603,795 active members*
2,898 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Tool Setter Calibration - Lynx 2100 LSYB w/ Oi-TF Plus Control
    May 2015
    31
    I have a new 2020 Lynx 2100 LSYB that has the new Oi-TF Plus control.
    Does anyone have instructions on how to calibrate the tool setter? I would call Ellison, but it is the day before thanksgiving and no one is answering the phone.
    There is a ten year old thread on this subject that talks about what numbers go in which parameters, but I am not confident those parameter addresses are the same for this new control.
    Thank You!
    Feb 2013
    796
    Re: Tool Setter Calibration - Lynx 2100 LSYB w/ Oi-TF Plus Control
    I just called and they picked up on 2 rings...
    Unless Fanuc has changed their parameter, or the write-up is not for a Fanuc, it will work.
    Your instruction Manual that came with the machine has replacement process, as well.
    The attached is the Installation Manual for a Lynx 220. The process is on page 28
    Doosan Service Technician
    darryl.hardt@doosanmt.com O:973-618-2461 M:973-803-9479
    May 2015
    31
    Thank you very much for the reply. About 30 minutes after I made the post I made another call, and they did answer. They put in a case number for someone to get back with me. I might have called too early since I called right at 8:30am local. I looked in the instruction manual, but I did not see it. I will look again though. I really appreciate your help.
    Thank You!
    Darryl
  1. Replies: 2
    Last Post: 05-08-2018, 07:47 AM
  2. Lynx 300 Tool setter and work offset questions
    By cruizer67 in forum Daewoo/Doosan
    Last Post: 06-06-2016, 07:24 PM
  3. Lynx Q-Setter
    By M5Boost in forum Daewoo/Doosan
    Last Post: 08-28-2014, 12:29 AM
  4. Hyundai tool setter calibration
    By Dr Evil in forum Hyundai Kia
    Last Post: 04-25-2011, 10:46 PM
  5. Pre-Setter "Tool Eye" calibration?
    By SmokinErb in forum Mori Seiki lathes
    Last Post: 03-15-2008, 02:00 PM
