
    N9810 X18.9888 Y102.5394
    N9815 X18.7041 Y101.8747
    N9820 X18.4192 Y101.1152
    N9825 X17.4698 Y98.0771
    N9830 G40
    N9835 X17.2799 Y97.2226
    N9840 G0 Z1.0000
    N9845 X142.6059 Y62.7578
    N9850 G1 Z0.0000
    N9855 G42
    N9860 X141.4666 Y58.9602
    N9865 X141.1819 Y58.2005
    N9870 X140.8972 Y57.4410
    N9875 X140.3273 Y55.9220
    N9880 X140.0426 Y55.2573
    N9885 X139.7575 Y54.4978
    N9890 X139.3777 Y53.7382
    N9895 X139.0930 Y52.9787
    N9900 X138.4285 Y51.5545
    N9905 X137.6690 Y50.1303
    N9910 X137.2892 Y49.4658
    N9915 X136.9095 Y48.7061
    N9920 X136.5297 Y48.0416
    N9925 X136.1500 Y47.3770
    N9930 X135.7698 Y46.7123
    N9935 X135.2954 Y45.9528
    N9940 X134.0611 Y43.9589
    N9945 X133.5863 Y43.2944
    N9950 X133.1115 Y42.6298
    N9955 X132.6367 Y41.9651
    N9960 X132.1623 Y41.3954
    N9965 X131.6875 Y40.7310
    N9970 X131.2127 Y40.0663
    N9975 X130.7379 Y39.4966
    N9980 X130.2631 Y38.8320
    N9985 X128.6490 Y37.0280
    N9990 X128.1746 Y36.4584
    N9995 X127.6048 Y35.7939
    N10000 X126.4655 Y34.6544
    N10005 X125.9907 Y34.0848
    N10010 X125.4212 Y33.5151
    N10015 X124.8514 Y33.0405
    N10020 X124.1869 Y32.4707
    N10025 X123.6171 Y31.9010
    N10030 X123.0476 Y31.4264
    N10035 X122.4778 Y30.8568
    N10040 X121.8133 Y30.3820
    N10045 X120.5790 Y29.3376
    N10050 X119.3447 Y28.3882
    N10055 X118.6802 Y27.8185
    N10060 X118.1104 Y27.3437
    N10065 X117.4459 Y26.9640
    N10070 X116.7810 Y26.4894
    N10075 X116.1165 Y26.0146
    N10080 X115.4520 Y25.5398
    N10085 X114.1227 Y24.6854
    N10090 X113.4582 Y24.3056
    N10095 X112.6987 Y23.9259
    N10100 X112.0338 Y23.5461
    N10105 X111.3693 Y23.1662
    N10110 X109.1858 Y22.0269
    N10115 X108.5209 Y21.6471
    N10120 X107.8564 Y21.2674
    N10125 X106.3374 Y20.6027
    N10130 X105.5779 Y20.3180
    N10135 X104.9130 Y20.0330
    N10140 X104.1535 Y19.7483
    N10145 X103.3940 Y19.3686
    N10150 X102.6344 Y19.0836
    N10155 X101.8749 Y18.8938
    N10160 X101.1154 Y18.6090
    N10165 X97.3178 Y17.3747
    N10170 G40
    N10175 X97.1277
    N10180 G0 Z1.0000
    N10185 X141.6567 Y63.0428
    N10190 G1 Z0.0000
    N10195 G42
    N10200 X141.5616 Y62.8529
    N10205 X141.3716 Y62.0934
    N10210 X140.8972 Y60.5741
    N10215 X140.6120 Y59.9096
    N10220 X140.4224 Y59.1499
    N10225 X140.1372 Y58.3904
    N10230 X139.8525 Y57.6309
    N10235 X139.5678 Y56.8714
    N10240 X139.2831 Y56.2069
    N10245 X138.7132 Y54.7827
    N10250 X138.3335 Y54.0230
    N10255 X137.3839 Y51.8394
    N10260 X137.0041 Y51.1748
    N10265 X136.2446 Y49.7506
    N10270 X135.9599 Y49.0861
    N10275 X135.4851 Y48.4214
    N10280 X134.7256 Y47.0922
    N10285 X132.6367 Y43.7690
    N10290 X132.1623 Y43.1046
    N10295 X131.6875 Y42.4399
    N10300 X129.7887 Y39.9714
    N10305 X129.3139 Y39.4016
    N10310 X128.8391 Y38.7371
    N10315 X128.2692 Y38.1675
    N10320 X127.7948 Y37.5978
    N10325 X126.1808 Y35.8887
    N10330 X123.9968 Y33.6102
    N10335 X123.4274 Y33.1354
    N10340 X122.7625 Y32.5657
    N10345 X121.6232 Y31.5213
    N10350 X121.0538 Y31.0467
    N10355 X120.3889 Y30.5719
    N10360 X119.8195 Y30.0022
    N10365 X117.3508 Y28.1034
    N10370 X116.6864 Y27.7235
    N10375 X116.0215 Y27.2489
    N10380 X113.3632 Y25.5398
    N10385 X112.6987 Y25.1600
    N10390 X112.0338 Y24.6854
    N10395 X111.3693 Y24.3056
    N10400 X110.7048 Y23.9259
    N10405 X109.9453 Y23.5461
    N10410 X109.2804 Y23.2612
    N10415 X108.6160 Y22.8814
    N10420 X105.0080 Y21.1725
    N10425 X103.6791 Y20.6027
    N10430 X102.8245 Y20.3180
    N10435 X102.1596 Y20.0330
    N10440 X101.4001 Y19.7483
    N10445 X100.6406 Y19.5584
    N10450 X99.8811 Y19.2735
    N10455 X97.6025 Y18.6090
    N10460 G40
    N10465 X96.9380 Y18.3241
    N10470 G0 Z1.0000
    N10475 X67.0304 Y73.8663
    N10480 G1 Z0.0000
    N10485 G42
    N10490 X67.7902 Y73.0118
    N10495 X68.5497 Y72.1574
    N10500 X69.0243 Y71.5878
    N10505 X69.5941 Y70.9231
    N10510 X69.4991 Y70.8282
    N10515 X69.4040 Y70.7332
    N10520 X69.2144 Y70.6382
    N10525 Y70.5433
    N10530 X69.1193
    N10535 X68.9294 Y70.8282
    N10540 X68.3598 Y71.3979
    N10545 X68.0749 Y71.6826
    N10550 X67.6951 Y71.9675
    N10555 X66.7457 Y72.6320
    N10560 G40
    N10565 X66.3660 Y72.8221
    N10570 G0 Z1.0000
    N10575 X73.7715 Y67.0304
    N10580 G1 Z0.0000
    N10585 G42
    N10590 X73.6766
    N10595 X73.5816 Y66.9354
    N10600 X73.2018 Y66.7455
    N10605 Y66.6507
    N10610 X73.1070
    N10615 X73.0120 Y66.5556
    N10620 X72.9171
    N10625 Y66.4608
    N10630 G40
    N10635 X72.8221
    N10640 G0 Z1.0000
    N10645 X70.5435 Y69.2142
    N10650 G1 Z0.0000
    N10655 G42
    N10660 X70.4485 Y69.3090
    N10665 X70.2586 Y69.4040
    N10670 X70.0687 Y69.5939
    N10675 X69.9739 Y69.6888
    N10680 X69.8788 Y69.7838
    N10685 X69.4991 Y70.1636
    N10690 X69.4040 Y70.3534
    N10695 G40
    N10700 X69.1193 Y70.5433
    N10705 G0 Z1.0000
    N10710 X70.9233 Y69.6888
    N10715 G1 Z0.0000
    N10720 G42
    N10725 X70.6384 Y69.8786
    N10730 X70.5435 Y69.9737
    N10735 X70.4485 Y70.1636
    N10740 X70.2586 Y70.2584
    N10745 X70.0687 Y70.4485
    N10750 X69.9739 Y70.6382
    N10755 X69.8788 Y70.7332
    N10760 X69.7838 Y70.8282
    N10765 G40
    N10770 X69.5941 Y70.9231
    N10775 G0 Z1.0000
    N10780 X85.5444 Y60.7640
    N10785 G1 Z0.0000
    N10790 G42
    N10795 Y61.3338
    N10800 X85.6395 Y61.8084
    N10805 X85.7345 Y62.3781
    N10810 X85.8296 Y62.9477
    N10815 X86.1143 Y64.1820
    N10820 X86.3990 Y64.7517
    N10825 X86.5891 Y65.3213
    N10830 X86.8738 Y65.8910
    N10835 X87.1585 Y66.4608
    N10840 X87.0639
    N10845 Y66.5556
    N10850 X86.9688
    N10855 X86.8738 Y66.6507
    N10860 X86.7788
    N10865 X86.6841 Y66.7455
    N10870 X86.3990 Y66.9354
    N10875 X86.2093 Y67.0304
    N10880 X86.1143
    N10885 G0 Z1.0000
    N10890 X85.5444 Y60.7640
    N10895 Z0.0000
    N10900 G1 X85.4498
    N10905 X84.4052
    N10910 G0 Z1.0000
    N10915 X85.5444 Y27.0590
    N10920 Z0.0000
    N10925 G1 Y43.8641
    N10930 Y60.7640
    N10935 G0 Z1.0000
    N10940 X97.2228 Y17.2797
    N10945 Z0.0000
    N10950 G1 Y17.4696
    N10955 X97.1277 Y17.5646
    N10960 Y17.6594
    N10965 X97.0327 Y17.8493
    N10970 Y17.9444
    N10975 Y18.0392
    N10980 Y18.1342
    N10985 X96.9380
    N10990 Y18.3241
    N10995 X96.5583 Y18.2291
    N11000 X96.0835 Y18.1342
    N11005 X95.6087
    N11010 X95.0388 Y18.0392
    N11015 X93.8049
    N11020 X93.1400 Y18.1342
    N11025 X92.5706 Y18.2291
    N11030 X92.0008 Y18.4190
    N11035 X91.4313 Y18.6090
    N11040 X90.8615 Y18.7989
    N11045 X90.2916 Y19.0836
    N11050 X89.8172 Y19.3686
    N11055 X89.3424 Y19.7483
    N11060 X88.8676 Y20.1281
    N11065 X88.3928 Y20.5078
    N11070 X87.9180 Y20.9826
    N11075 X87.5383 Y21.3624
    N11080 X87.1585 Y21.9320
    N11085 X86.8738 Y22.4066
    N11090 X86.5891 Y22.9763
    N11095 X86.3990 Y23.4511
    N11100 X86.1143 Y24.0207
    N11105 X85.9242 Y24.5904
    N11110 X85.7345 Y25.2550
    N11115 X85.6395 Y25.8247
    N11120 X85.5444 Y27.0590
    N11125 G0 Z1.0000
    N11130 X84.5002
    N11135 Z0.0000
    N11140 G1 Y26.5842
    N11145 X84.5952 Y25.5398
    N11150 X84.6903 Y24.9701
    N11155 X84.7849 Y24.4005
    N11160 X84.9750 Y23.8308
    N11165 X85.1647 Y23.3562
    N11170 X85.3548 Y22.7864
    N11175 X85.6395 Y22.3118
    N11180 X86.2093 Y21.3624
    N11185 X86.5891 Y20.8876
    N11190 X87.3486 Y20.0330
    N11195 X87.7284 Y19.6533
    N11200 X88.1081 Y19.2735
    N11205 X89.0577 Y18.6090
    N11210 X90.0069 Y18.0392
    N11215 X90.5768 Y17.7545
    N11220 X91.1462 Y17.5646
    N11225 X91.6210 Y17.3747
    N11230 X92.1908 Y17.2797
    N11235 X92.7603 Y17.0898
    N11240 X93.3301 Y16.9950
    N11245 X93.8049
    N11250 X94.9442
    N11255 X96.0835 Y17.0898
    N11260 X96.6529 Y17.1848
    N11265 X97.2228 Y17.2797
    N11270 G0 Z1.0000
    N11275 X84.4052 Y60.7640
    N11280 Z0.0000
    N11285 G1 Y38.2623
    N11290 X84.5002 Y29.3376
    N11295 Y27.0590
    N11300 G0 Z1.0000
    N11305 X86.1143 Y67.0304
    N11310 Z0.0000
    N11315 G1 X85.8296 Y66.5556
    N11320 X85.5444 Y65.9860
    N11325 X85.3548 Y65.4164
    N11330 X85.1647 Y64.8467
    N11335 X84.7849 Y63.5174
    N11340 X84.6903 Y62.8529
    N11345 X84.5002 Y62.1882
    N11350 Y61.4287
    N11355 G40
    N11360 X84.4052 Y60.7640
    N11365 G0 Z1.0000
    N11370 X69.1193 Y89.4373
    N11375 G1 Z0.0000
    N11380 G42
    N11385 X69.2144
    N11390 X69.3092 Y89.3422
    N11395 X69.4040 Y89.2472
    N11400 X69.4991 Y89.1524
    N11405 X69.5941 Y89.0573
    N11410 G0 Z1.0000
    N11415 X69.1193 Y89.4373
    N11420 Z0.0000
    N11425 G1 X68.9294 Y89.2472
    N11430 X68.7396 Y88.9625
    N11435 X68.4546 Y88.6776
    N11440 X67.4102 Y87.7282
    N11445 X67.0304 Y87.5383
    N11450 X66.7457 Y87.3484
    N11455 G40
    N11460 X66.3660 Y87.1585
    N11465 G0 Z1.0000
    N11470 X89.0577 Y69.5939
    N11475 G1 Z0.0000
    N11480 G42
    N11485 X89.4375 Y69.3090
    N11490 Y69.2142
    N11495 X89.1524 Y68.9292
    N11500 X88.8676 Y68.6443
    N11505 X88.5829 Y68.3596
    N11510 X88.2978 Y68.0749
    N11515 X88.0131 Y67.7900
    N11520 X87.3486 Y66.7455
    N11525 G40
    N11530 X87.1585 Y66.4608
    N11535 G0 Z1.0000
    N11540 X70.4485 Y90.8613
    N11545 G1 Z0.0000
    N11550 G42
    N11555 X70.2586 Y90.5766
    N11560 X70.0687 Y90.4815
    N11565 X69.7838 Y90.1018
    N11570 X69.5941 Y90.0067
    N11575 X69.4991 Y89.9119
    N11580 X69.3092 Y89.7220
    N11585 G40
    N11590 X69.1193 Y89.4373
    N11595 G0 Z1.0000
    N11600 X132.9218 Y75.4804
    N11605 G1 Z0.0000
    N11610 G42
    N11615 X133.4912
    N11620 X134.0611
    N11625 X135.2004 Y75.2905
    N11630 X135.6752 Y75.1006
    N11635 X136.2446 Y74.9108
    N11640 X136.8144 Y74.7209
    N11645 X137.8587 Y74.2461
    N11650 X138.3335 Y73.9614
    N11655 X138.8083 Y73.6764
    N11660 X139.2831 Y73.2967
    N11665 X140.0426 Y72.5372
    N11670 X140.8021 Y71.6826
    N11675 X141.4666 Y70.7332
    N11680 X141.7513 Y70.2584
    N11685 X142.2261 Y69.2142
    N11690 X142.6059 Y68.1697
    N11695 X142.7960 Y67.6001
    N11700 X142.8906 Y67.0304
    N11705 X142.9856 Y66.5556
    N11710 Y65.9860
    N11715 Y65.4164
    N11720 Y64.8467
    N11725 Y64.2771
    N11730 X142.8906 Y63.7074
    N11735 X142.7960 Y63.2326
    N11740 X142.6059 Y62.7578
    N11745 G0 Z1.0000
    N11750 X99.2166 Y75.4804
    N11755 Z0.0000
    N11760 G1 X101.4001
    N11765 X110.4201
    N11770 X132.9218
