603,936 active members*
3,028 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Torchmate > Torchmate growth 2x2 with powermax 65. Pierce but no line.
Results 1 to 5 of 5
    Jul 2016
    3
    I haVe the 2x2 growth series table I'm trying g to make my first line test the dry run goes fine. I go active and it drops down the ohmic sensor detects my steel. The torch lights makes a pierce. Stays on for 10 or 15 sec arc goes out air flows for another 20 sec then .nothing. Last call to Lincoln was to make sure plasma was on second mode from the top. It is but I've tried all 4 modes...no change. Help.
    Nov 2015
    10
    Re: Torchmate growth 2x2 with powermax 65. Pierce but no line.
    Quote Originally Posted by UpKnives View Post
    Does the torch head move during the 10-15 seconds the arc is on?
    What are the modes you are referring to? I have ran my table in awhile, I don't remember a mode selection like you're talking about.
    Jul 2016
    3
    Quote Originally Posted by BuzzSaw70 View Post
    No head movement. My powermax 65 has a mode selector (top right) expanded, plate,gouge,and one with a lock.on it
    Jul 2016
    3
    Also labeled continuous pilot arc and non continuous pilot arc
    Nov 2015
    10
    Ok. You want non continuous arc for plate.
    If no movement is the TM receiving the ok to move signal from the Hypertherm?
  1. Powermax 45, arc stops after pierce intermittently
    By DirtBound in forum Hypertherm Plasma
    Last Post: 01-24-2014, 07:38 PM
