Re: Tool retention with coolant
It's not drawbar tension, or coolant, as much as its speeds and feeds. 1/2" cutters seem more likely to have this issue than any other size I've used. Yes dry tool shanks will help but I don't worry about it except when I load my ATC. After that I just run it. Roughing ends mills are a blessing then its run what you need for the length to finish. Adjust your speeds and feeds for finishing you can get what you need, use roughers for clearing. I have been running production with Tormach's for almost 7yrs, and no regrets. I bought one of the first PDB and ATC as they became available. They work hands down, no regrets and glad I didn't buy another brand.
RAD. Yes those are my initials. Idea, design, build, use. It never ends.
PCNC1100 Series II, w/S3 upgrade, PDB, ATC & 4th's, PCNC1100 Series II, 4th