    N11775 G0 Z1.0000
    N11780 X92.9504 Y73.8663
    N11785 Z0.0000
    N11790 G1 X93.5198 Y74.1512
    N11795 X93.9946 Y74.3411
    N11800 X95.1339 Y74.8157
    N11805 X95.7037 Y75.0056
    N11810 X96.2732 Y75.1957
    N11815 X97.6976 Y75.4804
    N11820 X98.2670
    N11825 X99.2166
    N11830 G0 Z1.0000
    N11835 X141.6567 Y63.0428
    N11840 Z0.0000
    N11845 G1 X141.7513 Y63.6124
    N11850 X141.8464 Y64.1820
    N11855 X141.9414 Y64.8467
    N11860 Y66.0810
    N11865 X141.8464 Y66.6507
    N11870 X141.7513 Y67.2203
    N11875 X141.6567 Y67.7900
    N11880 X141.1819 Y68.9292
    N11885 X140.9918 Y69.4989
    N11890 X140.6120 Y70.0685
    N11895 X140.3273 Y70.5433
    N11900 X139.9476 Y71.0179
    N11905 X138.7132 Y72.3473
    N11910 X138.2384 Y72.7270
    N11915 X137.6690 Y73.0118
    N11920 X136.6244 Y73.5816
    N11925 X136.0549 Y73.8663
    N11930 X135.4851 Y74.0562
    N11935 X134.9156 Y74.1512
    N11940 X134.3458 Y74.2461
    N11945 X133.8710 Y74.3411
    N11950 X133.3962
    N11955 X132.9218 Y74.4360
    N11960 Y74.8157
    N11965 Y74.9108
    N11970 Y75.4804
    N11975 G0 Z1.0000
    N11980 X141.6567 Y63.0428
    N11985 Z0.0000
    N11990 G1 X141.7513
    N11995 X141.8464 Y62.9477
    N12000 X141.9414
    N12005 X142.0364
    N12010 X142.1311 Y62.8529
    N12015 X142.2261
    N12020 X142.3212
    N12025 X142.4162
    N12030 X142.6059 Y62.7578
    N12035 G0 Z1.0000
    N12040 X90.3867 Y70.9231
    N12045 Z0.0000
    N12050 G1 X90.6714 Y71.3979
    N12055 X91.1462 Y71.7776
    N12060 X91.8111 Y72.6320
    N12065 X92.3805 Y73.2018
    N12070 X92.6652 Y73.4866
    N12075 X92.9504 Y73.8663
    N12080 G0 Z1.0000
    N12085 X89.0577 Y69.5939
    N12090 Z0.0000
    N12095 G1 X89.4375 Y69.9737
    N12100 X89.5321 Y70.0685
    N12105 X89.7222 Y70.2584
    N12110 X89.9119 Y70.4485
    N12115 X90.0069 Y70.6382
    N12120 X90.3867 Y70.9231
    N12125 G0 Z1.0000
    N12130 X86.1143 Y67.0304
    N12135 Z0.0000
    N12140 G1 X86.5891 Y67.4102
    N12145 X86.9688 Y67.7900
    N12150 X87.8234 Y68.5495
    N12155 G40
    N12160 X89.0577 Y69.5939
    N12165 G0 Z1.0000
    N12170 X90.7664 Y70.5433
    N12175 G1 Z0.0000
    N12180 G42
    N12185 X90.5768 Y70.3534
    N12190 X90.4817 Y70.1636
    N12195 X90.2916 Y70.0685
    N12200 X90.1020 Y69.8786
    N12205 X89.6272 Y69.3090
    N12210 G40
    N12215 X89.4375 Y69.2142
    N12220 G0 Z1.0000
    N12225 X14.8112 Y115.2620
    N12230 G1 Z0.0000
    N12235 G42
    N12240 Y115.3568
    N12245 Y115.4518
    N12250 X14.7164 Y115.5469
    N12255 G40
    N12260 Y115.6417
    N12265 G0 Z1.0000
    N12270 X72.8221 Y93.5198
    N12275 G1 Z0.0000
    N12280 G42
    N12285 X72.6322 Y93.2349
    N12290 X72.3475 Y92.8551
    N12295 X72.1574 Y92.5704
    N12300 X71.8727 Y92.2855
    N12305 X71.6828 Y91.9057
    N12310 X70.5435 Y90.7664
    N12315 X70.6384
    N12320 Y90.6714
    N12325 X70.8282 Y90.4815
    N12330 G40
    N12335 X70.9233 Y90.3867
    N12340 G0 Z1.0000
    N12345 X93.6148 Y72.8221
    N12350 G1 Z0.0000
    N12355 G42
    N12360 X93.2351 Y72.6320
    N12365 X92.9504 Y72.4421
    N12370 X92.6652 Y72.2522
    N12375 X92.2855 Y72.0624
    N12380 X91.8111 Y71.5878
    N12385 X91.5260 Y71.3028
    N12390 X91.2412 Y71.0179
    N12395 X90.9565 Y70.8282
    N12400 X90.7664 Y70.5433
    N12405 G0 Z1.0000
    N12410 X90.3867 Y70.9231
    N12415 Z0.0000
    N12420 G1 Y70.8282
    N12425 X90.4817
    N12430 X90.6714 Y70.6382
    N12435 X90.7664
    N12440 G40
    N12445 Y70.5433
    N12450 G0 Z1.0000
    N12455 X83.3609 Y80.0377
    N12460 G1 Z0.0000
    N12465 G42
    N12470 X83.2659
    N12475 Y80.7972
    N12480 X83.1708 Y80.9871
    N12485 X83.0762 Y81.1770
    N12490 Y81.3669
    N12495 X82.9812 Y81.4619
    N12500 X82.8861 Y81.6518
    N12505 X82.7911 Y81.7466
    N12510 Y81.9365
    N12515 X82.6014 Y82.0316
    N12520 X82.5064 Y82.2214
    N12525 Y82.3165
    N12530 X82.3167 Y82.4113
    N12535 X82.2216 Y82.5062
    N12540 X82.1266 Y82.6012
    N12545 X81.9369 Y82.6962
    N12550 X81.8419 Y82.8859
    N12555 X81.6518 Y82.9810
    N12560 X81.4621 Y83.0760
    N12565 X81.2720
    N12570 X81.1770 Y83.1708
    N12575 X81.0824 Y83.2659
    N12580 X80.8923
    N12585 X80.7026 Y83.3607
    N12590 X79.3732
    N12595 X79.0885 Y83.2659
    N12600 X78.8034
    N12605 X78.7088 Y83.1708
    N12610 X78.6137 Y83.0760
    N12615 X78.4236
    N12620 X78.2340 Y82.9810
    N12625 X78.1389 Y82.8859
    N12630 X78.0439
    N12635 X77.9492 Y82.6962
    N12640 X77.7592 Y82.6012
    N12645 X77.6641 Y82.5062
    N12650 X77.5695 Y82.3165
    N12655 X77.3794
    N12660 X77.2846 Y82.1264
    N12665 X77.1895 Y82.0316
    N12670 X77.0947 Y81.8417
    N12675 X76.9996 Y81.7466
    N12680 Y81.5568
    N12685 X76.9046 Y81.4619
    N12690 Y81.2720
    N12695 X76.8098 Y81.1770
    N12700 X76.7149 Y80.9871
    N12705 X76.6199 Y80.7972
    N12710 Y79.4681
    N12715 X76.7149 Y79.1832
    N12720 Y78.8984
    N12725 X76.8098 Y78.8034
    N12730 X76.9046 Y78.7086
    N12735 X76.9996 Y78.5187
    N12740 Y78.4236
    N12745 X77.0947 Y78.3288
    N12750 Y78.1387
    N12755 X77.2846 Y78.0439
    N12760 X77.3794 Y77.8540
    N12765 X77.4744 Y77.7590
    N12770 X77.5695 Y77.6641
    N12775 X77.6641 Y77.4742
    N12780 X77.8542 Y77.3792
    N12785 X77.9492 Y77.2844
    N12790 X78.1389 Y77.1893
    N12795 X78.2340
    N12800 X78.3290 Y77.0945
    N12805 X78.5187 Y76.9994
    N12810 X78.6137 Y76.9046
    N12815 X78.8034
    N12820 X78.9935 Y76.8096
    N12825 X79.1836 Y76.7147
    N12830 X79.9431
    N12835 X80.7026
    N12840 X80.8923 Y76.8096
    N12845 X81.0824
    N12850 X81.1770 Y76.9046
    N12855 X81.2720 Y76.9994
    N12860 X81.4621
    N12865 X81.6518 Y77.0945
    N12870 X81.8419 Y77.1893
    N12875 X81.9369 Y77.3792
    N12880 X82.1266 Y77.4742
    N12885 X82.2216 Y77.5693
    N12890 X82.3167 Y77.6641
    N12895 X82.5064 Y77.7590
    N12900 Y77.8540
    N12905 X82.6014 Y78.0439
    N12910 X82.7911 Y78.1387
    N12915 Y78.3288
    N12920 X82.8861 Y78.4236
    N12925 X82.9812 Y78.6135
    N12930 X83.0762 Y78.7086
    N12935 Y78.8984
    N12940 X83.1708 Y79.0883
    N12945 X83.2659 Y79.2782
    N12950 G40
    N12955 Y80.0377
    N12960 G0 Z1.0000
    N12965 X18.7989 Y122.0030
    N12970 G1 Z0.0000
    N12975 G42
    N12980 X18.7041 Y121.9080
    N12985 X18.2293 Y121.1484
    N12990 X17.2799 Y119.6294
    N12995 X16.8051 Y118.7748
    N13000 X16.7102 Y118.6800
    N13005 X16.5204
    N13010 G40
    N13015 G0 Z1.0000
    N13020 X15.0013 Y119.6294
    N13025 Z0.0000
    N13030 G1 X16.5204 Y118.6800
    N13035 G0 Z1.0000
    N13040 X14.7164 Y115.6417
    N13045 G1 Z0.0000
    N13050 G42
    N13055 X13.1974 Y116.4963
    N13060 X12.8176 Y116.6862
    N13065 X12.5327 Y116.8760
    N13070 X12.2478 Y117.1608
    N13075 X11.9630 Y117.4457
    N13080 X11.6781 Y117.6356
    N13085 X11.4882 Y118.0153
    N13090 X11.1085 Y118.3002
    N13095 X10.6339 Y119.0598
    N13100 X10.4440 Y119.5344
    N13105 X10.9186 Y120.3889
    N13110 G40
    N13115 Y120.4838
    N13120 G0 Z1.0000
    N13125 X15.0013 Y119.6294
    N13130 G1 Z0.0000
    N13135 G42
    N13140 X14.6214 Y119.8193
    N13145 X14.2416 Y119.9141
    N13150 X13.9569 Y120.1040
    N13155 X13.5771 Y120.1990
    N13160 X12.8176 Y120.3889
    N13165 X11.9630 Y120.4838
    N13170 X11.4882
    N13175 G40
    N13180 X11.0136
    N13185 G0 Z1.0000
    N13190 X132.9218 Y74.4360
    N13195 G1 Z0.0000
    N13200 G42
    N13205 X116.1165
    N13210 X99.2166
    N13215 Y75.4804
    N13220 G0 Z1.0000
    N13225 Y74.4360
    N13230 Z0.0000
    N13235 G1 X97.9823 Y74.3411
    N13240 X97.4124 Y74.2461
    N13245 X96.7480 Y74.1512
    N13250 X95.5136 Y73.7715
    N13255 X95.0388 Y73.5816
    N13260 X94.4694 Y73.3915
    N13265 X93.9946 Y73.1068
    N13270 X93.6148 Y72.8221
    N13275 G0 Z1.0000
    N13280 X92.9504 Y73.8663
    N13285 Z0.0000
    N13290 G1 X93.0450 Y73.6764
    N13295 X93.1400 Y73.5816
    N13300 X93.3301 Y73.2018
    N13305 X93.4252 Y73.1068
    N13310 Y73.0118
    N13315 X93.5198 Y72.9169
    N13320 Y72.8221
    N13325 G40
    N13330 X93.6148
    N13335 G0 Z1.0000
    N13340 X118.7748 Y16.8051
    N13345 G1 Z0.0000
    N13350 G42
    N13355 X118.6802 Y16.7100
    N13360 Y16.6152
    N13365 G40
    N13370 Y16.5202
    N13375 G0 Z1.0000
    N13380 X153.0499 Y66.2707
    N13385 G1 Z0.0000
    N13390 G42
    N13395 X154.7586 Y65.8910
    N13400 X155.2334 Y65.7961
    N13405 X155.5185 Y65.7013
    N13410 X155.8983 Y65.6062
    N13415 X156.1830 Y65.4164
    N13420 X156.5628 Y65.2265
    N13425 X156.9425 Y65.0366
    N13430 X157.3223 Y64.8467
    N13435 X157.9868 Y64.2771
    N13440 X158.2719 Y63.8971
    N13445 X158.0818 Y62.9477
    N13450 Y62.8529
    N13455 G0 Z1.0000
    N13460 X153.9991 Y62.3781
    N13465 Z0.0000
    N13470 G1 X155.2334 Y62.2832
    N13475 X155.5185
    N13480 X155.8983
    N13485 X156.7524 Y62.3781
    N13490 X157.2272 Y62.4731
    N13495 X157.6070 Y62.6630
    N13500 X158.0818 Y62.8529
    N13505 G0 Z1.0000
    N13510 X152.2904 Y62.7578
    N13515 Z0.0000
    N13520 G1 X153.9991 Y62.3781
    N13525 G0 Z1.0000
    N13530 X152.2904 Y62.7578
    N13535 Z0.0000
    N13540 G1 X152.1953
    N13545 X152.1003
    N13550 X152.0052 Y62.6630
    N13555 X151.8156 Y61.8084
    N13560 X151.5308 Y60.8590
    N13565 X151.3408 Y60.0045
    N13570 X151.0560 Y59.1499
    N13575 Y59.0551
    N13580 G0 Z1.0000
    N13585 X151.2457 Y58.7702
    N13590 Z0.0000
    N13595 G1 X151.1511
    N13600 X151.0560 Y58.8652
    N13605 Y59.0551
    N13610 G0 Z1.0000
    N13615 X151.2457 Y58.7702
    N13620 Z0.0000
    N13625 G1 X152.8598 Y58.2005
    N13630 X153.2396 Y58.1057
    N13635 X153.6193 Y57.9158
    N13640 X153.9044 Y57.7259
    N13645 X154.2842 Y57.5360
    N13650 X154.5689 Y57.3462
    N13655 X154.9487 Y57.1563
    N13660 X155.2334 Y56.8714
    N13665 X155.8983 Y56.2069
    N13670 X156.1830 Y55.8269
    N13675 X155.8983 Y54.8775
    N13680 X155.8032 Y54.7827
    N13685 G0 Z1.0000
    N13690 X151.8156
    N13695 Z0.0000
    N13700 G1 X152.1953 Y54.6876
    N13705 X152.4800 Y54.5928
    N13710 X152.8598 Y54.4978
    N13715 X153.3346
    N13720 X153.7144 Y54.4027
    N13725 X154.0941
    N13730 X154.4739 Y54.4978
    N13735 X154.9487
    N13740 X155.4235 Y54.5928
    N13745 X155.8032 Y54.7827
    N13750 G0 Z1.0000
    N13755 X150.1064 Y55.3523
    N13760 Z0.0000
    N13765 G1 X151.8156 Y54.7827
    N13770 G0 Z1.0000
    N13775 X150.1064 Y55.3523
    N13780 Z0.0000
    N13785 G1 X149.9168
    N13790 X149.8217 Y55.2573
    N13795 Y55.1624
    N13800 X149.5370 Y54.3079
