587,420 active members*
3,149 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tormach Users, How do you clean up your chips.
Page 1 of 2 12
Results 1 to 20 of 30
    Feb 2014
    103
    Had my tormach for a few weeks now and am building up quite the collection of chips.
    I want us to get together and talk about methods for cleaning up chips. Spray hose on coolant pump?, Compressed air? ect....
    Tell me how it's done!
    Dec 2006
    302
    Re: Tormach Users, How do you clean up your chips.
    I used to use a vacuum but now I hose everything down, a method I learned from WOT. First, I use the T-slot cleaning tool to clear out the slots, then with a 3 or 4 inch wide spatula I scrape up the bulk of chips. When I replaced the Tormach coolant system with a sump pump feeding a 1" i.d. tube to a distribution block, the Tormach shower hose was left over. So, I now have that shower hose permanently connected to a brass ball valve on the distribution block. After scraping up the bulk of chips, I just give everything a good hosing. It all takes but a few minutes and leaves everything nice and clean.
    Dec 2012
    194
    All of the ways mentioned here and I also made ramped table covers which significantly limit the chis in table slots. I posted pics awhile back
    Feb 2014
    103
    Quote Originally Posted by JohnToner View Post
    Awesome! Thanks! That sounds like it works awesome! I would love to see some pics of that setup!
    Dec 2012
    194
    Aug 2013
    980
    I have a Tormach way cover which helps.
    I was shop vacing everything after a run but it was costing too much in bags so I bought a dust deputy from Oneida. It works great and saves on bags.
    Have fun!
    Nathan
    Quote Originally Posted by Stevos758 View Post
    Dec 2006
    302
    Stevos, I can take a few pics Monday but I have no idea how to post them. I will take them with my cell phone. I forgot to mention it, but the high coolant flow from the Tormach shower hose easily cleans the chips from the those bellows that serve as way covers.
    Feb 2014
    103
    Awesome guys! Keep em coming!
    Send pics to email at rippscnc@gmailcom or just shoot me a message and I can walk you through it.
    Mar 2009
    1863
    I let the coolant drain out over night then I vacuum the chips out in the morning.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    Dec 2012
    194
    I have a old shop vac that I keep for doing just that job.
    Jun 2006
    3063
    I use a small scoop like this one:
    McMaster-Carr
    to clean up piles of chips in the chip pan and a Fein shop vac with Dust Deputy cyclone to vacuum out the rest:
    Dust Deputy
    The Fein crevice tool does a pretty good job of getting into the T-slots and the Dust Deputy traps the swarf and hole before it gets into the Fein.
    If I ever go back to flood coolant (I'm using a Fog Buster now) I plan to get a pump with higher flow than the Tormach pump offers and install a coolant manifold with a branch line for a garden hose nozzle.
    Aug 2011
    135
    What chips? Attachment 265932
    But seriously a dust deputy is great investment no doubt
    Sent from my SM-G900V using Tapatalk
    Oct 2010
    253
    I use a combination of an automotive parts brush, compressed air, a thin piece of wood to squeegie under the machine, and a shop vac. Sounds like a lot, but takes about 10 minutes and leaves a clean Tormach.
    Feb 2014
    103
    I'll have to snap a pic of mine. Only had it for two weeks but man those ships are everywhere! For those of you soley using a shop vac. I've never sucked up water with mine. how do the wet chips affect it. Just leave the filter in and suck them up?
    Dec 2006
    302
    Stevos,
    I emailed some pics to you. The email is from niceredvette@gmail,com with no subject or message. I really didn't know how to do it so I took pics with my cell phone, then my step-son emailed them to me and I forwarded them to you. (and, by mistake, also to popspipes)..
    Feb 2014
    103
    Got them! Thanks John!
  17. #17
    Jan 2007
    1332
    I use an Oneida Air Systems Dust Deputy vortex filter in front of my shop vac. The Dust Deputy vortex filter separates out chips and coolant before it gets to the filter in my shop vac so I never have to buy another expensive replaceable filter again.
    Don
    https://www.youtube.com/watch?v=9NXZKYWpMbE
  18. #18
    Dec 2006
    302
    That's a 1" line supplied by a sump pump that feeds the dist. block. I take flooding seriously. Really works great. I plan to fit the end of the shower hose with one of those old, made in the USA, brass nozzles. Still, as it now stands, there's plenty of pressure for cleaning everything. I replaced the Tormach chip shield with clear plastic 36" high and, I believe, 32 or 33" wide to fit the 1/4" channels for the old shield, That makes it easy to remove for tool changes. The sides have 36" panels held with "C" clamps for now. When I find the time, I'll make some 1/4" channels for them as well. Low budget, simple, and very functional. Sorry, forgot to include their photos.
  19. #19
    Jun 2014
    1780
    Stevos,
    I got them too John Thanks!
    I keep all the chips and coolant on the table, not perfect but it works for me.
    mike sr
  20. #20
    Nov 2013
    402
    I cut a 32 Oz. plastic Gatorade bottle in half, and use it as a scoop.
    I also use the cheap 50 cent chip brushes from Home Depot.
    A lot of Machinists and Machine Shop owners frown on using compressed air to clean machines with.
    They claim chips will get blown into places they aren't welcome, like under the table, into crannies, and into electrical control panels.
    I don't know if it's fact or an old wives tale, but I usually try to avoid using compressed air, and blowing chips around.
Page 1 of 2 12
  1. Of Interest to Tormach Users
    By CNCneeds in forum Tormach Personal CNC Mill
    Last Post: 11-08-2014, 08:32 PM
  2. How do you clean your Tormach?
    By BAMCNC.COM in forum Tormach Personal CNC Mill
    Last Post: 08-12-2013, 03:54 AM
  3. Questions for Tormach Users
    By ljh34481 in forum Tormach Personal CNC Mill
    Last Post: 04-02-2012, 05:43 AM
  4. Tormach users in Albuquerque?
    By wdp67 in forum Tormach Personal CNC Mill
    Last Post: 01-28-2010, 07:14 PM
  5. Tormach users also in SE or SW Michigan?
    By befunovo in forum Tormach Personal CNC Mill
    Last Post: 12-18-2007, 04:48 PM
