587,614 active members*
3,650 visitors online*
Results 1 to 4 of 4
Hybrid View
    Jul 2010
    Torch height control
    Still working on my first project which is a 10' x 5' plasma table. Nothing fancy just purpose made rollers running on inverted angle and hollow section and driven by belts.
    I have came across loads of issues I have to iron out but the main problem I have now is with a THC I bought from Poland on ebay.
    http://proma-elektronika.pl/download/doc/thc_en.pdf
    Could someone please tell me how to connect it to either the 15 pin plug or 12 pin connector on the board below?
    3 Axis TB6560 CNC Stepper Motor Driver Board Controller | eBay
    Bob
    May 2012
    231
    Are you using mach3 to drive the BOB-driver board?
    Jul 2010
    Yes I am using Mach 3.
    My problem is where to connect the up - down wires to in the board as outside the 15 pin remote plug and 12 pin connector which seems to be for a dro, all other connections are used up
    Dec 2012
    15
    Did you ever get this figured out?
  1. DIY Torch Height Control
    By tjb1 in forum Stepper Motors / Drives
    Last Post: 12-21-2016, 05:12 PM
  2. Torch Height Control
    By Rxe in forum Waterjet General Topics
    Last Post: 04-07-2010, 12:09 PM
  3. Need better torch height control?
    By Karl_T in forum Waterjet General Topics
    Last Post: 04-27-2009, 05:36 PM
  4. Torch Height Control
    By luther in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-12-2007, 09:51 PM
  5. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
