603,964 active members*
1,999 visitors online*
Results 1 to 7 of 7
    Oct 2003
    208
    total line length program?
    does anyone know of a program that will tell me the total line lenght of a dxf file, or a gcode program.
    i would like to know the total length of the lines in a file. or a program that will read gcode and tell me the the same thing. or the total cut time with a given a feed rate.
    Apr 2003
    1876
    Many CAD/CAM programs will give this information, like Mastercam. I'm not aware of any programs that only do that without CAM. I suppose you could write a script to evaluate such data, but I'm not sure if it would be worth it.
    You might look for backplotters, (an app that reads g-codes and displays the toolpath). Something like that might have what you're looking for.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Mar 2003
    928
    OneCNC NCSentry
    Hi Joe,
    OneCNC NCSentry is just such a stand alone program.
    It will read in the G code file and give you line length, cut time, feed line length, rapid line length, etc.
    It will also simulate the part with stock. Live rotate the rendering.... It also has Collision detection.
    It works for both mills and lathes in the same program.
    There is a trial version available.
    You can get to it by clicking on the OneCNC banner add on the home page of this forum.
    Nov 2003
    634
    You can do this in Microsoft Word easily, or just about in any word processing software.
    Apr 2003
    1876
    buscht, I think what he's looking for is something to read the length of the moves in inches/mm, not count the number of lines of code in the program.
    i.e.
    X0 Y0
    G91
    X1.
    Y1.
    X2.
    would have a length of 4". (The length the tool travels)
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Nov 2003
    634
    Matt,
    Thanks, I read that post wrong.
    T
    Apr 2003
    1876
    I had to take a double look at it too, I almost said the same thing you did.
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
  1. *Knee Mill Retrofit*
    By IJ. in forum Vertical Mill, Lathe Project Log
    Last Post: 02-13-2011, 10:10 AM
  2. Learning to Program CNC Turning Center
    By Farmer in forum G-Code Programing
    Last Post: 09-12-2005, 06:03 AM
  3. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  4. Total Newbie on Taig CNC Mill!!
    By vwgo in forum Taig Mills / Lathes
    Last Post: 10-18-2004, 01:40 AM
  5. A few honest questions
    By HuFlungDung in forum CamSoft Products
    Last Post: 06-16-2004, 12:24 AM
