587,236 active members*
3,687 visitors online*
Results 1 to 4 of 4
    Sep 2003
    73
    Torqcut way oil
    Picked up a Torqcut 3G this fall seems to be working well, a few questions though, for way oil it calls for Vactra3 or equivalent , most of our newer machines with linear ways use thinner oil, what is everyoNe using ? Also want to change oil in the transmission, what goes in there ? Happy New Year everyone, Jon P.
    Dec 2005
    504
    Re: Torqcut way oil
    The oiler on my TC3 states Sunoco 1180. I've been running Vactra #2 which cross references.
    When I replaced the gearbox on my TC3 I ordered a gallon of oil from Drisson (bp-parts.com). I don't know if it's listed on the site but when I called them they hooked me up. It was expensive. When it arrived it came in an un-marked container so I don't know exactly what it was.
    Sep 2003
    73
    Re: Torqcut way oil
    Thanks for the reply Randy, yea vactra #2 is what it will be I'm sure the metering units are calibrated for it. I found a thread where a guy had taken apart his transmission to change bearings and oil, I may do that not sure, it seems a little noisy above 5000 but I do not have anything to compare it to. I did find the oil its synthetic Mobil SCH 626 about 40-50 dollars a gallon plus shipping. Any more to report on your digitizing? I noticed there are quite a few parameters about digitizing. Good Day. Jon P
    Dec 2005
    504
    Re: Torqcut way oil
    Quote Originally Posted by Jonp View Post
    My machine was noisy when I got it. When I pulled the motor there was abnormal wear on the pinion. I had to replace the motor bearings and the pinion. The gearbox was still a little noisy so I swapped it out with one that I bought off Ebay Canada and imported, as it was cheaper than buying the new gear set. I'd recommend you call Drisson BptParts.com - Bridgeport & CNC Machine Replacement Parts. They had the gears and recommended a number of gears to replace in the gearbox. There is a photo in this thread: New (to me) VMC - Page 5
    I've been using the digitizer with good results. The new mount fixed all my hate. The electrically adjusted radius was the key. I've been using it to find hole centers and it has been dead on.
  1. Need help with some settings on Torqcut 22
    By racingrob in forum Bridgeport / Hardinge Mills
    Last Post: 05-28-2015, 10:23 PM
  2. BobCad for Programming TorqCut 22
    By md63825 in forum Bridgeport / Hardinge Mills
    Last Post: 09-11-2011, 02:41 PM
  3. BPC-MC control - Torqcut TC-1G
    By nlh in forum Bridgeport / Hardinge Mills
    Last Post: 08-05-2009, 07:03 PM
  4. Torqcut 22 computer
    By gokarter in forum Bridgeport / Hardinge Mills
    Last Post: 01-20-2008, 08:21 PM
  5. TORQCUT 22
    By limey44460 in forum Bridgeport / Hardinge Mills
    Last Post: 01-11-2008, 01:15 PM