    N13805 X149.1572 Y53.5484
    N13810 X148.4924 Y51.8394
    N13815 Y51.7444
    N13820 G0 Z1.0000
    N13825 X148.5874 Y51.3646
    N13830 Z0.0000
    N13835 G1 X148.4924 Y51.4597
    N13840 Y51.5545
    N13845 Y51.7444
    N13850 G0 Z1.0000
    N13855 X148.5874 Y51.3646
    N13860 Z0.0000
    N13865 G1 X150.2015 Y50.7000
    N13870 X150.5812 Y50.5101
    N13875 X151.2457 Y50.1303
    N13880 X151.5308 Y49.9404
    N13885 X151.8156 Y49.6555
    N13890 X152.4800 Y49.0861
    N13895 X152.7652 Y48.7061
    N13900 X152.9548 Y48.4214
    N13905 X153.2396 Y47.9466
    N13910 X152.8598 Y47.0922
    N13915 Y46.9022
    N13920 G0 Z1.0000
    N13925 X148.7775 Y47.3770
    N13930 Z0.0000
    N13935 G1 X149.1572 Y47.2821
    N13940 X149.4420 Y47.0922
    N13945 X150.2015 Y46.9022
    N13950 X150.9610 Y46.8073
    N13955 X151.9106
    N13960 X152.2904 Y46.9022
    N13965 X152.8598
    N13970 G0 Z1.0000
    N13975 X147.1634 Y48.1365
    N13980 Z0.0000
    N13985 G1 X148.7775 Y47.3770
    N13990 G0 Z1.0000
    N13995 X147.1634 Y48.1365
    N14000 Z0.0000
    N14005 G1 X147.0684
    N14010 X146.9733
    N14015 X146.8783
    N14020 Y48.0416
    N14025 X146.4039 Y47.1871
    N14030 X146.0241 Y46.4276
    N14035 X145.1696 Y44.8135
    N14040 Y44.7186
    N14045 G0 Z1.0000
    N14050 X145.2642 Y44.4337
    N14055 Z0.0000
    N14060 G1 X145.1696 Y44.5286
    N14065 Y44.7186
    N14070 G0 Z1.0000
    N14075 X145.2642 Y44.4337
    N14080 Z0.0000
    N14085 G1 X146.7836 Y43.4843
    N14090 X147.0684 Y43.2944
    N14095 X147.4481 Y43.1046
    N14100 X148.0180 Y42.6298
    N14105 X148.3027 Y42.3450
    N14110 X148.4924 Y42.0601
    N14115 X148.7775 Y41.6804
    N14120 X149.0622 Y41.3006
    N14125 X149.2519 Y40.9208
    N14130 X149.5370 Y40.5411
    N14135 X149.4420 Y40.3512
    N14140 X149.3469 Y40.2562
    N14145 X149.2519 Y40.1613
    N14150 Y39.9714
    N14155 X149.1572 Y39.8764
    N14160 X149.0622 Y39.7814
    N14165 X148.9672 Y39.6865
    N14170 Y39.4966
    N14175 G0 Z1.0000
    N14180 X144.9795 Y40.3512
    N14185 Z0.0000
    N14190 G1 X145.3592 Y40.2562
    N14195 X145.7390 Y40.0663
    N14200 X146.0241 Y39.8764
    N14205 X146.4039 Y39.7814
    N14210 X146.7836 Y39.6865
    N14215 X147.1634 Y39.5915
    N14220 X147.5432 Y39.4966
    N14225 X148.1126
    N14230 X148.4924
    N14235 X148.9672
    N14240 G0 Z1.0000
    N14245 X143.4604 Y41.3006
    N14250 Z0.0000
    N14255 G1 X144.9795 Y40.3512
    N14260 G0 Z1.0000
    N14265 X143.4604 Y41.3006
    N14270 Z0.0000
    N14275 G1 X143.3654
    N14280 X143.1757
    N14285 Y41.2056
    N14290 X142.8906 Y40.8258
    N14295 X142.6059 Y40.4460
    N14300 X142.4162 Y39.9714
    N14305 X142.1311 Y39.5915
    N14310 X141.8464 Y39.2117
    N14315 X141.6567 Y38.8320
    N14320 X141.3716 Y38.4522
    N14325 X141.0868 Y38.0724
    N14330 G0 Z1.0000
    N14335 X141.1819 Y37.7877
    N14340 Z0.0000
    N14345 G1 X141.0868
    N14350 Y37.8826
    N14355 Y38.0724
    N14360 G0 Z1.0000
    N14365 X141.1819 Y37.7877
    N14370 Z0.0000
    N14375 G1 X142.6059 Y36.7433
    N14380 X143.1757 Y36.2685
    N14385 X143.7452 Y35.6988
    N14390 X144.0303 Y35.4141
    N14395 X144.2200 Y35.0342
    N14400 X144.4100 Y34.6544
    N14405 X144.5997 Y34.2746
    N14410 X144.9795 Y33.4203
    N14415 X144.4100 Y32.6606
    N14420 X144.3150 Y32.5657
    N14425 G0 Z1.0000
    N14430 X140.5170 Y33.8000
    N14435 Z0.0000
    N14440 G1 X140.8021 Y33.6102
    N14445 X141.4666 Y33.2304
    N14450 X141.8464 Y33.0405
    N14455 X142.1311 Y32.9455
    N14460 X142.5108 Y32.8506
    N14465 X142.9856 Y32.6606
    N14470 X143.4604 Y32.5657
    N14475 X143.8402
    N14480 X144.3150
    N14485 G0 Z1.0000
    N14490 X139.0930 Y34.8443
    N14495 Z0.0000
    N14500 G1 X140.5170 Y33.8000
    N14505 G0 Z1.0000
    N14510 X139.0930 Y34.8443
    N14515 Z0.0000
    N14520 G1 X138.9980 Y34.9393
    N14525 X138.9033
    N14530 X138.8083 Y34.8443
    N14535 X138.7132
    N14540 X138.1434 Y34.0848
    N14545 X137.8587 Y33.7050
    N14550 X137.5740 Y33.3252
    N14555 X137.2892 Y32.9455
    N14560 X137.0041 Y32.6606
    N14565 X136.7194 Y32.2808
    N14570 X136.4347 Y31.9010
    N14575 G0 Z1.0000
    N14580 Y31.6163
    N14585 Z0.0000
    N14590 G1 X136.3396
    N14595 Y31.7112
    N14600 Y31.8062
    N14605 X136.4347 Y31.9010
    N14610 G0 Z1.0000
    N14615 Y31.6163
    N14620 Z0.0000
    N14625 G1 X137.7636 Y30.3820
    N14630 X138.2384 Y29.9072
    N14635 X138.5236 Y29.6225
    N14640 X138.7132 Y29.2427
    N14645 X139.0930 Y28.5780
    N14650 X139.3777 Y28.1983
    N14655 X139.6628 Y27.3437
    N14660 X139.7575 Y26.8691
    N14665 X139.3777 Y26.4894
    N14670 X139.2831 Y26.3943
    N14675 X138.9980 Y26.1096
    N14680 G0 Z1.0000
    N14685 X135.2954 Y27.7235
    N14690 Z0.0000
    N14695 G1 X135.5801 Y27.5336
    N14700 X135.9599 Y27.2489
    N14705 X136.2446 Y27.0590
    N14710 X136.5297 Y26.8691
    N14715 X136.9095 Y26.6792
    N14720 X137.2892 Y26.4894
    N14725 X138.1434 Y26.2044
    N14730 X138.6182 Y26.1096
    N14735 X138.9980
    N14740 G0 Z1.0000
    N14745 X133.9660 Y28.9578
    N14750 Z0.0000
    N14755 G1 X135.2954 Y27.7235
    N14760 G0 Z1.0000
    N14765 X133.9660 Y28.9578
    N14770 Z0.0000
    N14775 G1 X133.8710
    N14780 X133.6813
    N14785 X133.3962 Y28.5780
    N14790 X133.0164 Y28.1983
    N14795 X132.3520 Y27.5336
    N14800 X132.0672 Y27.2489
    N14805 X131.0226 Y26.2995
    N14810 G0 Z1.0000
    N14815 Y25.9197
    N14820 Z0.0000
    N14825 G1 Y26.0146
    N14830 Y26.2044
    N14835 Y26.2995
    N14840 G0 Z1.0000
    N14845 Y25.9197
    N14850 Z0.0000
    N14855 G1 X132.2569 Y24.6854
    N14860 X132.4470 Y24.4005
    N14865 X132.7317 Y24.0207
    N14870 X132.9218 Y23.7360
    N14875 X133.1115 Y23.4511
    N14880 X133.3016 Y23.0713
    N14885 X133.3962 Y22.6916
    N14890 X133.5863 Y22.3118
    N14895 X133.6813 Y21.8370
    N14900 X133.8710 Y21.3624
    N14905 Y20.9826
    N14910 X133.6813 Y20.7926
    N14915 X133.5863 Y20.6977
    N14920 X133.3016 Y20.4128
    N14925 X133.1115 Y20.3180
    N14930 X133.0164 Y20.2229
    N14935 G0 Z1.0000
    N14940 X129.5986 Y22.2168
    N14945 Z0.0000
    N14950 G1 X129.7887 Y21.9320
    N14955 X130.3581 Y21.4572
    N14960 X131.0226 Y20.9826
    N14965 X131.4028 Y20.7926
    N14970 X131.7825 Y20.6027
    N14975 X132.1623 Y20.4128
    N14980 X132.6367 Y20.3180
    N14985 X133.0164 Y20.2229
    N14990 G0 Z1.0000
    N14995 X128.3643 Y23.5461
    N15000 Z0.0000
    N15005 G1 X129.5986 Y22.2168
    N15010 G0 Z1.0000
    N15015 X128.3643 Y23.5461
    N15020 Z0.0000
    N15025 G1 X128.2692 Y23.6410
    N15030 X128.0796
    N15035 Y23.5461
    N15040 X127.6998 Y23.2612
    N15045 X127.4151 Y22.9763
    N15050 X126.9403 Y22.6916
    N15055 X126.6556 Y22.4066
    N15060 X125.8956 Y21.8370
    N15065 X125.5159 Y21.5523
    N15070 X125.1361 Y21.2674
    N15075 G0 Z1.0000
    N15080 Y20.8876
    N15085 Z0.0000
    N15090 G1 X125.0415 Y20.9826
    N15095 Y21.1725
    N15100 X125.1361 Y21.2674
    N15105 G0 Z1.0000
    N15110 Y20.8876
    N15115 Z0.0000
    N15120 G1 X126.1808 Y19.4634
    N15125 X126.3704 Y19.1787
    N15130 X126.5605 Y18.8938
    N15135 X126.7502 Y18.5140
    N15140 X126.9403 Y18.1342
    N15145 X127.0353 Y17.7545
    N15150 X127.1300 Y17.4696
    N15155 X127.2250 Y16.9950
    N15160 X127.4151 Y16.5202
    N15165 Y16.1404
    N15170 Y15.6656
    N15175 X127.3200 Y15.5708
    N15180 X127.2250 Y15.4757
    N15185 X127.0353 Y15.3809
    N15190 X126.8452 Y15.1910
    N15195 X126.7502 Y15.0960
    N15200 X126.6556
    N15205 X126.4655 Y15.0011
    N15210 G0 Z1.0000
    N15215 X123.2373 Y17.3747
    N15220 Z0.0000
    N15225 G1 X123.5220 Y17.0898
    N15230 X123.9968 Y16.5202
    N15235 X124.3766 Y16.2354
    N15240 X124.5667 Y16.0454
    N15245 X125.2312 Y15.5708
    N15250 X125.7060 Y15.2858
    N15255 X126.0857 Y15.0960
    N15260 X126.4655 Y15.0011
    N15265 G0 Z1.0000
    N15270 X122.1931 Y18.7989
    N15275 Z0.0000
    N15280 G1 X123.2373 Y17.3747
    N15285 G0 Z1.0000
    N15290 X122.1931 Y18.7989
    N15295 Z0.0000
    N15300 G1 Y18.8938
    N15305 X122.0980
    N15310 X122.0030
    N15315 X121.9084
    N15320 X121.1484 Y18.4190
    N15325 X120.3889 Y17.8493
    N15330 X119.6294 Y17.3747
    N15335 X118.7748 Y16.8999
    N15340 G40
    N15345 X118.6802
    N15350 G0 Z1.0000
    N15355 X18.8940 Y121.9080
    N15360 G1 Z0.0000
    N15365 G42
    N15370 Y122.0030
    N15375 Y122.0978
    N15380 G40
    N15385 X18.7989 Y122.1929
    N15390 G0 Z1.0000
    N15395 X19.4636 Y126.1806
    N15400 G1 Z0.0000
    N15405 G42
    N15410 X20.9826 Y125.1361
    N15415 G0 Z1.0000
    N15420 X15.6658 Y127.5097
    N15425 Z0.0000
    N15430 G1 X16.0456 Y127.4149
    N15435 X16.5204
    N15440 X17.3749 Y127.2248
    N15445 X17.7547 Y127.0349
    N15450 X18.1344 Y126.9401
    N15455 X18.5142 Y126.7502
    N15460 X19.1787 Y126.3704
    N15465 X19.4636 Y126.1806
    N15470 G0 Z1.0000
    N15475 X15.6658 Y127.5097
    N15480 Z0.0000
    N15485 G1 X15.5710 Y127.3198
    N15490 X15.4759 Y127.2248
    N15495 X15.3811 Y127.1300
    N15500 X15.2860 Y127.0349
    N15505 X15.1912 Y126.8450
    N15510 X15.0013 Y126.6552
    N15515 X14.9063 Y126.5603
    N15520 X15.2860 Y125.7058
    N15525 X15.4759 Y125.3260
    N15530 X15.7608 Y124.9462
    N15535 X15.9507 Y124.5665
    N15540 X16.2354 Y124.2816
    N15545 X16.8051 Y123.7119
    N15550 X17.3749 Y123.2371
    N15555 G40
    N15560 X18.7989 Y122.1929
    N15565 G0 Z1.0000
    N15570 X75.4806 Y99.2164
    N15575 G1 Z0.0000
    N15580 G42
    N15585 X75.3856 Y97.8872
    N15590 X75.2907 Y97.1275
    N15595 X75.1957 Y96.4630
    N15600 X75.0058 Y95.7984
    N15605 X74.8159 Y95.1339
    N15610 X74.6260 Y94.5642
    N15615 X74.3413 Y93.9944
    N15620 X73.7715 Y92.9502
    N15625 G0 Z1.0000
    N15630 X75.4806 Y132.9216
    N15635 Z0.0000
    N15640 G1 Y130.7379
    N15645 Y121.7181
    N15650 Y99.2164
    N15655 G0 Z1.0000
    N15660 X62.7580 Y142.7007
    N15665 Z0.0000
    N15670 G1 X63.3277 Y142.7958
    N15675 X63.8025 Y142.8906
    N15680 X65.5114 Y143.0805
    N15685 X66.6507 Y142.9856
    N15690 X67.2205 Y142.8906
    N15695 X67.7902 Y142.7958
    N15700 X68.3598 Y142.6059
    N15705 X68.8344 Y142.4160
    N15710 X69.8788 Y141.9412
    N15715 X70.4485 Y141.7513
    N15720 X70.9233 Y141.3716
    N15725 X71.3030 Y141.0866
    N15730 X71.7776 Y140.7069
    N15735 X72.2524 Y140.4222
    N15740 X73.3917 Y139.0928
    N15745 X73.6766 Y138.7130
    N15750 X74.0564 Y138.2384
    N15755 X74.3413 Y137.6688
    N15760 X74.6260 Y137.1940
