587,945 active members*
3,614 visitors online*
Results 1 to 4 of 4
    Sep 2012
    TORCH HEIGHT CONTROL PROBLEM
    I USE A HYPERTHERM POWERMAX 1100 WITH THC CONNECTED TO MY WIN-CNC CONTROL SYSTEM. MY VOLTAGE FLUCTUATES WAY TOO MUCH FOR THE THC TO WORK PROPERLY. WHAT CAN I DO TO FIX THIS?
    Jan 2011
    188
    without more info, the simplest guess would be a weak work surface ground, moisture in the air, or consumable issues (worn, loose, or wrong parts)
    www.signtorch.com
    Jan 2008
    2247
    Your height control must have some background set up parameters...such as gains, acceleration, hysteresis. The feedback loop and the reaction needs to be dampened so that it averages the Raw DC voltage from a plasma. All plasma systems produce a rather large amount of "hash" or voltage fluctuation.....when averaged and dampened this voltage works well to control height
    Quote Originally Posted by TOMTIDWELL View Post
    Apr 2006
    54
    Go :: CNC4PC :: iNtRo and look Capacitive Height Controller.
    It detects the height without cutting voltage and keep it constant, whatever your cutting speed.
    Regards
    Can
  1. DIY Torch Height Control
    By tjb1 in forum Stepper Motors / Drives
    Last Post: 12-21-2016, 05:12 PM
  2. torch height control problem
    By drieslaas in forum Waterjet General Topics
    Last Post: 09-29-2011, 07:26 PM
  3. Torch Height Control
    By Rxe in forum Waterjet General Topics
    Last Post: 04-07-2010, 12:09 PM
  4. Need better torch height control?
    By Karl_T in forum Waterjet General Topics
    Last Post: 04-27-2009, 05:36 PM
  5. Torch Height Control / Capacitive Height Control
    By ahlbebuck in forum Open Source Controller Boards
    Last Post: 11-27-2006, 08:32 PM
