I have an issue with MACH3 running my Tormach that has been an issue for months but last night I think the pieces of the puzzle finally came together.
The issue is if you are running a part and then hit the pause command button on the main MACH screen. The machine stops as expected but when you hit continue the location pointers appear to get changed and the operation continues on except to the wrong location. As you can imagine this is not good!!!!
Over the past several months I have broken several tools when this happens but last night it happened in such a way that I am sure the location pointer change is what is happening. Most times I just run one off parts so the chance of a G-code error exists. However, last night I was running a program that had just run several good parts.
I know the pause - restart has been an issue with MACH just wondering if anyone has a work around. Restarting from the start of a program and cutting air would be really frustrating.
Thanks,
Robert