    N15765 X74.8159 Y136.7192
    N15770 X75.0058 Y136.1496
    N15775 X75.1957 Y135.5799
    N15780 X75.2907 Y135.0103
    N15785 X75.3856 Y134.4406
    N15790 X75.4806 Y133.9658
    N15795 Y133.4912
    N15800 Y132.9216
    N15805 G0 Z1.0000
    N15810 X74.3413 Y133.0164
    N15815 Z0.0000
    N15820 G1 Y133.5861
    N15825 X74.2463 Y134.1557
    N15830 X74.1512 Y134.8204
    N15835 X74.0564 Y135.3900
    N15840 X73.6766 Y136.5293
    N15845 X73.3917 Y137.0990
    N15850 X73.1070 Y137.5738
    N15855 X72.8221 Y138.1434
    N15860 X71.9677 Y139.0928
    N15865 X71.5880 Y139.4726
    N15870 X71.1132 Y139.8523
    N15875 X70.6384 Y140.2323
    N15880 X69.5941 Y140.8968
    N15885 X69.1193 Y141.1817
    N15890 X68.5497 Y141.3716
    N15895 X67.9800 Y141.5614
    N15900 X67.4102 Y141.7513
    N15905 X66.7457 Y141.8462
    N15910 X65.5114 Y141.9412
    N15915 X65.0366
    N15920 X64.3721
    N15925 X63.8973 Y141.8462
    N15930 X63.4227 Y141.7513
    N15935 X63.0430 Y141.6565
    N15940 X62.9479 Y141.7513
    N15945 Y141.8462
    N15950 Y141.9412
    N15955 X62.8531 Y142.0362
    N15960 Y142.1311
    N15965 Y142.2259
    N15970 Y142.3210
    N15975 X62.7580 Y142.4160
    N15980 Y142.6059
    N15985 Y142.7007
    N15990 G0 Z1.0000
    N15995 X74.3413 Y99.2164
    N16000 Z0.0000
    N16005 G1 Y116.1163
    N16010 Y133.0164
    N16015 G0 Z1.0000
    N16020 X75.4806 Y99.2164
    N16025 Z0.0000
    N16030 G1 X75.0058
    N16035 X74.9110
    N16040 X74.3413
    N16045 G0 Z1.0000
    N16050 X73.7715 Y92.9502
    N16055 Z0.0000
    N16060 G1 X73.2969 Y93.2349
    N16065 X73.2018 Y93.3299
    N16070 X73.1070
    N16075 X72.9171 Y93.5198
    N16080 X72.8221
    N16085 X73.1070 Y94.0894
    N16090 X73.8665 Y95.7984
    N16095 X74.0564 Y96.4630
    N16100 X74.1512 Y97.1275
    N16105 X74.2463 Y97.6023
    N16110 X74.3413 Y98.1720
    N16115 Y98.7416
    N16120 G40
    N16125 Y99.2164
    N16130 G0 Z1.0000
    N16135 X55.0676 Y149.9166
    N16140 G1 Z0.0000
    N16145 G42
    N16150 Y149.8215
    N16155 X54.2130 Y149.5368
    N16160 X53.3587 Y149.2519
    N16165 X52.5041 Y148.8721
    N16170 X51.6496 Y148.4924
    N16175 X51.4597
    N16180 Y148.5872
    N16185 G0 Z1.0000
    N16190 X50.7002 Y150.2963
    N16195 Z0.0000
    N16200 G1 X51.4597 Y148.5872
    N16205 G0 Z1.0000
    N16210 X47.9468 Y153.2396
    N16215 Z0.0000
    N16220 G1 X48.4214 Y153.0497
    N16225 X48.7063 Y152.7648
    N16230 X49.3710 Y152.1951
    N16235 X49.6557 Y151.9104
    N16240 X49.8456 Y151.5306
    N16245 X50.1305 Y151.2457
    N16250 X50.7002 Y150.2963
    N16255 G0 Z1.0000
    N16260 X47.9468 Y153.2396
    N16265 Z0.0000
    N16270 G1 X47.8520
    N16275 X47.7569 Y153.1445
    N16280 X47.4720 Y153.0497
    N16285 X47.3772 Y152.9546
    N16290 X47.1873
    N16295 X46.9024 Y152.8598
    N16300 Y152.3850
    N16305 X46.8075 Y151.9104
    N16310 Y151.4356
    N16315 X46.9024 Y150.5810
    N16320 Y150.2013
    N16325 X46.9974 Y149.8215
    N16330 X47.0922 Y149.5368
    N16335 X47.2821 Y149.1570
    N16340 X47.3772 Y148.7773
    N16345 X48.1367 Y147.1632
    N16350 G0 Z1.0000
    N16355 X47.9468 Y146.8783
    N16360 Z0.0000
    N16365 G1 X48.0416 Y146.9731
    N16370 X48.1367 Y147.0682
    N16375 Y147.1632
    N16380 G0 Z1.0000
    N16385 X47.9468 Y146.8783
    N16390 Z0.0000
    N16395 G1 X47.8520
    N16400 X47.0922 Y146.4985
    N16405 X46.2379 Y146.0237
    N16410 X45.3833 Y145.6440
    N16415 X44.6238 Y145.1694
    N16420 X44.4339
    N16425 X44.3389 Y145.2642
    N16430 G0 Z1.0000
    N16435 X43.4845 Y146.7834
    N16440 Z0.0000
    N16445 G1 X44.3389 Y145.2642
    N16450 G0 Z1.0000
    N16455 X40.4462 Y149.5368
    N16460 Z0.0000
    N16465 G1 X40.9208 Y149.3467
    N16470 X41.6806 Y148.8721
    N16475 X41.9653 Y148.5872
    N16480 X42.3450 Y148.3025
    N16485 X42.8198 Y147.7328
    N16490 X43.1046 Y147.4479
    N16495 X43.2944 Y147.1632
    N16500 X43.4845 Y146.7834
    N16505 G0 Z1.0000
    N16510 X40.4462 Y149.5368
    N16515 Z0.0000
    N16520 G1 X40.3512 Y149.4418
    N16525 X39.4968 Y148.9670
    N16530 Y148.4924
    N16535 Y148.0176
    N16540 Y147.6378
    N16545 X39.5917 Y147.1632
    N16550 X39.7816 Y146.4037
    N16555 X39.9714 Y146.0237
    N16560 X40.0665 Y145.6440
    N16565 X40.2564 Y145.3592
    N16570 X40.3512 Y144.9795
    N16575 X41.2058 Y143.4602
    N16580 G0 Z1.0000
    N16585 Y143.1755
    N16590 Z0.0000
    N16595 G1 X41.3008 Y143.2704
    N16600 Y143.3654
    N16605 X41.2058 Y143.4602
    N16610 G0 Z1.0000
    N16615 Y143.1755
    N16620 Z0.0000
    N16625 G1 X41.1109 Y143.0805
    N16630 X40.2564 Y142.6059
    N16635 X39.4968 Y142.1311
    N16640 X38.7373 Y141.6565
    N16645 X38.0726 Y141.0866
    N16650 X37.8828
    N16655 X37.6929 Y141.1817
    N16660 G0 Z1.0000
    N16665 X36.6484 Y142.6059
    N16670 Z0.0000
    N16675 G1 X37.6929 Y141.1817
    N16680 G0 Z1.0000
    N16685 X33.4203 Y145.0743
    N16690 Z0.0000
    N16695 G1 X34.2748 Y144.6946
    N16700 X34.6546 Y144.5047
    N16705 X35.0344 Y144.2198
    N16710 X35.3193 Y144.0301
    N16715 X35.6990 Y143.7452
    N16720 X35.9838 Y143.4602
    N16725 X36.1736 Y143.1755
    N16730 X36.4586 Y142.8906
    N16735 X36.6484 Y142.6059
    N16740 G0 Z1.0000
    N16745 X33.4203 Y145.0743
    N16750 Z0.0000
    N16755 G1 X33.3254 Y144.9795
    N16760 X33.1356 Y144.7896
    N16765 X32.9457 Y144.6946
    N16770 X32.8506 Y144.5995
    N16775 X32.7558 Y144.5047
    N16780 X32.6608 Y144.4098
    N16785 X32.4709 Y144.3148
    N16790 X32.5659 Y143.9350
    N16795 Y143.4602
    N16800 X32.8506 Y142.6059
    N16805 X33.1356 Y141.8462
    N16810 X33.2304 Y141.4664
    N16815 X33.8000 Y140.5170
    N16820 X34.8445 Y139.0928
    N16825 G0 Z1.0000
    N16830 X34.7496 Y138.8081
    N16835 Z0.0000
    N16840 G1 X34.8445
    N16845 Y138.9029
    N16850 Y138.9980
    N16855 Y139.0928
    N16860 G0 Z1.0000
    N16865 X34.7496 Y138.8081
    N16870 Z0.0000
    N16875 G1 X34.6546 Y138.7130
    N16880 X32.5659 Y137.0041
    N16885 X31.9012 Y136.4345
    N16890 X31.8064
    N16895 Y136.3394
    N16900 X31.7114
    N16905 X31.6165 Y136.4345
    N16910 G0 Z1.0000
    N16915 X30.4770 Y137.7636
    N16920 Z0.0000
    N16925 G1 X31.6165 Y136.4345
    N16930 G0 Z1.0000
    N16935 X26.8693 Y139.8523
    N16940 Z0.0000
    N16945 G1 X27.7237 Y139.5676
    N16950 X28.1985 Y139.3777
    N16955 X28.9580 Y138.9980
    N16960 X29.2429 Y138.8081
    N16965 X29.5276 Y138.5232
    N16970 X29.8126 Y138.3333
    N16975 X30.4770 Y137.7636
    N16980 G0 Z1.0000
    N16985 X26.8693 Y139.8523
    N16990 Z0.0000
    N16995 G1 X26.6792 Y139.6626
    N17000 X26.5844 Y139.5676
    N17005 X26.3945 Y139.3777
    N17010 X26.2995 Y139.1878
    N17015 X26.1096 Y139.0928
    N17020 X26.0148 Y138.9980
    N17025 X26.2046 Y138.1434
    N17030 X26.2995 Y137.6688
    N17035 X26.4894 Y137.2890
    N17040 X26.6792 Y136.9093
    N17045 X27.2491 Y135.9597
    N17050 X27.7237 Y135.3900
    N17055 X28.8630 Y134.0609
    N17060 G0 Z1.0000
    N17065 Y133.6811
    N17070 Z0.0000
    N17075 G1 X28.9580 Y133.7760
    N17080 Y133.8710
    N17085 Y133.9658
    N17090 X28.8630 Y134.0609
    N17095 G0 Z1.0000
    N17100 Y133.6811
    N17105 Z0.0000
    N17110 G1 X28.5782 Y133.3962
    N17115 X26.2046 Y131.1176
    N17120 Y131.0226
    N17125 X26.1096
    N17130 X26.0148
    N17135 G0 Z1.0000
    N17140 X24.5906 Y132.2569
    N17145 Z0.0000
    N17150 G1 X26.0148 Y131.0226
    N17155 G0 Z1.0000
    N17160 X20.9826 Y133.9658
    N17165 Z0.0000
    N17170 G1 X21.8372 Y133.7760
    N17175 X22.6918 Y133.4912
    N17180 X23.0715 Y133.3014
    N17185 X23.7360 Y132.9216
    N17190 X24.0209 Y132.7315
    N17195 X24.3056 Y132.5418
    N17200 X24.5906 Y132.2569
    N17205 G0 Z1.0000
    N17210 X20.9826 Y133.9658
    N17215 Z0.0000
    N17220 G1 X20.7928 Y133.8710
    N17225 X20.6979 Y133.6811
    N17230 X20.4130 Y133.3962
    N17235 X20.3182 Y133.3014
    N17240 X20.1283 Y133.1115
    N17245 X20.3182 Y132.6367
    N17250 X20.4130 Y132.1621
    N17255 X20.6029 Y131.7821
    N17260 X20.7928 Y131.4024
    N17265 X21.2676 Y130.7379
    N17270 X21.6473 Y130.1682
    N17275 X22.2170 Y129.5984
    N17280 X23.5461 Y128.3643
    N17285 G0 Z1.0000
    N17290 X23.6412 Y128.0794
    N17295 Z0.0000
    N17300 G1 Y128.1744
    N17305 Y128.2692
    N17310 Y128.3643
    N17315 X23.5461
    N17320 G0 Z1.0000
    N17325 X23.6412 Y128.0794
    N17330 Z0.0000
    N17335 G1 X23.2614 Y127.6996
    N17340 X22.9765 Y127.4149
    N17345 X22.4068 Y126.6552
    N17350 X22.0271 Y126.2754
    N17355 X21.4574 Y125.5159
    N17360 X21.2676 Y125.2310
    N17365 Y125.1361
    N17370 X21.0777
    N17375 G40
    N17380 X20.9826
    N17385 G0 Z1.0000
    N17390 X93.6148 Y87.1585
    N17395 G1 Z0.0000
    N17400 G42
    N17405 X93.2351 Y87.3484
    N17410 X92.8553 Y87.5383
    N17415 X92.5706 Y87.8232
    N17420 X92.1908 Y88.1079
    N17425 X91.9057 Y88.2978
    N17430 X91.6210 Y88.5827
    N17435 X91.3363 Y88.8674
    N17440 X91.0516 Y89.1524
    N17445 X90.7664 Y89.4373
    N17450 X90.6714 Y89.3422
    N17455 X90.5768
    N17460 Y89.2472
    N17465 X90.4817 Y89.1524
    N17470 X90.3867
    N17475 G40
    N17480 Y89.0573
    N17485 G0 Z1.0000
    N17490 X90.7664 Y89.4373
    N17495 G1 Z0.0000
    N17500 G42
    N17505 X90.4817 Y89.7220
    N17510 X90.3867 Y89.8170
    N17515 X90.0069 Y90.1968
    N17520 X89.9119 Y90.2916
    N17525 X89.8172 Y90.4815
    N17530 X89.6272 Y90.5766
    N17535 X89.5321 Y90.6714
    N17540 G40
    N17545 X89.4375 Y90.7664
    N17550 G0 Z1.0000
    N17555 G1 Z0.0000
    N17560 G42
    N17565 X89.2474 Y90.5766
    N17570 X89.1524 Y90.4815
    N17575 X89.0577
    N17580 Y90.3867
    N17585 G0 Z1.0000
    N17590 X89.4375 Y90.7664
    N17595 Z0.0000
    N17600 G1 X88.3928 Y91.8109
    N17605 X87.9180 Y92.3803
    N17610 X87.7284 Y92.6652
    N17615 X87.5383 Y92.9502
    N17620 X87.3486 Y93.2349
    N17625 G40
    N17630 X87.1585 Y93.5198
    N17635 G0 Z1.0000
    N17640 X99.2166 Y85.6395
    N17645 G1 Z0.0000
    N17650 G42
    N17655 X98.6468
    N17660 X98.1724
    N17665 X97.6025 Y85.7343
    N17670 X97.0327 Y85.8294
    N17675 X96.4632 Y85.9242
    N17680 X95.2289 Y86.3040
    N17685 X94.6591 Y86.5889
    N17690 X94.0896 Y86.8736
    N17695 X93.6148 Y87.1585
    N17700 X93.5198
    N17705 Y87.0637
    N17710 X93.4252 Y86.9686
    N17715 X93.3301 Y86.8736
    N17720 Y86.7788
    N17725 X93.2351 Y86.6837
    N17730 X93.1400 Y86.4938
    N17735 X93.0450 Y86.3990
    N17740 X92.9504 Y86.2091
    N17745 G0 Z1.0000
    N17750 X99.2166 Y85.6395
    N17755 Z0.0000
