588,159 active members*
4,687 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > tool path problem
Results 1 to 10 of 10
    Sep 2004
    222
    tool path problem
    I basically have a square block with a boss in the middle of it. I want to use a flat endmill to rough it out. It cuts the boss way undersize and I am not sure why.
    I generated the tool path, incremented it down half the tool diameter(maybe this is where I went wrong) then inserted NC and made the program. I made sure the tool technology was right. What else did I miss?? I like to use a flat to rough with since it is faster.
    Dec 2003
    24220
    Maybe list the code here showing the code just prior to the roughing cycle?
    Al
    Albert E.
    Sep 2004
    222
    I have had this problem before. Anytime I want to use a flat to rough with, it cuts any features like a boss way undersize. I stopped doing it that way but would like to figure out how to make it work.Also is there a way to control how much rough stock is left?
    Jan 2004
    190
    acording to my cd bobcad only uses a ball mill unless I mis understood
    thanks Kenneth
    www.lambertsrc.com
    Mar 2003
    4826
    I don't know if this will help you or not. I'm getting pretty rusty on Bobcad these days. But, it seemed to me that when you were pocketing you picked the profile and then the islands (the bosses you speak of). The location of the cursor when you picked the islands was critical to the outcome you got for a toolpath. Make sure your cursor is on the outside of the islands. Even then, you need to watch where you place the cursor before you "click it" to select an island. If you have more than one island, you may need to experiment a bit with various cursor locations to get a desirable outcome.
    First you get good, then you get fast. Then grouchiness sets in.
    Sep 2004
    222
    In order to pick just the boss I would need to unstitch that part. BobCad can use flat endmills if you set up the tool on the NC side.
    Apr 2005
    1194
    You dont run cutter comp with half your cutter diameter in your tools table. You use it with the full diamter of the cutter and the comp feature splits it.....silly rabbit
    Aug 2003
    449
    fastolds,
    Try extracting the edges of your part then project them to a flat plane. Once they are 2D you may need to do a little clean-up, but afterwards you can simply use the pocket function.
    Also, which version of BobCAD are you using? Dependant upon the version you may have other options. For instance, the Spiral solid toolpath in V20 will allow you to select one profile and one island for boundary machining.
    Regards
    Sep 2004
    222
    I gave up on using Bobcad a while back. It only gets used for DNC now. Thanks for the help
    Jul 2005
    how can i generate G-code from a dxf file? what should i do with the format of the dxf file once i inserted it into the CAD side? delete or leave it? (i used solidworks as my solid modeling software). thanks
    hau
  1. efficient tool path
    By balsaman in forum Mastercam
    Last Post: 07-28-2006, 05:37 PM
  2. Laser tool path display....( IDEA )
    By ynneb in forum DIY CNC Router Table Machines
    Last Post: 04-11-2006, 04:19 AM
  3. getting tool path problem
    By kenlambert in forum BobCad-Cam
    Last Post: 01-14-2005, 09:15 PM
  4. Tool Changer Problems
    By Snel in forum Haas Mills
    Last Post: 08-11-2004, 02:56 PM
  5. tool path generation BobCAD V18/19
    By inthedark in forum BobCad-Cam
    Last Post: 02-11-2004, 04:14 AM
