603,943 active members*
3,969 visitors online*
Results 1 to 7 of 7
    Jan 2007
    114
    Toolsetter problems
    I just bought a 2004 VF 3 SS and it came with a Renishaw probe and toolsetter
    I have figured out how to use the toolsetter and it seems to take the tool down touch off then spin the tool and give me the diameter as well. Very Cool
    The problem I am having is when I set my work offsets on the G54 X & Y seem to work fine and the machine goes to 0x & 0y and then the Z comes down but instead of going to the top of the part the machine starts cutting about 6 " above the part. I am pretty sure it is something simple but I appear to be missing something
    Any suggestions would be greatly appreciated.
    Oct 2005
    114
    Have you calibrated the touch probe lenght with the tool setter?
    You should be able to touch off z with the probe, and it will set the z offset.
    Also make sure you have g43 called out, with the H1 , for tool 1 or what ever tool you have.
    HAAS VF3-5 axis trunion
    Mastercam X3
    Jan 2007
    114
    Hmmm No I have not calibrated the touch probe with the tool setter
    How do you do that ?
    There appears to be a G43 In the code
    G43 Z .1 H 5
    Oct 2005
    114
    Use visual quick code , or the ips software in the control. there are probe calibration routines in the 2 programs, they do the same thing. they are macros.
    Mastercam X3
    Jan 2007
    114
    Hello I just wanted to say thanks to everyone that took the time to help out, I have the machine up and running and I think the Renishaw system is pretty cool. I also have the calibration doc's if anyone wants them let me know.
    Jul 2005
    340
    just share it , maybe we`ll learn something
    Jan 2007
    114
    I would like to share it, but I was not exactly sure how to attach a PDF what is the best way to do this ?
  1. More DNC problems
    By jnc in forum Haas Mills
    Last Post: 05-28-2009, 12:16 AM
  2. Probe and toolsetter suggestions?
    By REVCAM_Bob in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2008, 01:12 AM
  3. atc problems
    By novattack in forum Fadal
    Last Post: 08-06-2007, 01:57 PM
  4. Building Touch Probe and Toolsetter...
    By REVCAM_Bob in forum CNC Machine Related Electronics
    Last Post: 05-23-2007, 12:43 PM
  5. Mazak / Yasnak MX3 control toolsetter
    By soszi1950 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-10-2007, 03:24 PM