    N17760 G1 Y85.5444
    N17765 Y84.5000
    N17770 G0 Z1.0000
    N17775 X132.9218 Y85.6395
    N17780 Z0.0000
    N17785 G1 X116.1165
    N17790 X99.2166
    N17795 G0 Z1.0000
    N17800 X142.6059 Y97.2226
    N17805 Z0.0000
    N17810 G1 X142.5108
    N17815 X142.4162
    N17820 X142.3212 Y97.1275
    N17825 X142.2261
    N17830 X142.0364 Y97.0327
    N17835 X141.9414
    N17840 X141.8464
    N17845 X141.7513
    N17850 X141.6567 Y96.9378
    N17855 X141.7513 Y96.5581
    N17860 X141.8464 Y96.0833
    N17865 Y95.6085
    N17870 X141.9414 Y95.0388
    N17875 Y94.3742
    N17880 X141.8464 Y93.8045
    N17885 Y93.2349
    N17890 X141.7513 Y92.6652
    N17895 X141.5616 Y92.0006
    N17900 X141.1819 Y90.8613
    N17905 X140.6120 Y89.8170
    N17910 X140.2323 Y89.3422
    N17915 X139.8525 Y88.8674
    N17920 X138.9980 Y88.0131
    N17925 X138.6182 Y87.5383
    N17930 X138.0488 Y87.2534
    N17935 X137.5740 Y86.8736
    N17940 X136.5297 Y86.3040
    N17945 X135.9599 Y86.1141
    N17950 X135.3900 Y85.9242
    N17955 X134.7256 Y85.8294
    N17960 X134.1561 Y85.7343
    N17965 X133.5863 Y85.6395
    N17970 X132.9218
    N17975 G0 Z1.0000
    N17980 Y84.5000
    N17985 Z0.0000
    N17990 G1 X133.3962
    N17995 X133.9660
    N18000 X134.5359 Y84.5950
    N18005 X135.0103 Y84.6901
    N18010 X135.5801 Y84.8798
    N18015 X136.1500 Y84.9748
    N18020 X136.6244 Y85.1647
    N18025 X137.6690 Y85.6395
    N18030 X138.1434 Y85.9242
    N18035 X139.0930 Y86.5889
    N18040 X139.5678 Y86.9686
    N18045 X139.9476 Y87.3484
    N18050 X140.7071 Y88.2030
    N18055 X141.0868 Y88.5827
    N18060 X141.3716 Y89.0573
    N18065 X141.6567 Y89.5321
    N18070 X141.9414 Y90.1018
    N18075 X142.2261 Y90.5766
    N18080 X142.6059 Y91.6208
    N18085 X142.7009 Y92.1906
    N18090 X142.7960 Y92.7603
    N18095 X142.8906 Y93.3299
    N18100 X142.9856 Y94.4692
    N18105 Y95.0388
    N18110 Y95.6085
    N18115 X142.8906 Y96.1781
    N18120 X142.7960 Y96.6529
    N18125 X142.6059 Y97.2226
    N18130 G0 Z1.0000
    N18135 X99.2166 Y84.5000
    N18140 Z0.0000
    N18145 G1 X121.7183
    N18150 X130.6428
    N18155 X132.9218
    N18160 G0 Z1.0000
    N18165 X92.9504 Y86.2091
    N18170 Z0.0000
    N18175 G1 X93.9946 Y85.6395
    N18180 X94.5644 Y85.3546
    N18185 X95.1339 Y85.1647
    N18190 X95.7988 Y84.9748
    N18195 X96.4632 Y84.7849
    N18200 X97.1277 Y84.6901
    N18205 X98.4571 Y84.5000
    N18210 G40
    N18215 X99.2166
    N18220 G0 Z1.0000
    N18225 X87.1585 Y93.5198
    N18230 G1 Z0.0000
    N18235 G42
    N18240 X87.0639
    N18245 X86.8738 Y93.3299
    N18250 X86.7788
    N18255 X86.5891 Y93.2349
    N18260 X86.1143 Y92.9502
    N18265 G0 Z1.0000
    N18270 X87.1585 Y93.5198
    N18275 Z0.0000
    N18280 G1 X86.8738 Y93.9944
    N18285 X86.5891 Y94.5642
    N18290 X86.4940 Y95.0388
    N18295 X86.2093 Y95.5136
    N18300 X86.0192 Y96.1781
    N18305 X85.7345 Y97.4124
    N18310 G40
    N18315 X85.5444 Y99.2164
    N18320 G0 Z1.0000
    N18325 X74.3413 Y114.0276
    N18330 G1 Z0.0000
    N18335 G41
    N18340 X76.0502 Y114.4074
    N18345 Y113.5530
    N18350 G40
    N18355 X74.3413 Y114.0276
    N18360 G0 Z1.0000
    N18365 X85.5444
    N18370 G1 Z0.0000
    N18375 G41
    N18380 X83.9308 Y113.5530
    N18385 Y114.4074
    N18390 G40
    N18395 X85.5444 Y114.0276
    N18400 G0 Z1.0000
    N18405 X75.4806 Y132.9216
    N18410 G1 Z0.0000
    N18415 G42
    N18420 X74.5310
    N18425 X74.4362 Y133.0164
    N18430 G40
    N18435 X74.3413
    N18440 G0 Z1.0000
    N18445 X89.0577 Y90.3867
    N18450 G1 Z0.0000
    N18455 G42
    N18460 X89.2474 Y90.1968
    N18465 X89.4375 Y90.1018
    N18470 X89.9119 Y89.6270
    N18475 X90.0069 Y89.4373
    N18480 X90.1020 Y89.3422
    N18485 X90.1970 Y89.2472
    N18490 X90.3867 Y89.0573
    N18495 G0 Z1.0000
    N18500 X86.1143 Y92.9502
    N18505 Z0.0000
    N18510 G1 X86.4940 Y92.6652
    N18515 X86.7788 Y92.3803
    N18520 X87.3486 Y91.8109
    N18525 X88.2032 Y91.1462
    N18530 X89.0577 Y90.3867
    N18535 G0 Z1.0000
    N18540 X90.3867 Y89.0573
    N18545 Z0.0000
    N18550 G1 X91.4313 Y87.8232
    N18555 X92.5706 Y86.5889
    N18560 X92.9504 Y86.2091
    N18565 G0 Z1.0000
    N18570 X97.2228 Y142.7007
    N18575 Z0.0000
    N18580 G1 Y142.6059
    N18585 X97.1277 Y142.4160
    N18590 Y142.3210
    N18595 X97.0327 Y142.1311
    N18600 Y142.0362
    N18605 Y141.9412
    N18610 X96.9380 Y141.8462
    N18615 Y141.6565
    N18620 G0 Z1.0000
    N18625 X84.5002 Y132.9216
    N18630 Z0.0000
    N18635 G1 X85.4498
    N18640 X85.5444 Y133.0164
    N18645 Y133.3962
    N18650 X85.6395 Y134.3456
    N18655 X85.9242 Y135.4851
    N18660 X86.1143 Y136.1496
    N18665 X86.3990 Y136.6244
    N18670 X86.6841 Y137.1940
    N18675 X86.9688 Y137.7636
    N18680 X87.2536 Y138.2384
    N18685 X87.6333 Y138.7130
    N18690 X88.0131 Y139.1878
    N18695 X88.4879 Y139.5676
    N18700 X89.4375 Y140.3271
    N18705 X89.9119 Y140.7069
    N18710 X90.4817 Y140.9918
    N18715 X91.0516 Y141.1817
    N18720 X91.5260 Y141.4664
    N18725 X92.1908 Y141.6565
    N18730 X92.7603 Y141.7513
    N18735 X93.3301 Y141.8462
    N18740 X93.8996 Y141.9412
    N18745 X94.5644
    N18750 X95.1339
    N18755 X95.7037 Y141.8462
    N18760 X96.3682 Y141.7513
    N18765 X96.9380 Y141.6565
    N18770 G0 Z1.0000
    N18775 X84.4052 Y99.2164
    N18780 Z0.0000
    N18785 G1 X84.5002 Y98.7416
    N18790 Y98.2670
    N18795 Y97.7922
    N18800 X84.6903 Y97.0327
    N18805 X84.7849 Y96.2732
    N18810 X84.9750 Y95.7035
    N18815 X85.3548 Y94.5642
    N18820 X85.5444 Y93.9944
    N18825 X86.1143 Y92.9502
    N18830 G0 Z1.0000
    N18835 X84.5002 Y132.9216
    N18840 Z0.0000
    N18845 G1 X84.4052 Y110.4197
    N18850 Y101.4950
    N18855 Y99.2164
    N18860 G0 Z1.0000
    N18865 X97.2228 Y142.7007
    N18870 Z0.0000
    N18875 G1 X96.7480 Y142.7958
    N18880 X96.2732 Y142.8906
    N18885 X95.7037 Y142.9856
    N18890 X94.5644 Y143.0805
    N18895 X93.9946 Y142.9856
    N18900 X92.8553 Y142.8906
    N18905 X92.3805 Y142.7958
    N18910 X91.8111 Y142.7007
    N18915 X90.7664 Y142.3210
    N18920 X90.1970 Y142.0362
    N18925 X89.7222 Y141.7513
    N18930 X88.7726 Y141.1817
    N18935 X88.2978 Y140.8968
    N18940 X87.4436 Y140.1372
    N18945 X86.6841 Y139.2829
    N18950 X86.0192 Y138.3333
    N18955 X85.7345 Y137.8587
    N18960 X85.4498 Y137.2890
    N18965 X85.2597 Y136.8142
    N18970 X85.0700 Y136.2446
    N18975 X84.8800 Y135.7698
    N18980 X84.6903 Y135.2002
    N18985 Y134.6305
    N18990 X84.5002 Y134.0609
    N18995 Y133.4912
    N19000 G40
    N19005 Y132.9216
    N19010 G0 Z1.0000
    N19015 X84.4052 Y99.2164
    N19020 G1 Z0.0000
    N19025 G42
    N19030 X84.9750
    N19035 X85.0700
    N19040 X85.5444
    N19045 Y116.1163
    N19050 G40
    N19055 Y133.0164
    N19060 G0 Z1.0000
    N19065 X132.9218 Y84.5000
    N19070 G1 Z0.0000
    N19075 G42
    N19080 Y85.0698
    N19085 Y85.1647
    N19090 G40
    N19095 Y85.6395
    N19100 G0 Z1.0000
    N19105 X55.1624 Y149.8215
    N19110 G1 Z0.0000
    N19115 G42
    N19120 X55.2575 Y150.0114
    N19125 X55.3525 Y150.1064
    N19130 G40
    N19135 X55.2575
    N19140 G0 Z1.0000
    N19145 X63.8973 Y158.3665
    N19150 G1 Z0.0000
    N19155 G42
    N19160 X63.7074
    N19165 X62.7580 Y158.0816
    N19170 X62.4733 Y157.2272
    N19175 X62.3783 Y156.7524
    N19180 X62.2832 Y156.3727
    N19185 Y155.9929
    N19190 Y154.8536
    N19195 Y154.4739
    N19200 X62.3783 Y154.0939
    N19205 X62.7580 Y152.2902
    N19210 G0 Z1.0000
    N19215 X62.6630 Y152.1003
    N19220 Z0.0000
    N19225 G1 X62.7580 Y152.1951
    N19230 Y152.2902
    N19235 G0 Z1.0000
    N19240 X62.6630 Y152.1003
    N19245 Z0.0000
    N19250 G1 X62.4733 Y152.0052
    N19255 X61.6188 Y151.8154
    N19260 X60.6694 Y151.6255
    N19265 X59.8148 Y151.3406
    N19270 X58.9602 Y151.0558
    N19275 X58.8654
    N19280 X58.7704 Y151.1509
    N19285 X58.6755 Y151.2457
    N19290 G0 Z1.0000
    N19295 X58.2007 Y152.9546
    N19300 Z0.0000
    N19305 G1 X58.6755 Y151.2457
    N19310 G0 Z1.0000
    N19315 X55.8271 Y156.1828
    N19320 Z0.0000
    N19325 G1 X56.2069 Y155.8981
    N19330 X56.4918 Y155.6132
    N19335 X57.0614 Y154.9485
    N19340 X57.3464 Y154.6638
    N19345 X57.9158 Y153.6193
    N19350 X58.0108 Y153.3344
    N19355 X58.2007 Y152.9546
    N19360 G0 Z1.0000
    N19365 X55.8271 Y156.1828
    N19370 Z0.0000
    N19375 G1 X55.6372
    N19380 X55.5422
    N19385 X55.4474 Y156.0878
    N19390 X54.6878 Y155.8981
    N19395 X54.5928 Y155.4233
    N19400 X54.4980 Y154.9485
    N19405 Y154.5687
    N19410 Y154.0939
    N19415 Y153.3344
    N19420 Y152.9546
    N19425 X54.6878 Y152.1951
    N19430 X54.7827 Y151.8154
    N19435 G40
    N19440 X55.2575 Y150.1064
    N19445 G0 Z1.0000
    N19450 X77.9492 Y154.1890
    N19455 G1 Z0.0000
    N19460 G42
    N19465 X77.8542
    N19470 X75.1957 Y153.9991
    N19475 X74.2463 Y153.9042
    N19480 X74.1512
    N19485 X74.0564 Y153.9991
    N19490 X73.9616
    N19495 Y154.0939
    N19500 G0 Z1.0000
    N19505 X73.7715 Y155.8981
    N19510 Z0.0000
    N19515 G1 X73.9616 Y154.0939
    N19520 G0 Z1.0000
    N19525 X72.2524 Y159.6008
    N19530 Z0.0000
    N19535 G1 X72.4423 Y159.2211
    N19540 X72.8221 Y158.8411
    N19545 X73.0120 Y158.4614
    N19550 X73.2018 Y158.0816
    N19555 X73.5816 Y156.9423
    N19560 X73.6766 Y156.6576
    N19565 X73.7715 Y155.8981
    N19570 G0 Z1.0000
    N19575 X72.2524 Y159.6008
    N19580 Z0.0000
    N19585 G1 X72.0626
    N19590 X71.8727 Y159.5058
    N19595 X71.4929
    N19600 X71.3030
    N19605 X71.0181
    N19610 X70.6384 Y158.6514
    N19615 X70.4485 Y157.7969
    N19620 X70.3536 Y157.4171
    N19625 X70.2586 Y157.0374
    N19630 Y156.6576
    N19635 X70.1638 Y156.2778
    N19640 Y155.8981
    N19645 X70.2586 Y155.5181
    N19650 X70.4485 Y153.7142
    N19655 G0 Z1.0000
    N19660 X70.2586 Y153.5245
    N19665 Z0.0000
    N19670 G1 X70.4485 Y153.6193
    N19675 Y153.7142
    N19680 G0 Z1.0000
    N19685 X70.2586 Y153.5245
    N19690 Z0.0000
    N19695 G1 X69.7838 Y153.4294
    N19700 X69.3092 Y153.3344
    N19705 X68.8344
    N19710 X67.8850 Y153.1445
    N19715 X67.5052 Y153.0497
    N19720 X67.0304 Y152.9546
    N19725 X66.5558 Y152.8598
    N19730 X66.4608
    N19735 Y152.9546
    N19740 X66.3660
    N19745 Y153.0497
    N19750 G40
    N19755 G0 Z1.0000
    N19760 X65.8912 Y154.8536
    N19765 Z0.0000
    N19770 G1 X66.3660 Y153.0497
    N19775 G0 Z1.0000
    N19780 X153.0499 Y66.2707
    N19785 G1 Z0.0000
    N19790 G42
    N19795 X152.8598 Y66.4608
