603,371 active members*
4,062 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Torchmate Drivers Software Features
Results 1 to 8 of 8
    If you were to request new features to be added into the Torchmate 2 drivers software, what would they be? No idea is too wild so let the imaginations fly!
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Jun 2007
    20
    I would like to be able to resize a DXF file after it was transfered from cad to the torchmate software.
    thanks
    Quote Originally Posted by balto View Post
    thanks
    There is currently a way to resize them as a general scale such as .5 size and 1.5 size. Were you looking for something along the lines of resizing individual objects?
    Jun 2007
    20
    Should have worded it better. For example, torchmate's art clip files that comes with the software is already, DXF files so you don't use the CAD program. I wanted to resize some of them in the torchmate program. the whole thing, not just a object in it. Can you do that now?
    thanks
    Mar 2008
    33
    Smile change scale in torchmate driver software
    you can change scale in the torchmate driver software when import DXF file.
    For example,change scale 1 to 1.5 or 2 and so on,but is suit for one object.
    reed
    I would like to be able to change the orientation of the DXF file (horz. to vert. or flop)
    also I would like to use the pendent with the THC control (Turn the tourch on and off,raise and lower)
    JDDurham
    Also Mike I’m upgrading our TM 2 this week and every thing is working fine this is one good reason why to buy a tourchmate system they can be modified very easily to whatever spec. You need
    I will post the whole project next week
    JD
    The DXF file will always be oriented using the bottom left X- and Y- corner. How you draw your parts in the CAD, or how your motor configurations are set-up, will determine how things are oriented on the table.
  1. MEI LC/DSP Prof. Motion Control. Wo helps me on: Software and drivers?
    By Harmpy35 in forum CNC Machine Related Electronics
    Last Post: 08-07-2010, 09:59 PM
  2. Torchmate and Design2fab software?
    By kreb in forum Torchmate
    Last Post: 05-25-2010, 10:53 AM
  3. Replies: 26
    Last Post: 08-08-2006, 11:56 AM
  4. Drivers & software
    By willy in forum DIY CNC Router Table Machines
    Last Post: 07-02-2006, 12:27 PM
  5. software for testing drivers/controllers
    By posix in forum Open Source Controller Boards
    Last Post: 06-09-2005, 01:04 PM
