588,234 active members*
4,514 visitors online*
    Oct 2008
    44
    Torque spec on assembly bolts
    Hi all,
    I've been searching manuals and scouring the internet trying to locate torque specs for the various SHCS that keep subassemblies together (e.g.: head, column, etc.) I'm primarily concerned about the pieces that are aligned with the tapered dowels.
    Obviously if they are torqued all equally, there shouldn't be a problem with distortion of the casting. I just want to make sure I torque them enough so that they don't back out. Or even worse, too much so that the iron creeps & yields.
    I'm going to start crunching numbers to find a safe torque value, just wanted to see if anyone else had already done the work for me.
    Thanks in advance!
    Feb 2006
    1072
    Swede,
    Tormach's torque guidelines are on PDF page 181 (marked 9-49) of the current user manual http://www.tormach.com/document_libr...-3-UM-C4.1.pdf
    Best regards,
    Randy
    Oct 2008
    44
    Excellent!! Thanks so much. I torqued them all to slightly less than that because of a conservative calculation I did. I'll torque them up to spec now. Thanks again.
  1. Eccentric bolts
    By JerryFlyGuy in forum Mechanical Calculations/Engineering Design
    Last Post: 07-27-2014, 02:18 AM
  2. Constant Torque vs. Varaible Torque VFD
    By robhrzic in forum Phase Converters
    Last Post: 02-17-2012, 02:46 AM
  3. Question about using nuts and bolts.
    By Broken Balsa in forum Commercial CNC Wood Routers
    Last Post: 03-03-2011, 04:25 PM
  4. Nuts and Bolts - THREAD
    By High Seas in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 04-17-2008, 05:46 AM
  5. HSR rail bolts?
    By Gnu in forum Linear and Rotary Motion
    Last Post: 01-10-2007, 11:24 PM