    N19800 G40
    N19805 Y66.5556
    N19810 G0 Z1.0000
    N19815 X63.9924 Y158.3665
    N19820 G1 Z0.0000
    N19825 G42
    N19830 X64.2771 Y157.9868
    N19835 X64.5620 Y157.7018
    N19840 X64.8469 Y157.3221
    N19845 X65.1316 Y156.9423
    N19850 X65.2267 Y156.5626
    N19855 X65.4166 Y156.2778
    N19860 X65.6064 Y155.8981
    N19865 X65.7013 Y155.5181
    N19870 X65.7963 Y155.1384
    N19875 G40
    N19880 X65.8912 Y154.8536
    N19885 G0 Z1.0000
    N19890 X154.0941 Y74.0562
    N19895 G1 Z0.0000
    N19900 G42
    N19905 X153.9991
    N19910 X153.9044
    N19915 Y74.1512
    N19920 G40
    N19925 Y74.2461
    N19930 G0 Z1.0000
    N19935 X152.8598 Y66.6507
    N19940 G1 Z0.0000
    N19945 G42
    N19950 X153.3346 Y69.4040
    N19955 X153.4296 Y70.2584
    N19960 X153.5247 Y70.3534
    N19965 Y70.4485
    N19970 X153.7144
    N19975 G0 Z1.0000
    N19980 X155.4235 Y70.2584
    N19985 Z0.0000
    N19990 G1 X153.7144 Y70.4485
    N19995 G0 Z1.0000
    N20000 X159.4112 Y71.1130
    N20005 Z0.0000
    N20010 G1 X159.0314 Y70.8282
    N20015 X158.6516 Y70.6382
    N20020 X158.1768 Y70.5433
    N20025 X157.7971 Y70.4485
    N20030 X157.4173 Y70.3534
    N20035 X157.0376 Y70.2584
    N20040 X156.5628
    N20045 X155.8032
    N20050 X155.4235
    N20055 G0 Z1.0000
    N20060 X159.4112 Y71.1130
    N20065 Z0.0000
    N20070 G1 Y71.2080
    N20075 X159.5058 Y71.3979
    N20080 Y71.5878
    N20085 Y71.7776
    N20090 Y72.1574
    N20095 X159.2211 Y72.5372
    N20100 X158.4616 Y73.0118
    N20105 X157.7020 Y73.3915
    N20110 X157.3223 Y73.4866
    N20115 X156.1830 Y73.7715
    N20120 X155.8032 Y73.8663
    N20125 G40
    N20130 X154.0941 Y74.0562
    N20135 G0 Z1.0000
    N20140 X141.6567 Y96.9378
    N20145 G1 Z0.0000
    N20150 X140.6120 Y99.9759
    N20155 X140.4224 Y100.7354
    N20160 X140.1372 Y101.4950
    N20165 X139.8525 Y102.2547
    N20170 X139.2831 Y103.6789
    N20175 X138.9980 Y104.4384
    N20180 X138.7132 Y105.1029
    N20185 X137.0992 Y108.7108
    N20190 X136.7194 Y109.3755
    N20195 X136.3396 Y110.0400
    N20200 X135.9599 Y110.7997
    N20205 X135.5801 Y111.4642
    N20210 X135.2004 Y112.1288
    N20215 X134.8206 Y112.7933
    N20220 X134.4408 Y113.4580
    N20225 X133.1115 Y115.4518
    N20230 X132.7317 Y116.1163
    N20235 X132.2569 Y116.7810
    N20240 X131.7825 Y117.3506
    N20245 X131.3077 Y118.0153
    N20250 X129.8833 Y119.9141
    N20255 X129.4089 Y120.4838
    N20260 X128.9341 Y121.1484
    N20265 X128.3643 Y121.7181
    N20270 X127.8895 Y122.2877
    N20275 X126.2754 Y123.9968
    N20280 X125.7060 Y124.5665
    N20285 X125.2312 Y125.1361
    N20290 X124.6617 Y125.7058
    N20295 X123.5220 Y126.7502
    N20300 X122.9526 Y127.3198
    N20305 X122.3828 Y127.8895
    N20310 X121.7183 Y128.3643
    N20315 X121.1484 Y128.8389
    N20320 X120.5790 Y129.4085
    N20325 X119.3447 Y130.3579
    N20330 X118.6802 Y130.8327
    N20335 X118.1104 Y131.3075
    N20340 X117.4459 Y131.7821
    N20345 X116.7810 Y132.2569
    N20350 X116.2116 Y132.6367
    N20355 X115.5471 Y133.1115
    N20360 X114.8822 Y133.5861
    N20365 X114.2177 Y133.9658
    N20370 X113.5532 Y134.3456
    N20375 X112.8884 Y134.8204
    N20380 X112.2239 Y135.2002
    N20385 X111.5594 Y135.5799
    N20390 X110.7999 Y135.9597
    N20395 X110.2300 Y136.3394
    N20400 X109.4705 Y136.7192
    N20405 X108.8060 Y137.0990
    N20410 X108.0465 Y137.3839
    N20415 X107.3816 Y137.7636
    N20420 X106.6221 Y138.1434
    N20425 X105.9576 Y138.4283
    N20430 X105.1981 Y138.7130
    N20435 X104.5332 Y138.9980
    N20440 X103.7737 Y139.3777
    N20445 X102.3497 Y139.9474
    N20450 X101.5902 Y140.1372
    N20455 X100.8307 Y140.4222
    N20460 X100.0712 Y140.7069
    N20465 X97.7922 Y141.3716
    N20470 X97.1277 Y141.5614
    N20475 X96.9380 Y141.6565
    N20480 G0 Z1.0000
    N20485 X78.1389 Y154.2840
    N20490 G1 Z0.0000
    N20495 G42
    N20500 Y154.1890
    N20505 X78.0439 Y154.0939
    N20510 G40
    N20515 X77.9492
    N20520 G0 Z1.0000
    N20525 X85.6395 Y153.9042
    N20530 G1 Z0.0000
    N20535 G42
    N20540 X85.5444 Y153.9991
    N20545 X82.8861 Y154.0939
    N20550 X81.9369
    N20555 X81.8419
    N20560 Y154.1890
    N20565 X81.7468 Y154.2840
    N20570 G0 Z1.0000
    N20575 Y156.0878
    N20580 Z0.0000
    N20585 G1 Y154.8536
    N20590 Y154.2840
    N20595 G0 Z1.0000
    N20600 X80.5125 Y159.9806
    N20605 Z0.0000
    N20610 G1 X80.9873 Y159.2211
    N20615 X81.3671 Y158.3665
    N20620 X81.4621 Y157.9868
    N20625 X81.7468 Y157.2272
    N20630 Y156.4675
    N20635 Y156.0878
    N20640 G0 Z1.0000
    N20645 X80.5125 Y159.9806
    N20650 Z0.0000
    N20655 G1 X79.3732
    N20660 X78.8984 Y159.2211
    N20665 X78.7088 Y158.7463
    N20670 X78.6137 Y158.3665
    N20675 X78.4236 Y157.9868
    N20680 X78.3290 Y157.6070
    N20685 X78.2340 Y157.2272
    N20690 Y156.8475
    N20695 Y156.4675
    N20700 X78.1389 Y156.0878
    N20705 Y154.8536
    N20710 G40
    N20715 Y154.2840
    N20720 G0 Z1.0000
    N20725 X142.6059 Y97.2226
    N20730 G1 Z0.0000
    N20735 G42
    N20740 X142.5108 Y97.5075
    N20745 X142.3212 Y98.2670
    N20750 X141.6567 Y100.5456
    N20755 X141.3716 Y101.3053
    N20760 X141.0868 Y102.0648
    N20765 X140.8021 Y102.8243
    N20770 X140.5170 Y103.4888
    N20775 X140.2323 Y104.2483
    N20780 X139.9476 Y105.0080
    N20785 X139.6628 Y105.7676
    N20790 X139.2831 Y106.4322
    N20795 X138.9980 Y107.1918
    N20800 X138.3335 Y108.6158
    N20805 X137.9537 Y109.3755
    N20810 X137.5740 Y110.0400
    N20815 X136.9095 Y111.4642
    N20820 X136.4347 Y112.1288
    N20825 X136.0549 Y112.8884
    N20830 X135.6752 Y113.5530
    N20835 X135.2004 Y114.2175
    N20840 X133.9660 Y116.2114
    N20845 X133.4912 Y116.8760
    N20850 X133.0164 Y117.5405
    N20855 X132.5420 Y118.2052
    N20860 X132.1623 Y118.8699
    N20865 X131.5924 Y119.4395
    N20870 X131.1176 Y120.1040
    N20875 X130.6428 Y120.7687
    N20880 X130.0734 Y121.3383
    N20885 X129.5986 Y122.0030
    N20890 X129.1238 Y122.5726
    N20895 X128.5544 Y123.1423
    N20900 X127.9845 Y123.8070
    N20905 X127.5097 Y124.3766
    N20910 X126.9403 Y124.9462
    N20915 X126.3704 Y125.5159
    N20920 X124.6617 Y127.2248
    N20925 X124.0919 Y127.6996
    N20930 X123.5220 Y128.2692
    N20935 X122.9526 Y128.8389
    N20940 X122.2881 Y129.3137
    N20945 X121.7183 Y129.7885
    N20950 X120.4840 Y130.8327
    N20955 X119.2496 Y131.7821
    N20960 X118.5852 Y132.2569
    N20965 X117.9207 Y132.7315
    N20970 X117.3508 Y133.2063
    N20975 X116.5913 Y133.6811
    N20980 X113.9330 Y135.3900
    N20985 X113.2681 Y135.8648
    N20990 X112.6036 Y136.2446
    N20995 X111.8441 Y136.6244
    N21000 X111.1796 Y137.0041
    N21005 X109.7552 Y137.7636
    N21010 X109.0908 Y138.1434
    N21015 X108.4263 Y138.5232
    N21020 X106.9068 Y139.1878
    N21025 X106.1473 Y139.4726
    N21030 X105.4828 Y139.8523
    N21035 X104.7233 Y140.1372
    N21040 X103.9638 Y140.4222
    N21045 X103.2043 Y140.7069
    N21050 X102.4448 Y140.9918
    N21055 X101.7799 Y141.2765
    N21060 X101.0204 Y141.5614
    N21065 X97.9823 Y142.5108
    N21070 G40
    N21075 X97.2228 Y142.7007
    N21080 G0 Z1.0000
    N21085 X85.9242 Y154.0939
    N21090 G1 Z0.0000
    N21095 G42
    N21100 Y153.9991
    N21105 X85.8296 Y153.9042
    N21110 G40
    N21115 X85.7345
    N21120 G0 Z1.0000
    N21125 X120.3889 Y148.9670
    N21130 G1 Z0.0000
    N21135 G42
    N21140 X120.2943 Y149.0620
    N21145 X119.4397 Y149.5368
    N21150 X119.0600 Y149.3467
    N21155 X118.3004 Y148.8721
    N21160 X117.9207 Y148.5872
    N21165 X117.6356 Y148.3025
    N21170 X117.3508 Y148.0176
    N21175 X117.1612 Y147.7328
    N21180 X116.6864 Y147.1632
    N21185 X116.4963 Y146.7834
    N21190 X115.5471 Y145.2642
    N21195 G0 Z1.0000
    N21200 X115.2620 Y145.1694
    N21205 Z0.0000
    N21210 G1 X115.3570
    N21215 X115.5471
    N21220 Y145.2642
    N21225 G0 Z1.0000
    N21230 X115.2620 Y145.1694
    N21235 Z0.0000
    N21240 G1 X115.1673 Y145.2642
    N21245 X113.5532 Y146.1188
    N21250 X111.9392 Y146.8783
    N21255 X111.8441 Y146.9731
    N21260 Y147.0682
    N21265 Y147.1632
    N21270 G0 Z1.0000
    N21275 X112.6036 Y148.7773
    N21280 Z0.0000
    N21285 G1 X111.8441 Y147.1632
    N21290 G0 Z1.0000
    N21295 X112.9834 Y152.7648
    N21300 Z0.0000
    N21305 G1 X113.1735 Y152.3850
    N21310 Y151.9104
    N21315 Y151.4356
    N21320 Y151.0558
    N21325 Y150.6761
    N21330 X112.9834 Y150.2013
    N21335 Y149.8215
    N21340 X112.7937 Y149.5368
    N21345 X112.6987 Y149.1570
    N21350 X112.6036 Y148.7773
    N21355 G0 Z1.0000
    N21360 X112.9834 Y152.7648
    N21365 Z0.0000
    N21370 G1 X112.8884 Y152.8598
    N21375 X112.5086 Y153.0497
    N21380 X112.4140 Y153.1445
    N21385 X111.9392 Y153.2396
    N21390 X111.5594 Y153.0497
    N21395 X111.1796 Y152.7648
    N21400 X110.8945 Y152.4800
    N21405 X110.6098 Y152.1951
    N21410 X110.3251 Y151.8154
    N21415 X110.1350 Y151.5306
    N21420 X109.8503 Y151.2457
    N21425 X109.6602 Y150.9608
    N21430 X109.4705 Y150.5810
    N21435 X109.2804 Y150.2013
    N21440 X108.5209 Y148.5872
    N21445 G0 Z1.0000
    N21450 X108.2362 Y148.4924
    N21455 Z0.0000
    N21460 G1 X108.4263
    N21465 X108.5209 Y148.5872
    N21470 G0 Z1.0000
    N21475 X108.2362 Y148.4924
    N21480 Z0.0000
    N21485 G1 X108.1412 Y148.5872
    N21490 X106.4324 Y149.2519
    N21495 X105.6729 Y149.5368
    N21500 X104.8184 Y149.8215
    N21505 X104.6283 Y150.0114
    N21510 Y150.1064
    N21515 G0 Z1.0000
    N21520 X105.1981 Y151.8154
    N21525 Z0.0000
    N21530 G1 X104.6283 Y150.1064
    N21535 G0 Z1.0000
    N21540 X105.1981 Y155.8981
    N21545 Z0.0000
    N21550 G1 X105.3878 Y155.4233
    N21555 X105.4828 Y154.9485
    N21560 Y154.5687
    N21565 Y153.3344
    N21570 Y152.9546
    N21575 X105.3878 Y152.5749
    N21580 Y152.1951
    N21585 X105.1981 Y151.8154
    N21590 G0 Z1.0000
    N21595 Y155.8981
    N21600 Z0.0000
    N21605 G1 X104.9130 Y155.9929
    N21610 X104.8184
    N21615 X104.5332 Y156.0878
    N21620 X104.4386
    N21625 X104.1535 Y156.1828
    N21630 X103.4890 Y155.6132
    N21635 X103.1092 Y155.3282
    N21640 X102.8245 Y154.9485
    N21645 X102.6344 Y154.6638
    N21650 X102.0650 Y153.6193
    N21655 X101.8749 Y153.2396
    N21660 X101.7799 Y152.9546
    N21665 X101.3055 Y151.2457
    N21670 G0 Z1.0000
    N21675 X100.9257 Y151.0558
    N21680 Z0.0000
    N21685 G1 X101.1154
    N21690 X101.3055 Y151.2457
    N21695 G0 Z1.0000
    N21700 X100.9257 Y151.0558
