587,172 active members*
3,026 visitors online*
Results 1 to 4 of 4
    Sep 2010
    86
    TOOLPATH SPLIT
    Hi mates,
    Can somebody gives me a clear tutorial on how to use the TOOLPATH SPILT function in Edgecam.
    Im trying to do a PROFILING operation , but i dont want the toolpath to go all around the workpiece. Im only interested on a specific area of the profile, and i understand the "split" command is the key.
    Can i be helped on how to achieve this?
    Thanks in advance.
    Oct 2003
    127
    Re: TOOLPATH SPLIT
    have you tried using the start and end extensions in the start/end tab of profile?
    a positive number will extend the cut off the geometry and a negative will advance the cut from the start point.
    i am not familiar with the split but i am curious how it works now
    Dec 2013
    27
    Re: TOOLPATH SPLIT
    Instead of splitting the tool path; have you tried projecting the geometry and using that projected line as the profiling path? You can also create a boundary to keep the tool from cutting anywhere by where you specify.
    May 2014
    23
    Re: TOOLPATH SPLIT
    Quote Originally Posted by velocitycnc View Post
    Exactly, easiest way, just use a wire frame line from the profile of the part you want to profile, and then trim the line to where you want to start and end the path.
    I am also not familiar with the split.
  1. split operation
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-28-2014, 09:06 AM
  2. Can someone split this ??
    By tubeguy in forum BobCad-Cam
    Last Post: 10-19-2012, 08:41 PM
  3. Split/NCS
    By gplush in forum Uncategorised CAM Discussion
    Last Post: 11-05-2009, 11:56 PM
  4. How do you split a project that is to big for your cnc?
    By dave8305 in forum WoodWorking Topics
    Last Post: 03-21-2009, 03:30 AM
