588,112 active members*
5,586 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach PCNC owners - can you post some sizes please
Results 1 to 16 of 16
    Feb 2007
    1538
    Hi All - I am a Toolmaker/Mouldmaker working from home - in New Zealand - I have a Syil X3 - but now I have just discovered the Tormach.
    This machine looks a lot more solid - and looks as though the slideways have much better engagement length. Could someone please post the length of slide engagement and length of travel while fully engaged - The X3 Y travel only has about 3" of travel before engagement length reduces badly.- And at max of about 6" is only half engaged. The Tormach looks a lot better. also the X3 vertical colum is light in section only about 4"X 6" - love to know what the Tormach is - it looks in the pics I have studied to be more like 8" x 6" ..?
    I have limited ridgidity for steel work eg a 3/8 HSS cutter with 0.050 cuts is almost too much..... or a 1/2" with 0.030" etc - metal removal is better with max revs and carbide - but the lack of ridigity means the edge does not last very long.....and I see the Tormach spins faster.....
    Cheers
    Jun 2006
    2512
    My Tormach has full engagement over the full travel lengths of:
    x - 15.9 inches
    y - 10 inches
    z - 16.25 inches
    Newer machines have 18 inches on the x -axis but I'm sure it still has full engagement.
    Regards
    Phil
    Quote Originally Posted by keen View Post
    Cheers
    Feb 2006
    1072
    keen, the Tormach column is 9.75" wide x 8.5" deep. I don't know what the wall thickness is though.
    The Y axis is fully engaged for the whole travel. If you look at http://www.tormach.com/document_libr...arts_Lists.pdf you will see that the Y ways run from the column to the front of the machine base. I didn't understand your question until I saw http://www.syilamerica.com/images/da/RIMG0006.jpg and realized that the X3 ways were not full-length.
    Hope this helps! I love my Tormach.
    Best regards,
    Randy
    Feb 2006
    1072
    Hey, overlapping replies! I went down to measure my machine in the midst of typing.
    (correction of Phil's post retracted)
    Best regards,
    Randy
    Jun 2006
    2512
    My column is 10 inches wide by 8 inches deep (not including the z-axis ways).
    Regards
    Phil
    Jun 2006
    2512
    Ooops, yes, I have edited the typo.
    Regards
    Phil
    Quote Originally Posted by ProtoTrains View Post
    I think you mean to say that the X travel is 18 inches, Phil...
    Best regards,
    Randy
    Feb 2007
    1538
    Smile Many thanks
    Hey - Many thanks Guys! that was quick! Your machines are so much better proportioned than the X3. This is all the confirmation I need to make the decision. cheers.
    Feb 2007
    1538
    Gibs?
    Oh, one last question. The X3 has screw adjusted parallel gibs on the X and y slides - does the Tormach have the same or taper gibs? cheers
    Feb 2007
    1538
    Oops just saw your exploded drawing link Randy - taper gibs - excellent news!
    Nov 2006
    6
    Cheers
    We've just got a Tormach in Auckland if you'd like to see one.
    Regards,
    Brian Harris
    021 973 198
    Jul 2007
    438
    could some one please post up the dimensions of the deluxe stand? i asked for it when i was getting my quote but never got it from them. they have the size of the crate it comes in listed on their site but not the assembled dimensions. from looking at the pictures i am guessing about 3-1/2' x 7' to 4' x 8' but would like exact measurements to make sure it will fit in my shop.
    thanks.
    Feb 2006
    1072
    Robert, http://www.tormach.com/document_library/D40148.pdf has a fully dimensioned drawing of the machine on the deluxe stand.
    Best regards,
    Randy
    Nov 2006
    6
    Check out the pdf's on their website-all dimensions are there.
    Cheers,
    BH
    Jul 2007
    438
    Quote Originally Posted by Brian Harris View Post
    Cheers,
    BH
    i still couldn't find them. the only dimensions i can find are the packaging dimensions i believe, unless the chip tray is in fact 10'10" long. that sounds pretty big to me.
    Jun 2006
    3063
    The chip tray on the deluxe stand is 47" deep x 80" wide and you'll need around 78-80" of headroom.
    Mike
    Jul 2007
    438
    Quote Originally Posted by MichaelHenry View Post
    Mike
    thanks!
  1. Replies: 18
    Last Post: 09-23-2015, 06:49 AM
  2. looking for Tormach PCNC 1100 training in SF Bay Area
    By mw11 in forum Tormach Personal CNC Mill
    Last Post: 04-27-2007, 08:01 PM
  3. syil sx3 vs tormach pcnc 1100
    By ataxy in forum Benchtop Machines
    Last Post: 03-17-2007, 04:51 AM
  4. Engraving on The Tormach PCNC
    By phil burman in forum Benchtop Machines
    Last Post: 09-16-2006, 02:45 AM
