603,800 active members*
3,539 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > torq cut spindle, need to run cnc with out spindle running
    Nov 2013
    26
    22 torq cut DX32, Want to use a high speed air tool in spindle.
    How to I tell or lie to control to let it run in full auto
    .Removing "S", only set off alarm and "S0" the same.
    Nov 2004
    164
    Re: torq cut spindle, need to run cnc with out spindle running
    Did you also remember to remove the M3 out of the program? Probably need to make sure any inch/rev feedrates are out of the program as well. My machine's running right now or I'd try it.
    Nov 2013
    26
    Quote Originally Posted by jmullett View Post
    Thanks , didn't work, removing feedrates . I'll need feedrates to do what I want to do.
    It alarmed out ,PM Parser, no feedrate specified.
  1. Bridgeport Torq Cut 22 - Spindle/encoder problems, bad?
    By vettespeed in forum Bridgeport / Hardinge Mills
    Last Post: 07-28-2011, 10:16 AM
  2. Bridgeport Torq Cut 3g spindle speed issue
    By scrap maker in forum Bridgeport / Hardinge Mills
    Last Post: 04-19-2011, 03:05 PM
  3. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  4. TORQ-CUT 30 BRIDGEPORT DX32 SLOW RPM IN SPINDLE
    By dogamor in forum CNC Machine Related Electronics
    Last Post: 07-19-2010, 07:12 PM
  5. How do I orient spindle after encoder replacement? Torq Cut 22
    Last Post: 01-22-2007, 08:39 PM
