Hey all. Now that I have been using my mill for a bit I have started to consider what tooling I want for later down the CNC road. I'm planning to follow hoss' pattern in converting my BF-20 style mill. Right now, using standard R8 collets, I can not machine much that's clamped to the table. I can't reach it. Even if I pop off the Z bellows I still would have little range. Even propped up on 1" risers I often can't reach. I have come up against a few times when that has made things difficult. I was thinking about getting some solid end mill holders or ER collet chucks to gain some some extra reach.
I like the ER collet chucks best because they would allow for less jacking with the drawbar but I read they can slip easier too and require some heavy torque to cinch down. EM holders can handle heavier cutting but would require more clearance to change tools pulling that R8 shank out all the way. The other thing I was considering was the TTS tooling package... manual package for now and to add on to as time went by. I know that it also suffers a bit from pulling out in heavy cuts too. I kind of like the idea of known tool heights but as a manual user that has little benefit now. It does have the lower clearance requirements for changing tools too which is nice. But it's a bit expensive. So are collets for collet chucks though and those would always have to be touched off to use later with CNC.
I'm stuck trying to decide. Will the TTS bring me any immediate benefit or is way more useful for CNC? I was leaning towards ER chucks, but I see a lot of folks using TTS for CNC work and I was thinking maybe I should just go that way instead. I'd hate to lay out money on chucks and collets and then replace them later anyway.
