588,542 active members*
4,895 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Tool path for multiple bosses
Results 1 to 7 of 7
    Jan 2005
    98
    Hello...one thing I really struggle with is a 2-axis tool path with multiple bosses to cut around.
    BC always wants to cut off half of the bosses when I have to use side roughing to clear the area surrounding...even when using a tool too wide to even go through the gap.
    Images shows two rough profile paths (1/2" and 1/8") with side roughing. Still not clearing the surface but cutting into both bosses....or raised letters in this case.
    Any thoughts?
    Thank you...
    Chuck
    V:28 Mill Standard
    May 2010
    62
    Re: Tool path for multiple bosses
    There's other guys that are real experts, but I'll see if I can help a little. I can't see your cam tree, and my software is different (pro). Start by making the outer profile line a dashed line. Then be sure that your geometry is all connected and trimmed, so you can chain select the bosses/islands completely.- as a chain. Then I'd use a pocketing command. I chain select the outside profile first, then select each of the bosses/islands. Then be go through the rest of menu. My apologies if you know and have done this already.
    Jan 2005
    98
    Thank you...I always draw a solid object to what I want and then program from that. Perhaps that is wrong and I should work off sketched lines. I am aware of the dashed line allowing cut through but doesn't work with solids.. So from the solid I do select all Z to get the full chain...or work off surfaces and on this I tried both...same luck.
    I tried both pocketing and profile and had best luck with profile.
    As I was re-sketching the borders of my solid to try your suggestion BC locked up so will be starting from scratch. (dummy didn't save yet). I will try without the solid and use sketches only to see how that goes.
    Thanks for the feedback...it gives me direction. Cheers....
    Apr 2009
    3376
    draw in 2 D,dashed lines on perimeter of stock,machine with advance pocketing,,,look in help menu for more
    Dec 2011
    295
    If you are looking for a zig zag pattern its in standard pocketing. Offset perimeter one tool dia. Select step over and lace angle
    Jan 2005
    98
    Quote Originally Posted by jrmach View Post
    Perfect plan Sir! Thank you very much!
    Thank you all for looking and offering support.
    Jan 2005
    98
    Truth be told my solid part lines were not perfect either so reworking those in 2D and following your guys help...got it!
  1. MasterCAM multiple pockets in one tool path group
    By nomadcnc in forum Mastercam
    Last Post: 01-19-2016, 05:40 AM
  2. Multiple tools, single path...with offsets?
    By TedHamilton in forum Alphacam
    Last Post: 11-12-2015, 04:24 PM
  3. Multiple profile operation tool path issue
    By Craigpat in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-25-2014, 09:38 PM
  4. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
  5. bosses are milling askew egg shape
    By chaz6966 in forum BobCad-Cam
    Last Post: 03-04-2009, 04:22 AM