    N21705 Z0.0000
    N21710 G1 X100.5460 Y151.2457
    N21715 X100.0712 Y151.3406
    N21720 X99.5964 Y151.4356
    N21725 X99.1216 Y151.6255
    N21730 X98.7418 Y151.7203
    N21735 X98.2670 Y151.8154
    N21740 X97.7922 Y151.9104
    N21745 X97.3178 Y152.1003
    N21750 X97.2228 Y152.1951
    N21755 Y152.2902
    N21760 G0 Z1.0000
    N21765 X97.5075 Y154.0939
    N21770 Z0.0000
    N21775 G1 X97.2228 Y152.2902
    N21780 G0 Z1.0000
    N21785 X97.1277 Y158.0816
    N21790 Z0.0000
    N21795 G1 X97.3178 Y157.7018
    N21800 X97.4124 Y157.2272
    N21805 X97.6025 Y156.8475
    N21810 Y156.3727
    N21815 X97.6976 Y155.9929
    N21820 Y154.8536
    N21825 X97.6025 Y154.4739
    N21830 X97.5075 Y154.0939
    N21835 G0 Z1.0000
    N21840 X97.1277 Y158.0816
    N21845 Z0.0000
    N21850 G1 X97.0327
    N21855 X96.7480 Y158.1766
    N21860 X96.5583
    N21865 X96.4632 Y158.2717
    N21870 X96.3682
    N21875 X96.0835 Y158.3665
    N21880 X95.4186 Y157.7018
    N21885 X95.1339 Y157.3221
    N21890 X94.8492 Y156.9423
    N21895 X94.6591 Y156.5626
    N21900 X94.5644 Y156.2778
    N21905 X94.3744 Y155.8981
    N21910 X94.2793 Y155.5181
    N21915 X94.1847 Y155.1384
    N21920 X93.9946 Y154.7586
    N21925 X93.7099 Y153.0497
    N21930 G0 Z1.0000
    N21935 X93.4252 Y152.8598
    N21940 Z0.0000
    N21945 G1 X93.5198
    N21950 X93.6148 Y152.9546
    N21955 Y153.0497
    N21960 X93.7099
    N21965 G0 Z1.0000
    N21970 X93.4252 Y152.8598
    N21975 Z0.0000
    N21980 G1 X92.9504 Y152.9546
    N21985 X92.4756 Y153.0497
    N21990 X92.0008 Y153.1445
    N21995 X91.5260 Y153.2396
    N22000 X91.1462 Y153.3344
    N22005 X90.1970 Y153.4294
    N22010 X89.7222 Y153.5245
    N22015 X89.6272
    N22020 X89.5321 Y153.6193
    N22025 Y153.7142
    N22030 G0 Z1.0000
    N22035 X89.7222 Y155.5181
    N22040 Z0.0000
    N22045 G1 X89.5321 Y153.7142
    N22050 G0 Z1.0000
    N22055 X88.8676 Y159.5058
    N22060 Z0.0000
    N22065 G1 X89.1524 Y159.0312
    N22070 X89.5321 Y157.7969
    N22075 X89.6272 Y157.4171
    N22080 X89.7222 Y156.6576
    N22085 Y155.8981
    N22090 Y155.5181
    N22095 G0 Z1.0000
    N22100 X88.8676 Y159.5058
    N22105 Z0.0000
    N22110 G1 X88.5829
    N22115 X88.4879
    N22120 X88.0131
    N22125 X87.9180 Y159.6008
    N22130 X87.7284
    N22135 X87.4436 Y159.2211
    N22140 X87.0639 Y158.4614
    N22145 X86.7788 Y158.0816
    N22150 X86.5891 Y157.7018
    N22155 X86.4940 Y157.3221
    N22160 X86.3990 Y156.9423
    N22165 X86.3044 Y156.6576
    N22170 X86.2093 Y156.2778
    N22175 X86.1143 Y155.8981
    N22180 G40
    N22185 X85.9242 Y154.0939
    N22190 G0 Z1.0000
    N22195 X153.7144 Y89.5321
    N22200 G1 Z0.0000
    N22205 G42
    N22210 X153.6193
    N22215 X153.5247 Y89.6270
    N22220 G40
    N22225 X153.4296 Y89.7220
    N22230 G0 Z1.0000
    N22235 X153.8094 Y74.3411
    N22240 G1 Z0.0000
    N22245 G42
    N22250 X153.9044
    N22255 X154.0941 Y77.9490
    N22260 Y78.0439
    N22265 Y78.1387
    N22270 X154.1892 Y78.2338
    N22275 X154.2842
    N22280 G0 Z1.0000
    N22285 X156.0880
    N22290 Z0.0000
    N22295 G1 X154.7586
    N22300 X154.2842
    N22305 G0 Z1.0000
    N22310 X159.9806 Y79.4681
    N22315 Z0.0000
    N22320 G1 X159.5058 Y79.1832
    N22325 X158.7463 Y78.8034
    N22330 X158.3665 Y78.6135
    N22335 X157.2272 Y78.3288
    N22340 X156.4677 Y78.2338
    N22345 X156.0880
    N22350 G0 Z1.0000
    N22355 X159.9806 Y79.4681
    N22360 Z0.0000
    N22365 G1 Y80.6074
    N22370 X159.1260 Y81.0822
    N22375 X158.7463 Y81.2720
    N22380 X157.9868 Y81.5568
    N22385 X157.6070 Y81.6518
    N22390 X157.2272
    N22395 X156.8475 Y81.7466
    N22400 X156.0880
    N22405 X154.7586
    N22410 X154.2842
    N22415 G0 Z1.0000
    N22420 X154.0941 Y82.0316
    N22425 Z0.0000
    N22430 G1 Y81.9365
    N22435 X154.1892 Y81.8417
    N22440 X154.2842 Y81.7466
    N22445 G0 Z1.0000
    N22450 X154.0941 Y82.0316
    N22455 Z0.0000
    N22460 G1 Y82.1264
    N22465 X153.9044 Y85.7343
    N22470 Y85.8294
    N22475 Y85.9242
    N22480 X153.9991
    N22485 X154.0941 Y86.0192
    N22490 G0 Z1.0000
    N22495 X155.8032 Y86.2091
    N22500 Z0.0000
    N22505 G1 X154.0941 Y86.0192
    N22510 G0 Z1.0000
    N22515 X159.5058 Y87.8232
    N22520 Z0.0000
    N22525 G1 X159.2211 Y87.5383
    N22530 X158.8413 Y87.2534
    N22535 X158.4616 Y86.9686
    N22540 X158.0818 Y86.7788
    N22545 X157.7020 Y86.6837
    N22550 X157.3223 Y86.4938
    N22555 X156.9425 Y86.3990
    N22560 X156.5628 Y86.3040
    N22565 X155.8032 Y86.2091
    N22570 G0 Z1.0000
    N22575 X159.5058 Y87.8232
    N22580 Z0.0000
    N22585 G1 Y88.2030
    N22590 Y88.3928
    N22595 Y88.6776
    N22600 X159.4112 Y88.7726
    N22605 Y88.9625
    N22610 X159.0314 Y89.1524
    N22615 X158.6516 Y89.3422
    N22620 X157.7971 Y89.6270
    N22625 X157.4173
    N22630 X156.9425 Y89.7220
    N22635 X156.1830 Y89.8170
    N22640 X155.8032 Y89.7220
    N22645 X155.4235
    N22650 G40
    N22655 X153.7144 Y89.5321
    N22660 G0 Z1.0000
    N22665 X147.1634 Y111.8439
    N22670 G1 Z0.0000
    N22675 G42
    N22680 X146.9733
    N22685 G40
    N22690 X146.8783 Y111.9390
    N22695 G0 Z1.0000
    N22700 X153.4296 Y89.8170
    N22705 G1 Z0.0000
    N22710 G42
    N22715 Y89.9119
    N22720 X153.0499 Y92.5704
    N22725 X152.8598 Y93.4248
    N22730 Y93.5198
    N22735 X152.9548 Y93.6146
    N22740 Y93.7097
    N22745 X153.0499
    N22750 G0 Z1.0000
    N22755 X154.7586 Y94.0894
    N22760 Z0.0000
    N22765 G1 X153.0499 Y93.7097
    N22770 G0 Z1.0000
    N22775 X158.2719 Y96.0833
    N22780 Z0.0000
    N22785 G1 X157.9868 Y95.7035
    N22790 X157.3223 Y95.1339
    N22795 X156.9425 Y94.9440
    N22800 X156.5628 Y94.7539
    N22805 X156.1830 Y94.5642
    N22810 X155.8983 Y94.3742
    N22815 X155.5185 Y94.2793
    N22820 X155.2334 Y94.1845
    N22825 X154.7586 Y94.0894
    N22830 G0 Z1.0000
    N22835 X158.2719 Y96.0833
    N22840 Z0.0000
    N22845 G1 Y96.1781
    N22850 X158.1768 Y96.4630
    N22855 Y96.6529
    N22860 X158.0818 Y96.9378
    N22865 Y97.0327
    N22870 Y97.2226
    N22875 X157.2272 Y97.5075
    N22880 X156.3727 Y97.6974
    N22885 X155.8983
    N22890 X155.2334
    N22895 X153.9991 Y97.6023
    N22900 X152.2904 Y97.2226
    N22905 G0 Z1.0000
    N22910 X152.0052 Y97.4124
    N22915 Z0.0000
    N22920 G1 Y97.3176
    N22925 X152.1003
    N22930 X152.1953 Y97.2226
    N22935 X152.2904
    N22940 G0 Z1.0000
    N22945 X152.0052 Y97.4124
    N22950 Z0.0000
    N22955 G1 X151.9106 Y97.7922
    N22960 X151.8156 Y98.2670
    N22965 X151.7205 Y98.7416
    N22970 X151.5308 Y99.2164
    N22975 X151.4358 Y99.5962
    N22980 X151.3408 Y100.0710
    N22985 X151.2457 Y100.5456
    N22990 X151.0560 Y101.0204
    N22995 Y101.2102
    N23000 X151.1511
    N23005 X151.2457 Y101.3053
    N23010 G0 Z1.0000
    N23015 X152.8598 Y101.7799
    N23020 Z0.0000
    N23025 G1 X151.2457 Y101.3053
    N23030 G0 Z1.0000
    N23035 X156.1830 Y104.1535
    N23040 Z0.0000
    N23045 G1 X155.8983 Y103.7737
    N23050 X155.6132 Y103.4888
    N23055 X154.9487 Y102.9192
    N23060 X154.6640 Y102.6344
    N23065 X154.2842 Y102.4446
    N23070 X153.9044 Y102.2547
    N23075 X153.2396 Y101.9698
    N23080 X152.8598 Y101.7799
    N23085 G0 Z1.0000
    N23090 X156.1830 Y104.1535
    N23095 Z0.0000
    N23100 G1 Y104.2483
    N23105 X155.8032 Y105.2928
    N23110 X154.9487 Y105.4826
    N23115 X154.4739
    N23120 X154.0941 Y105.5777
    N23125 X153.7144
    N23130 X153.2396 Y105.4826
    N23135 X152.4800 Y105.3878
    N23140 X152.1953 Y105.2928
    N23145 X151.8156 Y105.1979
    N23150 X150.1064 Y104.6283
    N23155 G0 Z1.0000
    N23160 X149.8217 Y104.8182
    N23165 Z0.0000
    N23170 G1 X149.9168 Y104.7231
    N23175 X150.0114 Y104.6283
    N23180 X150.1064
    N23185 G0 Z1.0000
    N23190 X149.8217 Y104.8182
    N23195 Z0.0000
    N23200 G1 X149.7267 Y104.9130
    N23205 X149.4420 Y105.7676
    N23210 X149.1572 Y106.6219
    N23215 X148.7775 Y107.4765
    N23220 X148.4924 Y108.3310
    N23225 Y108.4261
    N23230 Y108.5209
    N23235 X148.5874 Y108.6158
    N23240 G0 Z1.0000
    N23245 X150.2015 Y109.2804
    N23250 Z0.0000
    N23255 G1 X148.5874 Y108.6158
    N23260 G0 Z1.0000
    N23265 X153.2396 Y112.0338
    N23270 Z0.0000
    N23275 G1 X153.0499 Y111.6540
    N23280 X152.7652 Y111.2743
    N23285 X152.4800 Y110.8945
    N23290 X152.1003 Y110.6096
    N23295 X151.5308 Y110.1350
    N23300 X151.2457 Y109.8501
    N23305 X150.2015 Y109.2804
    N23310 G0 Z1.0000
    N23315 X153.2396 Y112.0338
    N23320 Z0.0000
    N23325 G1 Y112.1288
    N23330 X153.1449 Y112.2237
    N23335 X153.0499 Y112.5086
    N23340 X152.9548 Y112.6034
    N23345 X152.8598 Y112.7933
    N23350 Y113.0782
    N23355 X152.2904
    N23360 X151.9106 Y113.1733
    N23365 X150.9610
    N23370 X150.2015 Y113.0782
    N23375 X149.4420 Y112.8884
    N23380 X149.0622 Y112.6985
    N23385 X148.7775 Y112.6034
    N23390 G40
    N23395 X147.1634 Y111.8439
    N23400 G0 Z1.0000
    N23405 X121.9084 Y141.1817
    N23410 G1 Z0.0000
    N23415 G42
    N23420 X121.8133
    N23425 X121.0538 Y141.7513
    N23430 X118.7748 Y143.1755
    N23435 X118.6802 Y143.2704
    N23440 Y143.3654
    N23445 Y143.4602
    N23450 G40
    N23455 G0 Z1.0000
    N23460 X119.6294 Y144.9795
    N23465 Z0.0000
    N23470 G1 X118.6802 Y143.4602
    N23475 G0 Z1.0000
    N23480 X122.1931 Y141.1817
    N23485 G1 Z0.0000
    N23490 G42
    N23495 Y141.0866
    N23500 G40
    N23505 X121.9084
    N23510 G0 Z1.0000
    N23515 X146.7836 Y111.9390
    N23520 G1 Z0.0000
    N23525 G42
    N23530 Y112.0338
    N23535 X146.4039 Y112.8884
    N23540 X145.9291 Y113.7427
    N23545 X145.5493 Y114.5024
    N23550 X145.1696 Y115.2620
    N23555 Y115.4518
    N23560 Y115.5469
    N23565 X145.2642 Y115.6417
    N23570 G0 Z1.0000
    N23575 X146.7836 Y116.4963
    N23580 Z0.0000
    N23585 G1 X145.2642 Y115.6417
    N23590 G0 Z1.0000
    N23595 X149.5370 Y119.4395
    N23600 Z0.0000
    N23605 G1 X149.3469 Y119.0598
    N23610 X149.0622 Y118.6800
    N23615 X148.7775 Y118.3002
    N23620 X148.4924 Y118.0153
    N23625 X148.3027 Y117.6356
    N23630 X148.0180 Y117.4457
    N23635 X147.7328 Y117.1608
    N23640 X147.4481 Y116.8760
    N23645 X146.7836 Y116.4963
    N23650 G0 Z1.0000
    N23655 X149.5370 Y119.4395
    N23660 Z0.0000
    N23665 G1 X149.4420 Y119.6294
    N23670 X149.3469 Y119.7242
    N23675 X149.2519 Y119.8193
    N23680 Y120.0092
    N23685 X149.1572 Y120.1040
    N23690 X149.0622 Y120.1990
    N23695 X148.9672 Y120.3889
    N23700 Y120.4838
