587,997 active members*
2,510 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Tooling EMCO compact 5 with tool changer
    Apr 2008
    91
    I don't currently have access to the lathe but I want to go ahead and order the tools I will be needing.
    My understanding is that the tool changer is a 3x3, 3 bar holders, and 3 regular tool holders.
    I don't know the sizes of either and what tools I should be most interested in.
    Re: Tooling EMCO compact 5 with tool changer
    I don't know if EMCO made "Imperial" turret Discs, since i live in Europe..
    But.. the EMCO Compact 5 CNC indeed has 3 Slots and 3 Bores.
    There is a 3D model of the EMCO Compact 5 CNC on Grabcad, made by a fellow dutchman, and i have that 3D model.. because i want to modify my EMCO5 a bit..
    the Slots are 14 mm high, and 12 mm deep, so a ½" tool will fit.
    the Bores are ø10 mm, so you might want to order tools that are slightly bigger, and turn them down, or Drill the holes a bit bigger.. it's cast Iron.. so that shouldn't be rocket Science..
    Another option could be, making a new Turret Disc, with all the holes or slots you need.. (That is what i intend to do, so i can put tools for a certain job in there , and just replace that disc..
  1. Emco Compact 5 CNC tool changer
    By twofoot in forum EMCO CNC Machines
    Last Post: 01-02-2022, 03:14 PM
  2. Replies: 12
    Last Post: 12-11-2021, 08:33 PM
  3. Emco Compact 5 Tool Turret for sale
    By yvesdupre in forum EMCO Lathe
    Last Post: 02-03-2019, 07:31 PM
  4. Replies: 1
    Last Post: 03-04-2016, 08:08 PM
  5. emco compact 5 - lathe tool holder series??
    By NoviceLatheMan in forum EMCO Lathe
    Last Post: 01-27-2011, 06:33 PM
