603,373 active members*
4,230 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > TOOL settings, basic questions - parameters
    Aug 2010
    I'm very new to machining world, I'm trying to learn but I'm little bit confused..
    Can anybody explain me whats the difference between SFPM and Cutting Feed from Feeds and Speeds? The same situation with Z-SFPM and Z-Feed..
    Help in BobCad says:
    "SFPM: This field indicates the Surface Feed Per Minute for X/Y and X/Y/Z tool motion as specified within the Cutting Conditions table.
    Cutting Feed: This field displays the feedrate for X/Y and X/Y/Z tool motion for the selected tool."
    wikipedia says: http://en.wikipedia.org/wiki/Speeds_and_feeds
    My english is not very good by in my opionion those informations are slighty different.
    Next question - I'm from "metric" world - is it common that also when I'm using milimeters everywhere I've got FPM not MPM?
    Thanks in advance for all the answers and regards,
    expart.
    Aug 2010
    Is it so obvious or I asked incorrect question?
    Feb 2009
    215
    I am new to this also, but on surface speed a 1 inch diameter tool travels in revaluations more distance/surface than a .125 inch at the same rpm's. and the cutting feed is how fast the tool travels from x0 to x10.
    I hope this helps.
    I have used the G-Wizard (Google G-Wizard) that helps in selecting the cutting feed/feed rate and the rpms.
    David L. Aery
    www.hooksolutions.com
  1. Please list your most used settings and parameters
    By 1ctoolfool in forum Haas Mills
    Last Post: 02-27-2013, 03:49 AM
  2. Replies: 13
    Last Post: 06-28-2010, 03:49 PM
  3. parameters and settings
    By DerHammer in forum Fanuc
    Last Post: 06-29-2009, 08:03 PM
  4. Basic Aluminium TIG settings?
    By Normsthename in forum Welding Brazing Soldering Sealing
    Last Post: 03-20-2008, 05:32 PM
  5. parameters,settings
    By Michael82 in forum Haas Lathes
    Last Post: 11-19-2007, 04:02 PM