    N23705 X148.4924
    N23710 X148.1126
    N23715 X147.5432
    N23720 X147.1634 Y120.3889
    N23725 X146.4039 Y120.1990
    N23730 X146.0241 Y120.1040
    N23735 X145.7390 Y119.9141
    N23740 X145.2642 Y119.8193
    N23745 X144.9795 Y119.6294
    N23750 X143.4604 Y118.6800
    N23755 G0 Z1.0000
    N23760 X143.1757 Y118.7748
    N23765 Z0.0000
    N23770 G1 Y118.6800
    N23775 X143.4604
    N23780 G0 Z1.0000
    N23785 X143.1757 Y118.7748
    N23790 Z0.0000
    N23795 G1 X142.8906 Y119.1546
    N23800 X142.6059 Y119.6294
    N23805 X142.1311 Y120.3889
    N23810 X141.8464 Y120.7687
    N23815 X141.6567 Y121.1484
    N23820 X141.3716 Y121.5282
    N23825 X141.0868 Y121.9080
    N23830 Y122.0030
    N23835 Y122.0978
    N23840 X141.1819 Y122.1929
    N23845 G0 Z1.0000
    N23850 X142.6059 Y123.2371
    N23855 Z0.0000
    N23860 G1 X141.1819 Y122.1929
    N23865 G0 Z1.0000
    N23870 X144.9795 Y126.5603
    N23875 Z0.0000
    N23880 G1 X144.5997 Y125.7058
    N23885 X144.4100 Y125.3260
    N23890 X144.2200 Y124.9462
    N23895 X144.0303 Y124.5665
    N23900 X143.7452 Y124.2816
    N23905 X143.4604 Y123.9968
    N23910 X143.1757 Y123.7119
    N23915 X142.8906 Y123.5220
    N23920 X142.6059 Y123.2371
    N23925 G0 Z1.0000
    N23930 X144.9795 Y126.5603
    N23935 Z0.0000
    N23940 G1 X144.8844 Y126.6552
    N23945 X144.3150 Y127.4149
    N23950 X143.8402
    N23955 X143.4604
    N23960 X142.9856 Y127.3198
    N23965 X142.5108 Y127.2248
    N23970 X142.1311 Y127.0349
    N23975 X141.8464 Y126.9401
    N23980 X141.4666 Y126.7502
    N23985 X140.8021 Y126.3704
    N23990 X140.5170 Y126.1806
    N23995 X139.0930 Y125.1361
    N24000 G0 Z1.0000
    N24005 X138.7132 Y125.2310
    N24010 Z0.0000
    N24015 G1 X138.8083 Y125.1361
    N24020 X138.9980
    N24025 X139.0930
    N24030 G0 Z1.0000
    N24035 X138.7132 Y125.2310
    N24040 Z0.0000
    N24045 G1 X138.4285 Y125.5159
    N24050 X137.8587 Y126.2754
    N24055 X137.5740 Y126.6552
    N24060 X137.2892 Y127.0349
    N24065 X137.0041 Y127.4149
    N24070 X136.7194 Y127.6996
    N24075 X136.4347 Y128.0794
    N24080 X136.3396
    N24085 Y128.1744
    N24090 Y128.2692
    N24095 Y128.3643
    N24100 X136.4347
    N24105 G0 Z1.0000
    N24110 X137.7636 Y129.5984
    N24115 Z0.0000
    N24120 G1 X136.4347 Y128.3643
    N24125 G0 Z1.0000
    N24130 X139.7575 Y133.1115
    N24135 Z0.0000
    N24140 G1 X139.6628 Y132.6367
    N24145 X139.4728 Y132.1621
    N24150 X139.3777 Y131.7821
    N24155 X139.1880 Y131.4024
    N24160 X138.9980 Y131.0226
    N24165 X138.7132 Y130.7379
    N24170 X138.2384 Y130.1682
    N24175 X137.9537 Y129.8833
    N24180 X137.7636 Y129.5984
    N24185 G0 Z1.0000
    N24190 X139.7575 Y133.1115
    N24195 Z0.0000
    N24200 G1 X139.6628 Y133.2063
    N24205 X138.9980 Y133.9658
    N24210 X138.6182 Y133.8710
    N24215 X138.1434 Y133.7760
    N24220 X137.2892 Y133.4912
    N24225 X136.9095 Y133.3014
    N24230 X136.5297 Y133.1115
    N24235 X136.2446 Y132.9216
    N24240 X135.8648 Y132.7315
    N24245 X135.5801 Y132.5418
    N24250 X135.2954 Y132.2569
    N24255 X133.9660 Y131.0226
    N24260 G0 Z1.0000
    N24265 X133.6813 Y131.1176
    N24270 Z0.0000
    N24275 G1 Y131.0226
    N24280 X133.8710
    N24285 X133.9660
    N24290 G0 Z1.0000
    N24295 X133.6813 Y131.1176
    N24300 Z0.0000
    N24305 G1 X132.9218 Y131.7821
    N24310 X132.3520 Y132.4468
    N24315 X131.6875 Y133.1115
    N24320 X131.0226 Y133.6811
    N24325 Y133.7760
    N24330 Y133.9658
    N24335 Y134.0609
    N24340 G0 Z1.0000
    N24345 X132.2569 Y135.3900
    N24350 Z0.0000
    N24355 G1 X131.0226 Y134.0609
    N24360 G0 Z1.0000
    N24365 X133.8710 Y138.9980
    N24370 Z0.0000
    N24375 G1 Y138.6182
    N24380 X133.7764 Y138.1434
    N24385 X133.5863 Y137.7636
    N24390 X133.4912 Y137.2890
    N24395 X133.3016 Y136.9093
    N24400 X133.1115 Y136.6244
    N24405 X132.9218 Y136.2446
    N24410 X132.7317 Y135.9597
    N24415 X132.2569 Y135.3900
    N24420 G0 Z1.0000
    N24425 X133.8710 Y138.9980
    N24430 Z0.0000
    N24435 G1 X133.7764 Y139.1878
    N24440 X133.0164 Y139.7575
    N24445 X132.6367 Y139.6626
    N24450 X132.1623 Y139.5676
    N24455 X131.7825 Y139.3777
    N24460 X131.4028 Y139.1878
    N24465 X131.0226 Y138.9980
    N24470 X130.7379 Y138.7130
    N24475 X130.3581 Y138.5232
    N24480 X130.0734 Y138.2384
    N24485 X129.7887 Y138.0486
    N24490 X129.5986 Y137.7636
    N24495 X128.3643 Y136.4345
    N24500 G0 Z1.0000
    N24505 X128.0796
    N24510 Z0.0000
    N24515 G1 X128.1746 Y136.3394
    N24520 X128.2692
    N24525 Y136.4345
    N24530 X128.3643
    N24535 G0 Z1.0000
    N24540 X128.0796
    N24545 Z0.0000
    N24550 G1 X127.9845 Y136.5293
    N24555 X127.2250 Y137.0990
    N24560 X126.5605 Y137.6688
    N24565 X125.8956 Y138.2384
    N24570 X125.1361 Y138.8081
    N24575 X125.0415 Y138.9029
    N24580 Y138.9980
    N24585 X125.1361 Y139.0928
    N24590 G0 Z1.0000
    N24595 X126.1808 Y140.5170
    N24600 Z0.0000
    N24605 G1 X125.1361 Y139.0928
    N24610 G0 Z1.0000
    N24615 X127.4151 Y144.3148
    N24620 Z0.0000
    N24625 G1 Y143.9350
    N24630 Y143.4602
    N24635 X127.3200 Y142.9856
    N24640 X127.1300 Y142.6059
    N24645 X127.0353 Y142.2259
    N24650 X126.9403 Y141.8462
    N24655 X126.7502 Y141.4664
    N24660 X126.5605 Y141.1817
    N24665 X126.3704 Y140.8019
    N24670 X126.1808 Y140.5170
    N24675 G0 Z1.0000
    N24680 X127.4151 Y144.3148
    N24685 Z0.0000
    N24690 G1 X127.2250 Y144.4098
    N24695 X126.4655 Y144.9795
    N24700 X126.0857 Y144.8844
    N24705 X125.7060 Y144.6946
    N24710 X125.2312 Y144.4098
    N24715 X124.8514 Y144.2198
    N24720 X124.5667 Y144.0301
    N24725 X124.2820 Y143.7452
    N24730 X123.9968 Y143.4602
    N24735 X123.2373 Y142.6059
    N24740 G40
    N24745 X122.1931 Y141.1817
    N24750 G0 Z1.0000
    N24755 X120.4840 Y148.9670
    N24760 G1 Z0.0000
    N24765 G42
    N24770 Y148.0176
    N24775 X120.3889 Y147.1632
    N24780 X120.1042 Y146.0237
    N24785 X119.9145 Y145.6440
    N24790 G40
    N24795 X119.6294 Y144.9795
    N24800 G0 Z1.0000
    N24805 M5
    N24810 M30
    Dec 2008
    3122
    Rob
    Cutter comp usage can be quite tricky at times, so don't expect to be an expert after your first sucess, each toolpath you create can have it's own little series of glitches
    comp basics ( also refer to the manuals for the machine controller )
    -comp is started with the tool away from the part, the first move is typically along a line ( many controls cannot start comp on an arc- rule #1 )
    - comp is cancelled by a G40, ( by itself, or it can be with an X/Y move, - not along an arc ), you should have the tool move away from the part before cancelling
    - decide on which side ( of the profile ) you want the tool to travel, and in what direction ( ie take a circle, tool to be on the outside, travelling clockwise ), this dictates what G code to use from the G41/G42 choices
    - G41 means tool is travelling on the left side of the contour ( climb milling ), if on the outside it is a CW motion, if inside, it will be a CCW movement
    - G42 means tool is travelling on the right side of the contour ( conventional milling ), if on the outside it is a CCW motion, if inside, it will be a CW movement, you have to define the chaining direction carefully, and apply the correct G comp code.
    - never start comp on an inside corner ( ie inside a square pocket )
    - G41/G42 require a D word that holds the offset number ( ie G41 D1 , where D1 has the cutter radius value to adjust the toolpath )
    - there are various methods of programming the toolpath,
    ----- using the part's shape--- where the cutter radius is input into D1, & any internal radius on the part shape, cannot be smaller that the tool radius value in D1
    ----- using a contour that is already offset ( from the part shape ) by the tool radius & then used as the toolpath, then D1 is then set to zero,
    To adjust the toolpath on these strategies, if the D value is increased , then the toolpath is further away from the part shape. If D is decreased, then the part shape is made smaller
    NEVER mix these two stategies together for the same tool in the same program.
    the 1st strategy is the old method, or if no CAM system is used, when the comp is applied, the actual path that the tool follows is the path that is used in the 2nd strategy....
    It is best to understand which one ( CAD or machine control ) is doing the calculations to get the toolpath to make the correct size part
    Code:
    N5 (File Name = large gear on Monday, September 24, 2012)
    N10 (Default Mill Post)
    N15 G91.1
    N20 G0 Z1.0000
    N25 M3
    N30 X17.3749 Y36.7433
    N35 G1 Z0.0000 F60.00
    N40 G42 D1 <--- go & lookup the offset value ( sometimes only needed on the first use )
    N45 X16.8051 Y36.2685
    N50 X16.2354 Y35.6988
    N55 X15.9507 Y35.4141
    N60 X15.7608 Y35.0342
    N65 X15.4759 Y34.6544
    N70 X15.2860 Y34.2746
    N75 G40
    - You are conventional milling on the right side of the contour, if the path is the actual finished shape, and the profile is chaining CW, then you have stuffed the part. But if your chain is CCW, then 1/2 the battle is done....but the N30 line is actually on the part profile, your descend point will also stuff the part. you are not starting the comp away from the shape by at least the tool radius.
    - if your profile is the 2nd strategy, & as the D1 value is zero, there is no adjustments to be made, so the G41/G42 is not really required. comp is only necessary to finely adjust the toolpath to get finish size- this is when you may need to have thoes codes inserted in your program.
    I have only touched on the basic concepts, there is a lot more info to be taken in
    - read up on how comp is
    --- adjusted on internal shapes
    --- going around sharp external corners
    --- how many NC lines ahead (look ahead or buffer ), that the controller looks to plan the next series of moves. You do have lots of short moves when approaching the root radius of the teeth, so it can't see what is supposed to happen on the upside of the adjacent tooth ( this is where it is undercut ). But if the lines were replaced with longer arcs, it may be able to follow the shape better.
    Try having AutoCAD generate the tooth form using a series of arcs instead of many segmented lines, you will also notice your programs will be much shorter.
    I hope this has not made you more confused than what you already are ?...LOL
