603,940 active members*
2,094 visitors online*
Results 1 to 4 of 4
    Mar 2008
    23
    Hello
    How is it possible to calibrate a toolsetter (Renishaw)? There isn’t any softkey in the input mask.
    What machine parameters have to be adjusted?
    The machine is a Spinner TC-52 with Siemens 810+Shopturn controller.
    Thanks in advance
    Hello
    Have you solved the problem?
    Mar 2008
    23
    Hello dsplastx
    I still don’t have any solution. Do you have one?
    Regards, Positron
    Ok, I sent you an e-mail. But I have one more question. Do you know the ropes? You’ll have to open the parameter PASSWORT and you may not make a mistake there.
