587,735 active members*
2,805 visitors online*
    May 2003
    323
    Tool touch sensor?
    Hello
    Can someone explain
    I have to put .002 offset in z to match both tools or I will get a step on face from I.d. turning .
    See pictures tool 3 and 4
    Oct 2013
    9
    depending on the control parameters b61-b64 control the tool eye. If the tool eye is true, then you may want to double check that your tool data is correct and matches the tool being used. minor things like nose radius and cutter angle are all taken into consideration in mazatrol. I can't clearly see what the marking/issue is, but I hope this helps.
    May 2003
    323
    I think I figured it out
    The problem comes when tools are touched of one or more days apart when machine is off
    Just servos issues when they are off .
    All mazaks we have with matrix.
    This does not happen on Fanuc.
  1. Fanuc Touch sensor function
    By Koh9574 in forum Fanuc
    Last Post: 05-12-2012, 11:25 AM
  2. Touch Sensor Z Axis?
    By Ezra in forum Joes CNC Model 2006
    Last Post: 12-14-2010, 09:03 PM
  3. DIY pressure sensor ? - Touch Off Plate ?
    By deleteallusers in forum Mechanical Calculations/Engineering Design
    Last Post: 06-22-2007, 10:56 PM
  4. Tool Height Touch Sensor for Techno-Isel
    By mikkojay in forum DIY CNC Router Table Machines
    Last Post: 08-08-2006, 08:28 PM
  5. lathe tool eye or touch sensor
    By Karl_T in forum CamSoft Products
    Last Post: 04-26-2006, 12:15 PM
